Home » Modeling » TMF (Xtext) » Manually add errors to a resource
Manually add errors to a resource [message #1406587] Sun, 10 August 2014 10:16 Go to next message
In my attempt to create an editor for the GLSL shading language im facing different problems. I would like to show errors reported by the native compiler in the editor.
I managed to create an option to compile the shader and show the error log in a console. Then i added these errors to the resource to highlight the specific line in the editor. Unfortunately the errors dont show up.
This is my attempt: I made a LinedDiagnostic class to implement the Diagnostic interface needed for the resource.
public static class LinedDiagnostic implements Resource.Diagnostic{
 final String message;
 final int line;
 final String resourceURI;
public LinedDiagnostic(String message, int line,String resourceURI) {
    this.message = message;
    this.line = line;
    this.resourceURI=resourceURI;
public String getMessage() {
    return message;
public String getLocation() {
    return resourceURI;
public int getLine() {
    return line;
public int getColumn() {
    return 1;
and then added the Errors to the resource:
public static void addErrorsToResource(String errors,Resource r){
    Stream.of(errors.split("\n"))
    .skip(1)
    .map(line->CompilerError.parseError(line))
    .filter(e->e!=null)
    .forEach(
            e->{
                System.out.println("Adding error: "+e);
                r.getErrors().add(new Internals.LinedDiagnostic(e.text, e.line, r.getURI().toString()));
this is called by a popupAction:
MessageConsole compilerConsole=null;
public void run(IAction action) {
    IFile shaderFile=(IFile) ((TreeSelection) selection).getFirstElement();
    if(compilerConsole==null){
        compilerConsole=createConsole("GLSL Compiler");
    MessageConsoleStream out=compilerConsole.newMessageStream();
    try {
        int shaderType=ShaderDialog.getShaderType(shell, shaderFile);
        if(shaderType==-1) return;
        IWorkbenchPage page = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage();// obtain the active page
        String id = IConsoleConstants.ID_CONSOLE_VIEW;
        IConsoleView view;
        view = (IConsoleView) page.showView(id);
        view.display(compilerConsole);
        out.println("Compiling shader...");
        String errors=CompilerService.checkForErrors(shaderFile.getLocation().toString(),shaderType);
        if(errors.isEmpty()){
            out.println("No Errors occured.");
        }else{
            out.println(errors);
            Resource r=resourceSetProvider.get(shaderFile.getProject())
                    .getResource(URI.createURI(shaderFile.getFullPath().toString()), true);
            CompilerService.addErrorsToResource(errors, r);
    } catch (CompilerException | IOException | PartInitException e) {
        out.println("[Internal Error] "+e.getMessage());
    try {
        out.close();
    } catch (IOException e) {
        e.printStackTrace();
Re: Manually add errors to a resource [message #1406616 is a reply to message #1406587] Sun, 10 August 2014 12:16 Go to previous messageGo to next message
Resource.errors is a good place to put your model errors, but the
Eclipse UI is to use org.eclipse.core.resources.IMarker so you need to
maintain the markers or reuse some functionality that does so for you.
e.g org.eclipse.emf.validation.marker.MarkerUtil,
org.eclipse.emf.edit.ui.util.EditUIMarkerHelper
Ed Willink
> dont show up.
> final int line;
> this.line = line;
> @Override
> return message;
> @Override
> return resourceURI;
> @Override
> return line;
> @Override
> return 1;
> .skip(1)
> .filter(e->e!=null)
> .forEach(
> e->{
> try {
> the active page
> IConsoleView view;
> String
> }else{
> CompilerService.addErrorsToResource(errors, r); }
> try {
> out.close();
Re: Manually add errors to a resource [message #1407106 is a reply to message #1406616] Mon, 11 August 2014 18:22 Go to previous message
thank you for your help! Of course a nice feature like Resource.recreateMarkersFromErrors() would have been nicer Wink
this is my approach:
			}else{
				try {
					shaderFile.deleteMarkers(IMarker.PROBLEM, true, IResource.DEPTH_INFINITE);
					shaderFile.deleteMarkers("org.glsl.ui.glsl.check.fast", true, IResource.DEPTH_INFINITE);
					for(CompilerError error:CompilerService.getErrorList(errors)){
						IMarker marker = shaderFile.createMarker(IMarker.PROBLEM);
						marker.setAttribute("CODE_KEY", "org.glsl.compiler.error");
						marker.setAttribute("severity", IMarker.SEVERITY_ERROR);
						marker.setAttribute("charStart", 1+nthOccurrence(shaderSource,'\n',error.line-2));
						marker.setAttribute("charEnd", nthOccurrence(shaderSource,'\n',error.line-1));
						marker.setAttribute("location", "line: "+(error.line-1)+" "+shaderFile.getLocation());
						marker.setAttribute("lineNumber", error.line-1);
						marker.setAttribute("message", error.text);
						marker.setAttribute("URI_KEY", EcoreUtil.getURI(r.getContents().get(0)).toString());
						marker.setAttribute("FIXABLE_KEY", true);
				} catch (CoreException e1) {
					e1.printStackTrace();
everything works fine, except for one thing: when i click on the error indicator next to the line in the editor ill get the infamous "no more handles" exception...
Previous Topic:Trying to use types that are only imported via import statement
Next Topic:Serialization of xtext grammar models
Current Time: Wed Jul 23 02:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.04362 seconds
