RAP Button - content alignment [message #1404443] |
Fri, 01 August 2014 08:34  |
how to align the content of a button (image + text) to a distinct direction e. g. left side. The property 'label position' seem not to work. I does not matter which value I use, the content is always centered. The button is inside a GroupBox and the property 'Fill Horizontal' is true.
In the attached image yout can see how I want to align the content.
Thanks in advance.
Re: RAP Button - content alignment [message #1404573 is a reply to message #1404557] |
Mon, 04 August 2014 05:11   |
Hi Reinhold,
below I describe a solution where it is possible to set the alignment of a button's content (Left, Center, Right). This is not a global solution, but can be configured from button to button individually.
1) I created the a button and misused the getConfiguredLabelPosition property:
@Order(30.0)
public class DownloadButton extends AbstractButton {
protected boolean getConfiguredFillHorizontal() {
return true;
protected boolean getConfiguredProcessButton() {
return false;
protected int getConfiguredGridW() {
return 8;
protected String getConfiguredLabel() {
return TEXTS.get("Download");
* Misuse property for Button alignment
* -1 = left
* 0 = center
* 1 = right
protected int getConfiguredLabelPosition() {
return 1;
2) Go to your rap bundle: <your project>.ui.rap
2.1) Create the following file
public class RwtScoutAlignedButton extends RwtScoutButton<IButton> {
protected ButtonEx createSwtPushButton(Composite container, int style) {
style = SWT.PUSH;
if (getScoutObject().getLabelPosition() == -1) {
style |= SWT.LEFT;
else if (getScoutObject().getLabelPosition() == 0) {
style |= SWT.CENTER;
else {
style |= SWT.RIGHT;
return super.createSwtPushButton(container, style);
Here, we can react on the property we set on our Button
2.2) Create the following file
public class MyButtonFieldFactory extends ButtonFieldFactory {
protected IRwtScoutButton<IButton> createRwtScoutButton() {
return new RwtScoutAlignedButton();
3) Now, open the plugin.xml in the <your project>.ui.rap bundle, click on "Add..." and add a new 'org.eclipse.scout.rt.ui.rap.formfields' extension. Create a new formField, and set the modelClass to 'org.eclipse.scout.rt.client.ui.form.fields.button.IButton', 'active' to 'true' and 'scope' to 'global'.
4) Create a new uiFactory below the new entry, which references your MyButtonFieldFactory
Now you can set the alignment of the Button with the following code:
* -1 = left
* 0 = center
* 1 = right
return 1;
As you can see, you can now change the default alignment. But notice, this solution only applies to RAP in the moment. SWT and Swing will still align the button centered, however you can use the same strategy to change the alignment. However If you really need this feature I would recommend to create a change request.
Attachment: plugin1.png
(Size: 43.59KB, Downloaded 428 times)
Attachment: plugin2.png
(Size: 32.14KB, Downloaded 437 times)
Attachment: result.png
(Size: 4.63KB, Downloaded 394 times)
[Updated on: Mon, 04 August 2014 05:13] by Moderator
FUDForum. Page generated in 0.04315 seconds
