Home » Eclipse Projects » Nebula » Grid row height with image in last column
Grid row height with image in last column [message #1405003] Wed, 06 August 2014 06:59 Go to next message
I'm trying to use the Grid component to display an Image alongside some Text.
This works fine for me as long as the image is displayed anywhere except for the last column. However, if the image is in the last column, it's row is no longer resized to match the height of the image.
The AutoHeight property and WordWrap properties on all columns are set to true.
The following screenshots show an example of this problem:
index.php/fa/18799/0/index.php/fa/18800/0/
Thanks for any help,
Mirko
Re: Grid row height with image in last column [message #1407342 is a reply to message #1405003] Tue, 12 August 2014 07:29 Go to previous message
Looks like you caught one! Please file a bug against nebula/grid. If you want to supply a patch then please use Gerrit.
https://wiki.eclipse.org/Nebula/Contributions
Wim
Previous Topic:Whether modify the row number for other string(NatTable)
Next Topic:bug dataprovider of xygraph
Current Time: Sat Nov 22 16:18:14 EST 2025
Powered by FUDForum. Page generated in 0.06438 seconds
