Home » Modeling » Epsilon » XSD to EMF(Model instance not persisting)
XSD to EMF [message #484564] |
Tue, 08 September 2009 05:25  |
Hi all,
I followed this tutorial ( http://help.eclipse.org/help33/index.jsp?topic=/org.eclipse. emf.doc/tutorials/xlibmod/xlibmod.html) to create an EMF model from an XSD. I didn't want a custom editor or anything so stopped after that.
I have my ecore file sitting happily in my project and I register the EPackage, which works fine. I then create an Epsilon EMF Model from the wizard, choosing my newly registered EPackage as the metamodel uri. The model file is created fine, and I can add the expected elements into the model. However, these elements do not persist once the file is closed and reopened - leaving just the root node and no child nodes.
Creating a model instance of a pre-registered metamodel (such as UML2) works fine. Is there possibly something wrong with the way the XSD is transformed. Maybe this should go into the EMF forum?
The XSD is here: http://czt.sourceforge.net/zml/zml/Z_2_1.xsd
James
Re: XSD to EMF [message #484581 is a reply to message #484577] |
Tue, 08 September 2009 07:06   |
Hi James,
Thanks for the update. I'll give the xsd a go and get back to you.
Dimitris
James Williams wrote:
> Hi Dimitris,
> When opening it with the Sample Reflective Ecore Model Editor (as either
> .xmi or .ecore), I get the following (trimmed as they were massive) errors:
> Quote:
>> org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos
>> ticWrappedException:
>> org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'zSect'
>> not found. (platform:/resource/ZML/model/birthdaybook.xmi, 3, 43)
>> at ........
> and
> Quote:
>> at ........
> Cheers,
> James
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: XSD to EMF [message #484586 is a reply to message #484581] |
Tue, 08 September 2009 07:32   |
Just so as not to leave this thread hanging. This has been resolved
off-line and the short story is that when creating a model from an Ecore
that has been generated from an XSD, in the New EMF Model wizard of
Epsilon, you should select DocumentRoot as the Root Instance type and
add all other objects below that.
Dimitris
Dimitris Kolovos wrote:
> Hi James,
> Cheers,
> Dimitris
>> Hi Dimitris,
>> either .xmi or .ecore), I get the following (trimmed as they were
>> massive) errors:
>> Quote:
>>> at ........
>> and
>> Quote:
>>> at ........
>> Cheers,
>> James
Re: XSD to EMF [message #580480 is a reply to message #580442] |
Hi James,
Dimitris
> Hi Dimitris,
> Quote:
>> at ........
> and
> Quote:
>> at ........
> Cheers,
> James
Re: XSD to EMF [message #580492 is a reply to message #484581] |
Dimitris
> Hi James,
> Cheers,
> Dimitris
>> Hi Dimitris,
>> massive) errors:
>> Quote:
>>> at ........
>> and
>> Quote:
>>> at ........
>> Cheers,
>> James
Re: XSD to EMF [message #1404043 is a reply to message #484586] |
Tue, 29 July 2014 06:01   |
I'd like to pick up this thread as I've got the same feature not found exception.
I get it due to upper case letters in XML tags, while loading a XML instance for an ecore model.
Starting from a very simple XML Scheme File MyXSD.xml
<xs:schema xmlns="MyXSD" xmlns:xs="..." elementFormDefault="qualified" targetNamespace="MyXSD">
<xs:element name="Document" type="Document"/>
<xs:complexType name="Document">
<xs:sequence>
<xs:element name="FirstElem" type="Max10Text"/>
<xs:element name="SecondElem" type="Max20Text"/>
</xs:sequence>
</xs:complexType>
<xs:simpleType name="Max10Text"> ... </xs:simpleType>
<xs:simpleType name="Max20Text"> ... </xs:simpleType>
</xs:schema>
I have got ecore and genmodel, generated editors and everything works fine.
By ANT script, I register my ecore model and I try to load the following XML instance in Epsilon:
<Document xmlns="MyXSD" xmlns:xsi="...">
<FirstElem>FirstElem</FirstElem>
<SecondElem>SecondElement</SecondElem>
</Document>
At this step, I get a feature not found exception "Caused by: org.eclipse.emf.ecore.xmi.FeatureNotFoundException: Feature 'FirstElem' not found."
Changing the first letter of inner element tags from upper case to lower case, loading of this instance succeeds.
<firstElem>FirstElem</firstElem>
<secondElem>SecondElement</secondElem>
</Document>
Exceed editor and Eclipse Validation, of course, accept the first version of this file and complain about the second version with lower case letters.
May be, I am missing some parameter for loading the XML instance or any other detail?
Do you need any additional information?
Thanks in advance,
Gerd
eclipse-epsilon-1.1_SR1-win32-x86_64
Windows 7 64 bit with Java 1.7 update 60
Current Time: Sun Jul 20 21:22:08 EDT 2025
Powered by FUDForum. Page generated in 0.08697 seconds
