Home » Modeling » EMF » [CDO] Old class cast exception resurfaces(A CDO classcastexception fixed in 2012 rises again, maybe?)
[CDO] Old class cast exception resurfaces [message #1339141] Wed, 07 May 2014 10:37 Go to next message
We have some code that Exports our repo model into an xmi file. But in some cases it throws this exception
[ERROR 2014-05-07 15:30:36.945 BST] main:com.yambina.edm.core.utils.ErrorUtils - Failed to export to file:/Users/david/workspace/fullmodeltest.xmi
	at org.eclipse.jface.operation.ModalContext.run(ModalContext.java:421)
	at org.eclipse.jface.dialogs.ProgressMonitorDialog.run(ProgressMonitorDialog.java:507)
	at com.yambina.edm.validation.ExportCommandHandler.execute(ExportCommandHandler.java:54)
	at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
	at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:90)
	at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
	at java.lang.reflect.Method.invoke(Method.java:606)
	at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:243)
	at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:224)
	at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:132)
	at org.eclipse.e4.core.commands.internal.HandlerServiceHandler.execute(HandlerServiceHandler.java:167)
	at org.eclipse.core.commands.Command.executeWithChecks(Command.java:499)
	at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
	at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:213)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:850)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:743)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:727)
	at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:662)
	at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4166)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1466)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1489)
	at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1474)
	at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1279)
	at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3651)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1113)
	at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:997)
	at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:140)
	at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:611)
	at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:567)
	at com.yambina.mdwmui.MDWMUIApplication.start(MDWMUIApplication.java:44)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: org.eclipse.net4j.signal.RemoteException: java.lang.ClassCastException: org.eclipse.emf.cdo.common.revision.CDORevisionUtil$Uninitialized cannot be cast to org.eclipse.emf.cdo.common.id.CDOID
	at org.eclipse.net4j.signal.RequestWithConfirmation.getRemoteException(RequestWithConfirmation.java:141)
	at org.eclipse.net4j.signal.RequestWithConfirmation.setRemoteException(RequestWithConfirmation.java:130)
	at org.eclipse.net4j.signal.SignalProtocol.handleRemoteException(SignalProtocol.java:465)
	at org.eclipse.net4j.signal.RemoteExceptionIndication.indicating(RemoteExceptionIndication.java:66)
	at org.eclipse.net4j.signal.Indication.doExtendedInput(Indication.java:57)
	at org.eclipse.net4j.signal.Signal.doInput(Signal.java:328)
	at org.eclipse.net4j.signal.Indication.execute(Indication.java:51)
	at org.eclipse.net4j.signal.Signal.runSync(Signal.java:253)
	at org.eclipse.net4j.signal.Signal.run(Signal.java:149)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
	at java.lang.Thread.run(Thread.java:724)
Caused by: java.lang.ClassCastException: org.eclipse.emf.cdo.common.revision.CDORevisionUtil$Uninitialized cannot be cast to org.eclipse.emf.cdo.common.id.CDOID
	at org.eclipse.emf.cdo.internal.common.model.CDOTypeImpl$11.writeValue(CDOTypeImpl.java:242)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.LoadChunkIndication.responding(LoadChunkIndication.java:106)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerIndication.responding(CDOServerIndication.java:134)
	at org.eclipse.net4j.signal.IndicationWithResponse.doExtendedOutput(IndicationWithResponse.java:98)
	at org.eclipse.net4j.signal.Signal.doOutput(Signal.java:298)
	at org.eclipse.net4j.signal.IndicationWithResponse.execute(IndicationWithResponse.java:67)
	at org.eclipse.emf.cdo.server.internal.net4j.protocol.CDOServerReadIndication.execute(CDOServerReadIndication.java:36)
I saw this was fixed here https://bugs.eclipse.org/bugs/show_bug.cgi?id=369646
But not clear to me if this is different or the same cause. I am using V4.2.1 of org.eclipse.emf.cdo.server.db in Kepler SR2 using H2, on Java 7 - /Library/Java/JavaVirtualMachines/jdk1.7.0_25.jdk/Contents/Home/bin/../jre/lib/server/libjvm.dylib
i.e. A Mac
Here is the code that does the clone prior to the export, it does not return from this method, but the ClassCastException is not caught in it either?
