UI required when launching mwe2 headlessly? [message #1404393] |
Thu, 31 July 2014 18:43  |
I'm trying to set up a headless configuration where I launch an mwe2 workflow. I'm not able to do so without involving a large number of UI plug-ins in my setup. The bundle marks them as optional but I get the exception below when I launch.
I know I can make it work by adding the UI bundles but I would like to avoid that. Is there some configuration option that can be set to avoid it?
java.lang.NoClassDefFoundError: org/eclipse/debug/ui/RefreshTab
at org.eclipse.emf.mwe2.launch.shortcut.Mwe2LaunchDelegate$1$1.run(Mwe2LaunchDelegate.java:38)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: java.lang.ClassNotFoundException: org.eclipse.debug.ui.RefreshTab cannot be found by org.eclipse.emf.mwe2.launch_2.6.0.v201405200939
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
at java.lang.ClassLoader.loadClass(ClassLoader.java:358)
FUDForum. Page generated in 0.04843 seconds
