3.1.2: StackOverflowError on creating/mod jobs [message #1248454] |
Mon, 17 February 2014 04:24  |
I am using hudson 3.1.1 on an ubuntu machine. After upgrading with the deb-file I am no longer able to create or modify existing jobs (type freestyle). I got the following error. Old maven2/3-job-type seems to work.
Setup Info:
jdk1.7.0_45
Hudson 3.1.2
Ubuntu wheezy (64 Bit)
Testet with an without memory options.
2014-02-17 09:11:08.213:WARN:oejs.ServletHandler:/job/VORLAGE02/configure
org.apache.commons.jelly.JellyTagException: jar:file:/var/lib/hudson/war/webapp/WEB-INF/lib/hudson-core-3.1.2.jar!/lib/form/drop
downDescriptorSelector.jelly:49:76: <st:include> java.lang.StackOverflowError
at org.apache.commons.jelly.impl.TagScript.handleException(TagScript.java:728)
at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:290)
at org.apache.commons.jelly.impl.ScriptBlock.run(ScriptBlock.java:95)
at org.kohsuke.stapler.jelly.CallTagLibScript$1.run(CallTagLibScript.java:90)
at org.apache.commons.jelly.tags.define.InvokeBodyTag.doTag(InvokeBodyTag.java:91)
at org.apache.commons.jelly.impl.TagScript.run(TagScript.java:270)
at org.apache.commons.jelly.TagSupport.invokeBody(TagSupport.java:186)
at org.apache.commons.jelly.tags.core.WhenTag.doTag(WhenTag.java:46)
at org.apache.commons.jelly.tags.core.ChooseTag.doTag(ChooseTag.java:38)
at org.apache.commons.jelly.tags.core.CoreTagLibrary$2.run(CoreTagLibrary.java:105)
at org.kohsuke.stapler.jelly.CallTagLibScript.run(CallTagLibScript.java:111)
at org.apache.commons.jelly.tags.core.ForEachTag.doTag(ForEachTag.java:150)
at org.kohsuke.stapler.jelly.ReallyStaticTagLibrary$1.run(ReallyStaticTagLibrary.java:91)
Maybe some problems with some Plugins? Here my list:
Build Pipeline Plugin 1.3.4-h-1
Hudson Translation Assistance plugin 1.10-h-1
Hudson REST Plugin 2.1.2
Groovy Support Plugin 3.0.3
Legacy Maven 2 job type Plugin 3.0.1
Hudson Dependency Viewer Plugin 1.1
Email-ext plugin 2.10
Run Condition Plugin 1.1-h-1
Promoted builds plugin 2.4-h-2
Active Directory plugin 1.31-h1
Hudson Subversion Plug-in 2.3.8-h-1
Hudson BIRT Charts Plugin 3.0.3
Hudson build timeout plugin 1.7-h-1
Performance plugin 1.8-h-1
Windows Slaves Plugin 1.0
Hudson Maven3 SNAPSHOT Monitor 3.0.1
Team Foundation Server Plugin 1.12
Compact Columns 1.10-h-1
VirtualBox Plugin 0.2.1
Hudson Maven3 Plugin 3.0.2
JFreeChart Plugin 1.5
Hudson CVS Plug-in 2.2.0
Hudson SSH Slaves plugin 3.0.2
Log Parser Plugin 1.0.8
Hudson Downstream build view 1.9-h-1
Hudson Parameterized Trigger plugin 2.17-h-1
Warnings Plug-in 4.23-h-1
Static Analysis Utilities 1.49-h-1
Backup plugin 3.0.0
Job Node Stalker 1.0.4-h-1
Dashboard View 2.9.2-h-1
XPath Provider Plugin 1.0.2
JNA Native Support Plugin 3.0.4
Sonar Plugin 2.0.1
Extended Read Permission Plugin 1.0
Subversion Tagging Plugin 1.17-h-1
Hudson JIRA plugin 1.36-h-1
Hudson Xvnc plugin 1.13-h-1
Token Macro Plugin 1.6-h-1
Xvfb plugin 1.0.9-h-1
Groovy Postbuild 1.9-h-2
Conditional Buildstep Plugin 1.3.2-h-1
ThinBackup 1.7.2-h-1
Node and Label parameter plugin 1.4.1-h-1
Thanks for helping
Denis
FUDForum. Page generated in 0.40530 seconds