    private void clone(final Collection<EObject> eObjects, final IProgressMonitor monitor) throws InvocationTargetException {
        SubMonitor subMonitor = SubMonitor.convert(monitor, eObjects.size());
        Object value = null;
        try {
            for (EObject eObject : eObjects) {
                EObject eObjectClone = EDMModelFactory.eINSTANCE.create(eObject.eClass());
                this.clones.put(eObject, eObjectClone);
                for (EAttribute attribute : eObjectClone.eClass().getEAllAttributes()) {
                    if (!attribute.isDerived()) {
                        eObjectClone.eSet(attribute, eObject.eGet(attribute));
                Collection<EObject> children = new ArrayList<EObject>();
                for (EReference reference : eObjectClone.eClass().getEAllContainments()) {
                    try {
                        value = eObject.eGet(reference);
                        if (reference.isMany()) {
                            children.addAll((Collection<EObject>) value);
                        } else {
                            CollectionUtils.addIgnoreNull(children, value);
                    } catch (ObjectNotFoundException ex) {
                        //TODO: Remove eObject and all references to it.
                        throw new InvocationTargetException(ex, NLS.bind("{0}#{1} contains an object that can't be found", Utils.getFullyQualifiedName(eObject), reference.getName())); //$NON-NLS-1$
                this.clone(children, subMonitor.newChild(1));
        } catch (ClassCastException cce) {
        	LogPlugin.error(LOG, true, "{0} is not initialized", value.toString()); //$NON-NLS-1$
        } finally {
            if (monitor != null) {
                monitor.done();
Not clear exactly where it fails as it is a large model so cannot single step it and it does not do the catch where I added the ClassCastException in the code above. Any pointers?
[Updated on: Wed, 07 May 2014 10:38] by Moderator
Re: [CDO] Old class cast exception resurfaces [message #1343344 is a reply to message #1339141] Fri, 09 May 2014 04:41 Go to previous messageGo to next message
This might help I set a breakpoint on ClassCastException and found it in my CDOServer implementation..
Daemon Thread [net4j-Thread-3] (Suspended (exception ClassCastException))
	CDOTypeImpl$11.writeValue(CDODataOutput, Object) line: 242
	LoadChunkIndication.responding(CDODataOutput) line: 106
	LoadChunkIndication(CDOServerIndication).responding(ExtendedDataOutputStream) line: 134
	LoadChunkIndication(IndicationWithResponse).doExtendedOutput(ExtendedDataOutputStream) line: 98
	LoadChunkIndication(Signal).doOutput(BufferOutputStream) line: 298
	LoadChunkIndication(IndicationWithResponse).execute(BufferInputStream, BufferOutputStream) line: 67
	LoadChunkIndication(CDOServerReadIndication).execute(BufferInputStream, BufferOutputStream) line: 36
	LoadChunkIndication(Signal).runSync() line: 253
	LoadChunkIndication(Signal).run() line: 149
	ThreadPoolExecutor.runWorker(ThreadPoolExecutor$Worker) line: 1145
	ThreadPoolExecutor$Worker.run() line: 615
	Thread.run() line: 724
Re: [CDO] Old class cast exception resurfaces [message #1368958 is a reply to message #1343344] Tue, 20 May 2014 07:00 Go to previous messageGo to next message
Is my question so stupid no one wants to answer it? Or is it so difficult no one can?
Re: [CDO] Old class cast exception resurfaces [message #1384248 is a reply to message #1368958] Wed, 28 May 2014 10:08 Go to previous messageGo to next message
I can reproduce this problem using the CDO Explorer perspective in the CDO Sessions view by trying to open the resource in an active transaction in the CDO Editor
	... 5 more
What worries me is this happens quite frequently with CDO, for the last few years. I don't know how the repos end up in this state, which is the worrying thing.
Re: [CDO] Old class cast exception resurfaces [message #1397916 is a reply to message #1384248] Thu, 10 July 2014 06:41 Go to previous messageGo to next message
Bump.
Maybe someone who reads this can guide me on how we determine the cause of this exception.
