Home » Newcomers » Newcomers » Having trouble with launching Ecliplse .log file(An error has occurred. See the log file.)
Having trouble with launching Ecliplse .log file [message #1404145] Tue, 29 July 2014 19:17 Go to next message
I've been searching around and seen several different solutions but unfortunately none of them worked for me to get my Eclipse up and running. I am new here and it was working yesterday perfectly but I'm guessing when I closed it yesterday it might have somehow gotten corrupted. If you could point me in the right direction I'd very much appreciate it Smile! Here is some of the things I've tried so far based on other thread solutions that worked for others:
Changed SHOW_WORKSPACE_SELECTION_DIALOG=false (to true to see if a new workspace would resolve issue but it did not)
Tried adding -clean to the beginning of the eclipse.ini that did not work as well.
Tried finding any .snap files from the .plugins\org.eclipse.core.resources\ but I did not see any to delete.
Tried reinstalling the jdk and that didn't work
Tried to delete and fresh install Eclipse to see if that would work and it didn't either.
Thank you for your time and help!!
Here is the information from my .log file:
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.7.0_45
!ENTRY org.eclipse.osgi 4 0 2014-07-29 23:16:09.198
!MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: C:\Users\Zach\Desktop\eclipse\configuration\org.eclipse.osgi
!ENTRY org.eclipse.jdt.annotation 2 0 2014-07-29 23:16:14.210
!MESSAGE Could not resolve module: org.eclipse.jdt.annotation [190]
Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.Cool)"
!ENTRY org.eclipse.osgi 4 0 2014-07-29 23:16:14.220
!MESSAGE Application error
!STACK 1
org.eclipse.e4.core.di.InjectionException: java.lang.InternalError
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:114)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:502)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:210)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
Caused by: java.lang.InternalError
at java.util.Currency$1.run(Unknown Source)
at java.util.Currency.<clinit>(Unknown Source)
at java.text.DecimalFormatSymbols.initialize(Unknown Source)
at java.text.DecimalFormatSymbols.<init>(Unknown Source)
at java.text.DecimalFormatSymbols.getInstance(Unknown Source)
at java.text.NumberFormat.getInstance(Unknown Source)
at java.text.NumberFormat.getIntegerInstance(Unknown Source)
at java.text.SimpleDateFormat.initialize(Unknown Source)
at java.text.SimpleDateFormat.<init>(Unknown Source)
at org.eclipse.osgi.internal.debug.EclipseDebugTrace.<clinit>(EclipseDebugTrace.java:51)
at org.eclipse.osgi.internal.debug.FrameworkDebugOptions.newDebugTrace(FrameworkDebugOptions.java:404)
at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.setDebugOptions(WorkbenchLogger.java:137)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
... 23 more
Caused by: java.io.FileNotFoundException: C:\Windows\jre\lib\currency.data (The system cannot find the file specified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.<init>(Unknown Source)
... 42 more
Re: Having trouble with launching Ecliplse .log file [message #1404225 is a reply to message #1404145] Wed, 30 July 2014 10:41 Go to previous messageGo to next message
On Tue, 29 Jul 2014 19:30:25 -0400, Zach Prince wrote:
> I've been searching around and seen several different solutions but unfortunately none of them worked for me to get my Eclipse up and running. I am new here and it was working yesterday perfectly but I'm guessing when I closed it yesterday it might have somehow gotten corrupted. If you could point me in the right direction I'd very much appreciate it :)! Here is some of the things I've tried so far based on other thread solutions that worked for others:
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.8))"
> !STACK 1
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at java.security.AccessController.doPrivileged(Native Method)
> ... 23 more
> ... 42 more
I would rename the eclipse folder to eclipse.bak then unpack a new
eclipse folder from the file you originally downloaded
or even get the latest from the Eclipse Downloads site.
Then before running it, I'd run:
java -version
Make sure that looks correct (an actual JDK and version you intended) then run:
where java.exe
Make sure the one that is running is the one you think is running.
Then run:
set
Look for the PATH and JAVA_HOME (if set) to make sure they
look right.
Dilton
Re: Having trouble with launching Ecliplse .log file [message #1404255 is a reply to message #1404225] Wed, 30 July 2014 13:12 Go to previous messageGo to next message
Or, just read the Announcement post at the top of this forum titled, "Trouble getting Eclipse to run? READ THIS FIRST"
Re: Having trouble with launching Ecliplse .log file [message #1404273 is a reply to message #1404255] Wed, 30 July 2014 15:40 Go to previous messageGo to next message
I'm PARTICIPATING IN the forum using the PAN USENET newsreader,
there is no "forum" that participants such as us see.
Re: Having trouble with launching Ecliplse .log file [message #1404274 is a reply to message #1404273] Wed, 30 July 2014 15:48 Go to previous messageGo to next message
That's unfortunate, but I guess an inherent limitation of the forum<->NNTP bridge. Here's the link to the message I'm referring to: https://www.eclipse.org/forums/index.php/t/198527/
Basically, use eclipse.ini, don't set JAVA_HOME (Eclipse ignores it anyway) or PATH.
Re: Having trouble with launching Ecliplse .log file [message #1404495 is a reply to message #1404274] Fri, 01 August 2014 21:03 Go to previous message
Thank you both very much for your time, I did get it to run after reading what Dilon posted I do apologize as I did not see such a thread. Again thank you! Have a great day!
Previous Topic:XML Version
Next Topic:#define sections of code are highlighted
Current Time: Sun Jul 27 02:00:18 EDT 2025
Powered by FUDForum. Page generated in 0.08725 seconds
