@PreDestroy for singletons [message #1405509] |
Thu, 07 August 2014 10:07  |
I have an E4 application with two parts. Only one part is shown at a time, such that part one will be destroyed when part two is shown, and vice versa.
Part one has a dependency to a Foo class which is injected into a @PostConstruct-annotated method in part one. The Foo class is annotated with @Creatable and @Singleton (as I want it to be a singleton).
I tracked the lifecycle of the Foo instance by checking when its @PostConstruct- and @PreDestroy-annotated methods are called. The findings were surprising to me. Switching between parts one and two gave me the following results:
Open part one:
Foo - PostConstruct
Open part two:
Foo - PreDestroy
Open part one again:
<nothing>
Open part two again:
<nothing>
So the Foo singleton instance is destroyed when part one is closed for the first time, but it is not constructed again when part one is opened for the second time. It must still exist since it is injected successfully into part one every time the part is constructed. But when the Foo instance still exists, how come the @PreDestroy method was called?
Could it be that an object is not destroyed after the @PreDestroy method was called? My understanding is that "destroy" means the instance does not exist any more, but I may be wrong. According to the E4 documentation, the object "is to be uninjected and released".
I'd appreciate your feedback.
Uwe
Re: @PreDestroy for singletons [message #1405530 is a reply to message #1405509] |
Thu, 07 August 2014 11:00   |
@PreDestroy means that the CONTEXT to which the object was attached to
was disposed.
I think the main problem is that @Createable creates an object on the
requesting context which is wrong for Singleton instances who should
most likely get created on the Root-Context and hence only haveing
access to the information in this root-context (==OSGi-ServiceRegistry)
I'm not a friend of this @Creatable all together and would advice to not
make use of it but better using IContextFunction and decide on what
level of the IEclipseContext the object is a singleton.
Tom
On 07.08.14 16:07, Uwe San wrote:
> vice versa.
> Open part one:
> Foo - PostConstruct
> Open part two:
> Foo - PreDestroy
> <nothing>
> <nothing>
> https://wiki.eclipse.org/Eclipse4/RCP/Dependency_Injection#.40PostConstruct.2C_.40PreDestroy_.28javax.annotation.29,
> Uwe
Re: @PreDestroy for singletons [message #1405541 is a reply to message #1405530] |
Thu, 07 August 2014 11:22  |
Thanks, Tom. That makes a lot of sense (and should be documented more explicitly somewhere, I think).
Using @Creatable in this case was meant to be a quick solution since, as you said, it is not the best approach for handling the objects in a part's context. I was then struck by the weird behaviour when combining @Creatable and @Singleton, but I suppose everything works as specified.
Uwe
FUDForum. Page generated in 0.24261 seconds
