Home » Language IDEs » C / C++ IDE (CDT) » Help: ld: cannot find -l.... any library
Help: ld: cannot find -l.... any library [message #140700] Tue, 15 March 2005 02:07 Go to next message
Originally posted by: krebs-dv.lisega.de
Hello out there,
i would like some help on following problem:
Using eclipse / cygwin configuration (gcc, make, ld..) i get following
message when trying to include any library (test with libc (cygwin):
Building target: AO_CW.exe
gcc -o AO_CW.exe ao_cw.o errw.o findw.o pcidataw.o -llibc.a
/usr/lib/gcc-lib/i686-pc-cygwin/3.3.3/../../../../i686-pc-cy gwin/bin/ld:
cannot find -llibc.a
collect2: ld returned 1 exit status
Library and path (not in example) are set in project properties, C/C++
Build, GCC/CLinker Libraries/Library search path.
After trying different combinations on that i still get the above message.
Thank's for any help!
Uli
Re: Help: ld: cannot find -l.... any library [message #140737 is a reply to message #140700] Tue, 15 March 2005 02:54 Go to previous messageGo to next message
Originally posted by: grkoma.gmail.com
Hello Uli,
Try -llibc instead of -llibc.a ....
It is enough to set name of the library without extension in project
libraries dialog.
Marko
Uli wrote:
> Hello out there,
> Regards
> Uli
Re: Help: ld: cannot find -l.... any library [message #140755 is a reply to message #140737] Tue, 15 March 2005 03:20 Go to previous messageGo to next message
Thank's Marko; i tried that already; finally i have to link a library with
the extension .lib (pci_win.lib).
Uli
Marko Nikolic wrote:
> Hello Uli,
> libraries dialog.
> Marko
> Uli wrote:
>> Hello out there,
>> Regards
>> Uli
Re: Help: ld: cannot find -l.... any library [message #140845 is a reply to message #140755] Tue, 15 March 2005 15:22 Go to previous messageGo to next message
Hi Uli,
-llibc will try to link a library by the name liblibc.so, liblibc.dll,
liblibc.a, etc, depending on your platform and link settings. If you
need to link against libc just use -lc (though the compiler should link
against libc by default). If your library doesn't follow the lib* naming
convention you'll have to use the full name as you did, but I'm not sure
that there are no side effects in doing that.
Javier Kohen <jkohen@users.sourceforge.net>
ICQ: blashyrkh #2361802
Jabber: jkohen@jabber.org
Re: Help: ld: cannot find -l.... any library [message #140963 is a reply to message #140845] Wed, 16 March 2005 04:41 Go to previous message
Javier Kohen wrote:
> Hi Uli,
Hi Javier,
it's easy, after you know it; eclipse does not like extensions; without an
extension it worked.
Thank's a lot
Uli
Previous Topic:Remote debug against simulator -- no 'load'?
Next Topic:Configuration - CDT and Cygwin
Current Time: Tue Nov 04 08:20:55 EST 2025
Powered by FUDForum. Page generated in 0.05072 seconds
