Home » Eclipse Projects » Remote Application Platform (RAP) » Alpha of ImageData not working for RAP(Setting ImageData.alpha has no effect in RAP)
Alpha of ImageData not working for RAP [message #1404771] Tue, 05 August 2014 11:35 Go to next message
Alpha transparency for SWT ImageData does not appear to be supported by RAP.
In SWT I often used this to create a series of images with different alpha values in order to animate a fade-out or fade-in effect, but this has no effect in RAP (or Tabris in fact), and the image remains at 100% alpha.
My code is something like this:
Image alphaImage = ...;
ImageData alphaImageData = alphaImage.getImageData();
alphaImageData.alpha = desiredAlpha; // 0-255
Image adjustedAlphaImage = new Image(display, alphaImageData);
myLabel.setImage(adjustedAlphaImage);
Is this a known limitation of RAP, or is it a bug?
Thanks, John
Re: Alpha of ImageData not working for RAP [message #1404931 is a reply to message #1404771] Wed, 06 August 2014 03:14 Go to previous messageGo to next message
Hi John,
RAP is using SWT org.eclipse.swt.graphics.ImageLoader#save to make an
image file from image data. Could you try the same code in SWT, but
instead setting the image on the Label directly, save it to a file
(with ImageLoader). Is the output image transparent? See also:
438401: Image created from ImageData does not show up on a label
https://bugs.eclipse.org/bugs/show_bug.cgi?id=438401
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: Alpha of ImageData not working for RAP [message #1404950 is a reply to message #1404931] Wed, 06 August 2014 04:08 Go to previous message
That pointed me in the right direction...
PNG images are not saved with the alpha value for the overall image... only the alphaBytes[] array. Therefore, I've changed my logic to set the alphaBytes[] and don't touch alpha at all, and this works perfectly in RAP.
Thanks Ivan!
John
Previous Topic:RAP 2.3 and eclipse e4 single-sourced RCP (soft migrated)
Next Topic:FileUpload + Feedback
Current Time: Thu Jul 24 23:16:51 EDT 2025
Powered by FUDForum. Page generated in 0.04648 seconds
