RCP Designer (and Viewer) [message #1406804] |
Mon, 11 August 2014 02:18  |
After fiddling around a couple of hours to get my old version up...
i downloaded the latest version of birt (4.4) and will start from scratch.
i need to integrate both, birt viewer and designer into an RCP application.
i found the 'birt-rcp-report-designer-4_4_0-20140611' build on Birt webpage, which is nice, but i did not find a tutorial yet, how to get there.
so what do i need to get started? (i need an update site for the libaries, so i grabbed 'birt-updatesite-4_4_0-20140611')
but which (minimal set of) plugins do i need to get the designer running (and viewer)?
and finally i need to create a 'Custom Java report generator', which is mentioned like three times on the webpage, but i was not able to find an example by search&google (point me if you know one)
Thanks in Advance
Ludwig
NOTE: in the update site, it still says
- BIRT 4.2 Charting SDK
- BIRT 4.2 Engine OSGi Runtime SDK
- BIRT 4.2 Reporting SDK
- Birt 4.2 WTP Integration SDK
(whereat the version numbers are 4.4 inside...
FUDForum. Page generated in 0.04316 seconds
