Agent Controller - Unable to create named pipe [message #140638] |
Fri, 20 February 2009 19:07  |
I downloaded agent controller and followed instruction and configuration
as stated here
http://dev.eclipse.org/viewcvs/index.cgi/platform/org.eclips e.tptp.platform.agentcontroller/src-native-new/packaging_md/ windows/getting_started.html?root=TPTP_Project&view=co#C onfigure_Agent_Controller
Ran SetConfig.bat successfully which created serviceconfig.xml .
HOwever, when I Start the Agent Controller by changing my working
directory to <install-dir>\bin and running ACServer.exe, I get an error
stating
Error starting transport layers, Agent controller exiting.
See servicelog.log for error report.
Entries in servicelog.log are as follows:-
<CommonBaseEvent creationTime="2009-02-21T00:05:46.838000Z"
globalInstanceId="ACAA44B6D1AE4240A95961248F9B7318" msg="Unable to create
named pipe." severity="50" version="1.0.1">
<sourceComponentId component="AgentController"
componentIdType="TPTPComponent"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\transport\namedPipeTL\namedPipeListener.c,
line 1068" instanceId="1001" location="S027918" locationType="IPV4"
processId="2128" subComponent="Named Pipe TL" threadId="5744"
componentType="Eclipse_TPTP"/>
<situation categoryName="ReportSituation">
<situationType xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
</situation>
</CommonBaseEvent>
<CommonBaseEvent creationTime="2009-02-21T00:05:46.854000Z"
globalInstanceId="ADBA34FC7E90414FB09EAFB6A3A7DBF5" msg="An error was
returned from TransportLayer(1001)::startTransportLayer errNum = -1"
executionEnvironment=" C:\cygwin\home\build\TPTP\4.5.0\TPTP-4.5.0-200806200100\agnt ctrl\src\agentController\ConnectionManager.c,
line 263" instanceId="2" location="S027918" locationType="IPV4"
processId="2128" subComponent="Connection Manager" threadId="5744"
</situation>
</CommonBaseEvent>
I am using Windows XP. Any ideas please ??
Krishnaveni Krishnarajah
Re: Agent Controller - Unable to create named pipe [message #140752 is a reply to message #140638] |
Wed, 25 February 2009 20:27  |
> as stated here
> directory to <install-dir>bin and running ACServer.exe, I get an error
> stating
executionEnvironment=" C:cygwinhomebuildTPTP4.5.0TPTP-4.5.0-200806200100agntctrlsrc transportnamedPipeTLnamedPipeListener.c,
> </situation>
> </CommonBaseEvent>
executionEnvironment=" C:cygwinhomebuildTPTP4.5.0TPTP-4.5.0-200806200100agntctrlsrc agentControllerConnectionManager.c,
> </situation>
> </CommonBaseEvent>
Hi Krishnaveni, first, I would recommend killing an
ACServer.exe/RAServer.exe/ACWinService.exe/RAWinService.exe processes, as
well as any java.exe processes that are running on your system.
This problem usually occurs when another agent controller is already
installed (and is running) on the system.
If this doesn't not work, can you please provide the following information
about your environment:
- which version of the agent controller did you download?
- Which version on XP (64-bit/32-bit)?
- Are you running using an administrative account?
FUDForum. Page generated in 0.03461 seconds
