Home » Eclipse Projects » EGit / JGit » Latest EGit in Luna doesn't show filenames in commit dialog
Latest EGit in Luna doesn't show filenames in commit dialog [message #1404481] Fri, 01 August 2014 13:12 Go to next message
I just upgraded to Luna and EGit 3.4.1.20140620, and I can't see the file names in the dialog when I try to commit. Here's an example:
index.php/fa/18733/0/
I've tried uninstalling & reinstalling the plugin, to no avail. Any ideas?
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1404661 is a reply to message #1404481] Mon, 04 August 2014 15:12 Go to previous messageGo to next message
Chris Coslor skrev 2014-08-01 20.05:
Can you see any errors in the workspace log (Error view)?
Is there anything "unusual" about filenames or directory names.
-- robin
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1404665 is a reply to message #1404661] Mon, 04 August 2014 15:37 Go to previous messageGo to next message
I don't see anything germaine in the error log. There are various messages there, including Maven complaining about something or other, but when I cleared the log, restarted Eclipse, and did a team..commit, I didn't see any new messages.
I don't think there's anything especially unusual about the file names or path. One example is:
/home/coslor/git/maestro/src/test/java/com/rachio/maestro/service/WaterBudgetServiceTest.java
..so, no spaces or Unicode chars or anything like that.
I don't thik it's a permissions issue, either; the file above, for example, looks like this:
-rw-r--r-- 1 coslor coslor 9934 Aug 4 11:06 /home/coslor/git/maestro/src/test/java/com/rachio/maestro/service/WaterBudgetServiceTest.java
I was running Kepler before, and I didn't see this problem. It never remembered my Git logins, but at least it showed the files to be committed.
I'm running Linux Mint 16/Petra, BTW. Aby other ideas? I tried updating to the latest stable nightly, and it didn't seem to help.
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1404697 is a reply to message #1404665] Tue, 05 August 2014 03:17 Go to previous messageGo to next message
Is Eclipse installed under a path which needs elevated file system permissions ?
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1404768 is a reply to message #1404697] Tue, 05 August 2014 11:22 Go to previous messageGo to next message
Nope, it's just in my home directory. For good measure, I did try running Eclipse as root, but it didn't seem to make any difference for this issue.
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1404806 is a reply to message #1404768] Tue, 05 August 2014 17:23 Go to previous messageGo to next message
Are the paths of modified files shown in staging view ?
Then you could commit using staging view.
Any other views lacking text ?
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1405592 is a reply to message #1404806] Thu, 07 August 2014 14:07 Go to previous messageGo to next message
Problem solved! I was also having very frequent Eclipse crashes, so after some research I tried running with:
SWT_GTK3=0 eclipse
That not only solved my crashes, but this issue as well. Seems to have been a SWT problem.
Re: Latest EGit in Luna doesn't show filenames in commit dialog [message #1714088 is a reply to message #1405592] Mon, 09 November 2015 14:49 Go to previous message
I hit the same problem. The slightly more interesting solution might be:
You can add the following lines to eclipse.ini to make it permanent
--launcher.GTK_version
2
Source: http://forums.debian.net/viewtopic.php?t=115477
Previous Topic:Git Staging view enhancements to contribute
Next Topic:MAMP directory deleted on commit
Current Time: Sun Jul 27 09:57:52 EDT 2025
Powered by FUDForum. Page generated in 0.04363 seconds