Starting to wish we had not used CDO as we consistently get this issue in using the Db Store.
We also consistently get another issue when trying to export models to XML. Neither has ever been resolved and as you can see above no one has clue so far, or can't be bother to answer the question.
Re: [CDO] Old class cast exception resurfaces [message #1402966 is a reply to message #1397916] Fri, 18 July 2014 16:31 Go to previous messageGo to next message
On 10-07-14 12:41, David Wynter wrote:
> Bump.
> of this exception.
Hi David,
As you can see Eike is not very present on the forum lately. Any chance
you can debug/reproduce the problem yourself? It's new for me. (I use
CDO extensively).
Cheers CHristophe
Re: [CDO] Old class cast exception resurfaces [message #1403198 is a reply to message #1402966] Tue, 22 July 2014 06:16 Go to previous messageGo to next message
Christophe can you drop me an email to my gmail account. My user name is stpdave there. I will have to share a rather large, and private repo with you that exhibits the issue of the corrupt repo with the class cast exception. I will also add a JUnit test case, assume you have a CDO Server implementation to connect to the H2 repo I supply.
Thx
David
[Updated on: Tue, 22 July 2014 08:51] by Moderator
Re: [CDO] Old class cast exception resurfaces [message #1403264 is a reply to message #1403198] Tue, 22 July 2014 12:52 Go to previous messageGo to next message
I now have a JUnit test case and repo that have the problem. The repo is 140MB so need to share via a google drive.
    private CDONet4jSession session;
    private CDOTransaction transaction;
    private final Map<EObject, EObject> clones = new HashMap<EObject, EObject>();
	@Before
	public void setUp() throws Exception {
            IManagedContainer container = ContainerUtil.createContainer();
            Net4jUtil.prepareContainer(container);
            TCPUtil.prepareContainer(container);
            CDONet4jUtil.prepareContainer(container);
            container.activate();
            IConnector connector = Net4jUtil.getConnector(container, url);
            CDONet4jSessionConfiguration sessionConfiguration = CDONet4jUtil.createNet4jSessionConfiguration();
            sessionConfiguration.setConnector(connector);
            sessionConfiguration.setRepositoryName(repo);
            PasswordCredentialsProvider credentialsProvider = new PasswordCredentialsProvider(login, password);
            sessionConfiguration.setCredentialsProvider(credentialsProvider);
            try {
                this.session = sessionConfiguration.openNet4jSession();
                session.options().setGeneratedPackageEmulationEnabled(true);
                this.transaction = this.session.openTransaction();
            } catch (Exception ex) {
        	throw new SessionException(url, login, password, repo, ex);
	@After
	public void tearDown() throws Exception {
            if (this.transaction != null) {
                this.transaction.commit();
                this.transaction.close();
                this.transaction = null;
            if (this.session != null) {
                this.session.close();
                this.session = null;
	@Test
	public void test() {
            CDOResource resource = this.transaction.getResource("resTR");
            EList<EObject> contents = resource.getContents();
            this.clone(contents);
	    assert(clones.size()>0);
	private void clone(Collection<EObject> children2) {
	    for (EObject eObject : children2) {
	            try {
	                Object value = eObject.eGet(reference);
	                } else {
	        this.clone(children);
Any takers?
[Updated on: Wed, 23 July 2014 05:41] by Moderator
Re: [CDO] Old class cast exception resurfaces [message #1404031 is a reply to message #1403264] Tue, 29 July 2014 05:09 Go to previous messageGo to next message
Hi David,
Propose you put this in a new Bug and refer to the other bug you
mentioned earlier. Also mention clearly what you observe. ("The problem"
is not enough). People like to see the concise/complete issue in one go,
not spread over multiple emails please. For example, I don't see how
this test case relates to the exception you wrote earlier about.
On the Repo, it might not be needed considering it's size, but if can
provide the details of your configuration, (the cdo-server.xml),the CDO
build you use, also the DB you use, which version etc... could prove
handy. Perhaps also mention your model and EPackages, is it legacy, have
you converted it to CDO?
I notice this:
I never have to set this, but it might be there for a reason? Not sure
what it does.
