Home » Eclipse Projects » Remote Application Platform (RAP) » UI expands after changing the Language
UI expands after changing the Language [message #1404618] Mon, 04 August 2014 09:58 Go to next message
Hi Rappers,
I have an RAP application, which has 2 views (HomeView and ItemView). Both the views have a fixed size, so that the UI always fit inside the screen.
The HomeView has language setting, where I can choose between English and Swedish (NLS Strings). Then I can view the ItemView in the Selected Language.
When I switch from English to Swedish for the first time and the ItemView is loaded, the view gets expanded and does not fit into the screen. This problem is solved when I change the language again back to English and load the ItemView.
Only once, the same problem won't appear again even if I switch between the languages and load the ItemView.
Same kind of problem appears when i invoke pack() method on any UI element in the Views.
How can I get rid of these problems?
/Uma
[Updated on: Mon, 04 August 2014 10:02] by Moderator
Re: UI expands after changing the Language [message #1404699 is a reply to message #1404618] Tue, 05 August 2014 03:15 Go to previous message
it sounds like a text-size determination problem - view is resized to
+1000 with the new texts, but does not shrink back. Could you create a
simple test project to demonstrate the issue?
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Previous Topic:HOWTO: Installing Luna and RAP (e4!!!!!!!!!!)
Next Topic:RAP 2.3 and eclipse e4 single-sourced RCP (soft migrated)
Current Time: Thu Jul 24 22:09:39 EDT 2025
Powered by FUDForum. Page generated in 0.72748 seconds
