Home » Modeling » Papyrus » How to listen to models being loaded?
How to listen to models being loaded? [message #1406934] Mon, 11 August 2014 09:20 Go to next message
What is the proper way to, from a plug-in, listen to and act upon a model being loaded in Papyrus 1.0, e.g. opened in the Model Explorer.
I assume there is some way to register a listener on models being loaded, but I cannot find the proper way to do so by studying the Papyrus source code.
Thanks in advance,
Thomas
Re: How to listen to models being loaded? [message #1406952 is a reply to message #1406934] Mon, 11 August 2014 09:59 Go to previous messageGo to next message
I think you can look IPapyrusListener to use with the extension point:
org.eclipse.papyrus.infra.core.modellistener
Gabriel
Re: How to listen to models being loaded? [message #1406978 is a reply to message #1406952] Mon, 11 August 2014 11:22 Go to previous messageGo to next message
Thanks for the quick answer but I get no notifications on model opening/loading.
I have implemented the IPapyrusListener interface and registered it into the org.eclipse.papyrus.infra.core.modellistener extension.
It will give me a lot of notifications when things are happening in a loaded model, but NOT any notification on the actual opening/loading of the model.
If I have an empty model without any profile applications, the registered listener will not give me any notifications at all when the model is opened/loaded.
Re: How to listen to models being loaded? [message #1406985 is a reply to message #1406978] Mon, 11 August 2014 11:44 Go to previous messageGo to next message
My second solution is to use IModeSnippet which is defined with the extension point :
To illustrate how use it, there is UmlSnippet. I think this is performed at model loading.
Gabriel
Re: How to listen to models being loaded? [message #1407271 is a reply to message #1406985] Tue, 12 August 2014 04:25 Go to previous messageGo to next message
Your second solution worked!
I am able to get hold of the model being loaded by implementing the IModelSnippet interface and using the proposed extension point.
Thanks!
/Thomas
Re: How to listen to models being loaded? [message #1409504 is a reply to message #1407271] Mon, 18 August 2014 05:20 Go to previous messageGo to next message
Hi Thomas,
Startup services might be more appropriate, as you can add dependencies, especially to the IMultiDiagramEditor service.
Models/ModelSnippets will be called for each model loaded in memory, which isn't necessarily related to opening an editor. For example, when using the Model Search on the workspace, models are loaded in-memory but not opened in an editor.
So, registering a startup service (via the org.eclipse.papyrus.infra.core.services extension point) with a dependency to the editor service (org.eclipse.papyrus.infra.core.editor.IMultiDiagramEditor) is probably the most reliable solution
Camille
Re: How to listen to models being loaded? [message #1410706 is a reply to message #1409504] Thu, 21 August 2014 08:30 Go to previous messageGo to next message
Thanks Camille,
Your solution works fine and probably even better than the previous one.
/Thomas
Re: How to listen to models being loaded? [message #1622812 is a reply to message #1410706] Wed, 18 February 2015 14:17 Go to previous messageGo to next message
Hi all,
can you tell me how you can get the opened ModelSet from the startup service?
Thanks in advance!
Re: How to listen to models being loaded? [message #1623789 is a reply to message #1622812] Thu, 19 February 2015 05:24 Go to previous messageGo to next message
When you implement the IService interface in Papyrus, you have the init() method which receives the current ServicesRegistry.
The ModelSet is registered as a service in the ServicesRegistry, so you can use the following code:
private ServicesRegistry servicesRegistry;
public void init(ServicesRegistry servicesRegistry) {
	this.servicesRegistry = servicesRegistry;
public void startService() throws ServiceException {
	ModelSet modelSet = servicesRegistry.getService(ModelSet.class); //Get the ModelSet service from the ServicesRegistry
	//Do something
Don't forget to add a dependency between your service and the ModelSet (This can be done in the service extension point)
Camille
Re: How to listen to models being loaded? [message #1691610 is a reply to message #1623789] Wed, 08 April 2015 09:07 Go to previous message
Thanks, Camille, this works great!
For the record, my plugin.xml looks like this:
<extension
         point="org.eclipse.papyrus.infra.core.service">
      <service
            classname="service.Service1"
            priority="1"
            startKind="startup">
         <dependsOn
               serviceKeyRef="org.eclipse.papyrus.infra.core.editor.IMultiDiagramEditor"></dependsOn>
         <dependsOn
               serviceKeyRef="org.eclipse.papyrus.infra.core.resource.ModelSet">
         </dependsOn>
      </service>
   </extension>
And the Service1 class:
		IMultiDiagramEditor diagramEditor = servicesRegistry.getService(IMultiDiagramEditor.class);
Previous Topic:Member End in association links in Use Case Diagrams
Next Topic:Problems while installing MARTE over Payrus
Current Time: Wed Jul 23 23:04:10 EDT 2025
Powered by FUDForum. Page generated in 0.06486 seconds
