Home » Eclipse Projects » Eclipse Scout » RAP Button - content alignment
RAP Button - content alignment [message #1404443] Fri, 01 August 2014 08:34 Go to next message
how to align the content of a button (image + text) to a distinct direction e. g. left side. The property 'label position' seem not to work. I does not matter which value I use, the content is always centered. The button is inside a GroupBox and the property 'Fill Horizontal' is true.
In the attached image yout can see how I want to align the content.
Thanks in advance.
Re: RAP Button - content alignment [message #1404549 is a reply to message #1404443] Mon, 04 August 2014 02:57 Go to previous messageGo to next message
Hi Reinhold,
thanks for your question. Unfortunately, the alignment of the button seems to be hardcoded:
org.eclipse.scout.rt.ui.rap.form.fields.button.RwtScoutButton.initializeUi(Composite)
uiFieldAsButton = createSwtPushButton(m_menuMarkerComposite, SWT.CENTER | SWT.PUSH);
As for the moment there is no "easy" way to change the alignment. However it would be possible to override this "global" behaviour in a kind of workaround. If you are interested in the workaround, let me know. Otherwise you could create a new bug and specify it as "enhancement".
Hope this helps,
Matthias
Re: RAP Button - content alignment [message #1404557 is a reply to message #1404549] Mon, 04 August 2014 03:46 Go to previous messageGo to next message
Hi Matthias,
thank you for the fast reply!
So the "global" workaround would mean, that I could only set a distinct aligment for all buttons in the application and not for each?
But I am interested anyway.
Thanks in advance.
Reinhold.
Re: RAP Button - content alignment [message #1404573 is a reply to message #1404557] Mon, 04 August 2014 05:11 Go to previous messageGo to next message
Hi Reinhold,
below I describe a solution where it is possible to set the alignment of a button's content (Left, Center, Right). This is not a global solution, but can be configured from button to button individually.
1) I created the a button and misused the getConfiguredLabelPosition property:
    @Order(30.0)
    public class DownloadButton extends AbstractButton {
      protected boolean getConfiguredFillHorizontal() {
        return true;
      protected boolean getConfiguredProcessButton() {
        return false;
      protected int getConfiguredGridW() {
        return 8;
      protected String getConfiguredLabel() {
        return TEXTS.get("Download");
       * Misuse property for Button alignment
       * -1 = left
       * 0 = center
       * 1 = right
      protected int getConfiguredLabelPosition() {
        return 1;
2) Go to your rap bundle: <your project>.ui.rap
2.1) Create the following file
public class RwtScoutAlignedButton extends RwtScoutButton<IButton> {
  protected ButtonEx createSwtPushButton(Composite container, int style) {
    style = SWT.PUSH;
    if (getScoutObject().getLabelPosition() == -1) {
      style |= SWT.LEFT;
    else if (getScoutObject().getLabelPosition() == 0) {
      style |= SWT.CENTER;
    else {
      style |= SWT.RIGHT;
    return super.createSwtPushButton(container, style);
Here, we can react on the property we set on our Button
2.2) Create the following file
public class MyButtonFieldFactory extends ButtonFieldFactory {
  protected IRwtScoutButton<IButton> createRwtScoutButton() {
    return new RwtScoutAlignedButton();
3) Now, open the plugin.xml in the <your project>.ui.rap bundle, click on "Add..." and add a new 'org.eclipse.scout.rt.ui.rap.formfields' extension. Create a new formField, and set the modelClass to 'org.eclipse.scout.rt.client.ui.form.fields.button.IButton', 'active' to 'true' and 'scope' to 'global'.
index.php/fa/18739/0/
4) Create a new uiFactory below the new entry, which references your MyButtonFieldFactory
index.php/fa/18740/0/
Now you can set the alignment of the Button with the following code:
       * -1 = left
       * 0 = center
       * 1 = right
        return 1;
As you can see, you can now change the default alignment. But notice, this solution only applies to RAP in the moment. SWT and Swing will still align the button centered, however you can use the same strategy to change the alignment. However If you really need this feature I would recommend to create a change request.
index.php/fa/18741/0/
  • Attachment: plugin1.png
    (Size: 43.59KB, Downloaded 426 times)
  • Attachment: plugin2.png
    (Size: 32.14KB, Downloaded 435 times)
  • Attachment: result.png
    (Size: 4.63KB, Downloaded 392 times)
[Updated on: Mon, 04 August 2014 05:13] by Moderator
Re: RAP Button - content alignment [message #1404581 is a reply to message #1404573] Mon, 04 August 2014 05:47 Go to previous message
Thank you very much!!!
Previous Topic:Renaming and plugin.xml
Next Topic:Dynamic form width
Current Time: Thu Jul 24 22:30:03 EDT 2025
Powered by FUDForum. Page generated in 0.28339 seconds
