Home » Modeling » TMF (Xtext) » Import built-in types as qualified names
Import built-in types as qualified names [message #1407392] Tue, 12 August 2014 09:51 Go to next message
Hey everyone,
My model language requires for built-in types to be imported in the file where they are used. The problem is that those types looks like this: 'com.type.ID' 'com.type.Binary' 'com.type.DynamicStructure' etc. I tried making grammar for that and here is what I could think of:
DomainModel:
packageDeclaration=PackageDeclaration;
PackageDeclaration:
"package" name=QualifiedName ";" importDeclarations+=ImportDeclaration*
abstractTypeDeclarations+=AbstractTypeDeclaration+;
ImportDeclaration:
"import" importedNamespace=QualifiedName ";";
AbstractTypeDeclaration:
modifier+=ClassOrInterfaceModifier* typeDeclaration=TypeDeclaration;
TypeDeclaration:
ClassDeclaration |
EnumDeclaration | InterfaceDeclaration
TypeRef:
SimpleTypeRef | Type;
SimpleTypeRef:
DynamicStructure;
DynamicStructure:
{DynamicStructure} 'com.type.DynamicStructure' (also tried with name='com.type.DynamicStructure');
Type:
referencedType=[TypeDeclaration|QualifiedName];
I am able to reference TypeRef for field parameter types for example:
FieldDeclaration:
type=TypeRef variableName=ValidID ';';
and it works. But when I try to use it as part of import statements it says 'Mismatch input 'com.type.DynamicStruture' expects 'RULE_ID'' and I suspect it is because of the QualifiedName definition of the ImportStatement.
Is it possible what I am trying to do? Or is it wrong?
Thanks a lot in advance!
Re: Import built-in types as qualified names [message #1407397 is a reply to message #1407392] Tue, 12 August 2014 09:57 Go to previous messageGo to next message
lexing and parsing is done in two steps
=> com.type.DynamicStructure is always lexed as a keyword and not as an ID.
you can introduce an
XID: 'com.type.DynamicStructure' | ID; and use that instead of id
of you do not hardcode this packages
Re: Import built-in types as qualified names [message #1408054 is a reply to message #1407397] Thu, 14 August 2014 01:59 Go to previous messageGo to next message
Hey Christian,
Thanks for your response but I still can't make it work. What do you mean by use XID: 'com.type.DynamicStructure' | ID istead of id? Does this mean I have to create new rule for QualifiedName as well? If so, wouldn't that break my current functionallity, because I want to be able to import other types as well (not only built-in types)?
I tried changing my grammar to:
TypeRef:
SimpleTypeRef:
name=(DynamicStructure | ID);
DynamicStructure:
Type:
but there wasn't much of a difference.
Could you elaborate a bit more on that?Thanks.
Re: Import built-in types as qualified names [message #1408064 is a reply to message #1408054] Thu, 14 August 2014 02:31 Go to previous messageGo to next message
your QualifiedName rule (that may be ID ("." ID)* and the com.type.DynamicStructure conflict.
why do you hardcode this com.type.DynamicStructure thing.
id replace that with quailifiedName in the first place.
or you have to take care that com.type.DynamicStructure is parsed by the quailifiedName rule a well (wich might be very hard)
i dont know if it help to replace
com.type.DynamicStructure with a datatype rule
WiredStuffYouShouldNotDo : "com" "." "type" "." "DynamicStructure"
and
XID: "com" | "type" | "DynamicStructure" | ID;
QualifiedNAme: XID ("." XID)*
Re: Import built-in types as qualified names [message #1408091 is a reply to message #1408064] Thu, 14 August 2014 03:56 Go to previous message
I understood now. Thank you! I was trying to make the whole 'com.type.DynamicStructure' to be a QualifiedName (unsuccessfully), but your solution is cool. Thanks!
Previous Topic:Building Xtext Languages with Maven and Gradle
Next Topic:Implicit imports and and plug-in resources
Current Time: Sun Jul 20 05:30:12 EDT 2025
Powered by FUDForum. Page generated in 0.03293 seconds
