Re: [EMF FORMS] Rule Based Enablement TreeMasterDetail View [message #1405531 is a reply to message #1405037] |
Thu, 07 August 2014 11:01  |
Hi Ranjeeth,
there is different options to tackle the problem you have been
describing over the course of this thread. Proposed solutions include
using a derived feature, the view model context and a custom condition
or preprocessing your view model before rendering to cut off view model
parts that are affected by access control rules. In the context of this
newsgroup and limited time I cannot judge which solution is the best
solution for your problem. To go further I can offer you professional
support (see signature) in case you would like to get detailed help with
finding a good solution very efficiently.
Maximilian
Maximilian Kögel
Get Professional EMFForms Support: http://eclipsesource.com/munich
Am 06.08.2014 14:23, schrieb Ranjeeth Rajendran:
> Hello Maximilian,
> Thanks you for your response.
> w.r.t the viewmodelcontext i think you are talking about current
> development stream BR ID: 441107
> Will the issue also address propagating something completely out of model?
> ex-
> I have a model say task.ecore and account.ecore, which are two different
> model completely independent and without any relationship with each others.
> account.ecore represents the security module for
> authentication/authorization
> task.ecore represents task system which is to be presented in UI, but
> will have to apply some rules based on the authorization/roles from
> account.ecore.
> Thank you,
> Ranjeeth
FUDForum. Page generated in 0.04463 seconds
