Home » Archived » Visual Editor (VE) » ImageDataCollector / ScreenScraping
ImageDataCollector / ScreenScraping [message #139420] Mon, 30 July 2007 11:19 Go to next message
hi all,
I would like to use VE ability to make a screenshot of a SWT composite
in my GMF Editor. When I looked at the implementation I noticed it is
very platform specific.
Basically I just need following method of
org.eclipse.ve.internal.swt.targetvm.ImageCapture:
protected abstract Image getImage(Control control, int maxWidth, int
maxHeight, boolean includeChildren);
even easier, "Image getImage(Control)" without children would be sufficient.
I found the OS branching stuff in
org.eclipse.ve.internal.swt.ImageDataCollector
looking like:
if (Platform.OS_WIN32.equals(Platform.getOS()))
dataCollectorType =
(...)("org.eclipse.ve.internal.swt.targetvm.win32.ImageCapture ");
else if (Platform.WS_GTK.equals(Platform.getWS())){
Is it a good approach to implement the branching stuff and copy the
three classes to make it work? (these classes are not exported in VE). I
also noticed that these classes are 2+ years old, is there already a
replacement?
Is it possible to do it this way? How would you suggest realizing it?
thanks & regards
stefan
Re: ImageDataCollector / ScreenScraping [message #140357 is a reply to message #139420] Thu, 13 September 2007 12:16 Go to previous messageGo to next message
"SKuhn" <kuhn@oio.de> wrote in message
news:f8kvis$10d$1@build.eclipse.org...
> hi all,
Have you looked at the SWT snippet for capturing screen images too?
It is not platform specific.
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet95. java
http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/org. eclipse.swt.snippets/src/org/eclipse/swt/snippets/Snippet215 .java
> looking like:
> dataCollectorType =
> replacement?
The code is 2 years old, but works. If that is what you need, copying and
branching is fine.
I would suggest that if you project is not open source you keep that
branched code in a separate bundle, so that you can release the forked
sources as per the EPL.
> thanks & regards
> stefan
Re: ImageDataCollector / ScreenScraping [message #140462 is a reply to message #140357] Thu, 13 September 2007 13:39 Go to previous messageGo to next message
This requires that Shell with GUI is visible on screen, so it will
flash and annoy user.
Re: ImageDataCollector / ScreenScraping [message #140493 is a reply to message #140462] Thu, 13 September 2007 14:21 Go to previous messageGo to next message
"Konstantin Scheglov" <kscheglov@gmail.com> wrote in message
news:fcbsjt$4ee$1@build.eclipse.org...
Would you know how to do it best then?
Re: ImageDataCollector / ScreenScraping [message #140504 is a reply to message #140493] Thu, 13 September 2007 23:13 Go to previous messageGo to next message
Solution in VE is good enough.
Yes, it is platform specific, but there are no other way.
Re: ImageDataCollector / ScreenScraping [message #140545 is a reply to message #140504] Fri, 14 September 2007 11:25 Go to previous messageGo to next message
news:fccu8f$t1d$1@build.eclipse.org...
Konstantin:
Would you know of a better solution than good enough?
Are ether flaws in the current one?
What could be improved?
(from googling your name you seem to know more than a thing or two on the
topic of visual editing, your help would matter a lot if you care for VE)
:-P
Re: ImageDataCollector / ScreenScraping [message #140568 is a reply to message #140545] Fri, 14 September 2007 12:57 Go to previous messageGo to next message
> Konstantin:
I have not looked in VE screen shot making precisely. I just know
that they use native code and it is known that ther are no other good
way. For Win32 you can use OS.SendMessage(), for Linux and Mac native
code is unavoidable.
In reallity screen shot making is the simplest part of WYSIWYG GUI
editor.
Contributing to VE [wa Re: ImageDataCollector / ScreenScraping] [message #140574 is a reply to message #140568] Sat, 15 September 2007 01:44 Go to previous message
news:fceehg$dot$1@build.eclipse.org...
the
VE)
> editor.
agreed, is there an area of interest wher you think you could help?
Re: ImageDataCollector / ScreenScraping [message #616513 is a reply to message #139420] Thu, 13 September 2007 12:16 Go to previous message
> hi all,
> looking like:
> dataCollectorType =
> replacement?
branching is fine.
> thanks & regards
> stefan
Re: ImageDataCollector / ScreenScraping [message #616542 is a reply to message #140357] Thu, 13 September 2007 13:39 Go to previous message
Re: ImageDataCollector / ScreenScraping [message #616549 is a reply to message #140462] Thu, 13 September 2007 14:21 Go to previous message
Re: ImageDataCollector / ScreenScraping [message #616550 is a reply to message #140493] Thu, 13 September 2007 23:13 Go to previous message
Re: ImageDataCollector / ScreenScraping [message #616556 is a reply to message #140504] Fri, 14 September 2007 11:25 Go to previous message
Konstantin:
:-P
Re: ImageDataCollector / ScreenScraping [message #616558 is a reply to message #140545] Fri, 14 September 2007 12:57 Go to previous message
> Konstantin:
editor.
Contributing to VE [wa Re: ImageDataCollector / ScreenScraping] [message #616559 is a reply to message #140568] Sat, 15 September 2007 01:44 Go to previous message
the
VE)
> editor.
Previous Topic:Anybody is extending VE ? we need your help!
Next Topic:How I can get Propertis ' name from java Class, we need your help!
Current Time: Sat Jul 26 21:15:13 EDT 2025
Powered by FUDForum. Page generated in 0.09498 seconds