I also notice in your clone method, you don't really clone (make a
copy), but move objects to the new destination. For Containment
references, this implies the object will not be in the source resource
anymore.
Thank You,
Christophe
> EObject>();
> @Before
> try {
> @After
> @Test
> try {
> } else {
> Any takers?
Re: [CDO] Old class cast exception resurfaces [message #1404033 is a reply to message #1403264] Tue, 29 July 2014 05:15 Go to previous messageGo to next message
One more thing, I propose you use the ECoreUtil.Copier method to create
your clone. To rule out your implementation is the culprit.
> EObject>();
> @Before
> try {
> @After
> @Test
> try {
> } else {
> Any takers?
Re: [CDO] Old class cast exception resurfaces [message #1404040 is a reply to message #1404031] Tue, 29 July 2014 05:46 Go to previous messageGo to next message
Am 29.07.2014 11:09, schrieb Christophe Bouhier:
> Hi David,
> Propose you put this in a new Bug and refer to the other bug you mentioned earlier. Also mention clearly what you
> observe. ("The problem" is not enough). People like to see the concise/complete issue in one go, not spread over
> multiple emails please. For example, I don't see how this test case relates to the exception you wrote earlier about.
> On the Repo, it might not be needed considering it's size, but if can provide the details of your configuration, (the
> cdo-server.xml),the CDO build you use, also the DB you use, which version etc... could prove handy. Perhaps also
> mention your model and EPackages, is it legacy, have you converted it to CDO?
David, some more questions:
1) Does this only happen when the server is used by concurrent clients?
2) How exactly do you launch your server? And how exactly do you configure your CDOSessions?
3) In particular, do you use CDOSession.Options.setCollectionLoadingPolicy()? If so, how?
Cheers
/Eike
http://www.esc-net.de
> I notice this:
> I never have to set this, but it might be there for a reason? Not sure what it does.
> I also notice in your clone method, you don't really clone (make a copy), but move objects to the new destination. For
> Containment references, this implies the object will not be in the source resource anymore.
> Thank You,
> Christophe
>> EObject>();
>> @Before
>> try {
>> @After
>> @Test
>> try {
>> } else {
>> Any takers?
Re: [CDO] Old class cast exception resurfaces [message #1404368 is a reply to message #1404031] Thu, 31 July 2014 11:12 Go to previous messageGo to next message
Christophe,
In answer to your question about why I use setGeneratedPackageEmulationEnabled(true) is ably explained by Eike in response to one of your posts. In a nutshell it is required when the ECore model resides in the repo only, generally using a JUnit test.
https://www.eclipse.org/forums/index.php/mv/msg/634055/1227482/#msg_1227482
I use the clone code because it exposes the error simply by walking the model.
I am coming to this cold the guy who wrote it is no longer around. So now realise CDO is not simple and there is a great deal to learn.
Part of the problem is that while the test case exhibits the ObjectNoFoundException, the ClassCastException only shows when using the design tool product and trying to persist. So we do not have a repo that exhibits this error currently, because they fail to persist. Since the model in question has about 100 hours of data entry and the CCE has occurred about 5 times during this this is a difficulty.
I will go through the code and make changes according to Eike's suggestions and only then raise the issue if the problem persists.
Re: [CDO] Old class cast exception resurfaces [message #1404729 is a reply to message #1404368] Tue, 05 August 2014 06:30 Go to previous messageGo to next message
On 31-07-14 17:12, David Wynter wrote:
> Christophe,
Ah yes, I recall now. This was for Edapt. In a regular usage of CDO with
native EPackages, you should have the generated model and EPackage and
therefor not needing to emulated the EPackage. EMF Code generation makes
sure your EPackage is registered in the global registry. Have a look at
your plugin.xml in the generated model plugin.
> model.
Re: [CDO] Old class cast exception resurfaces [message #1404740 is a reply to message #1404368] Tue, 05 August 2014 08:07 Go to previous messageGo to next message
Am 31.07.2014 um 17:12 schrieb David Wynter:
> Christophe,
> using a JUnit test.
Please note that in that post I say "If the original type of a model is NATIVE [...]", which doesn't seem to be the case
for you.
Cheers
/Eike
Re: [CDO] Old class cast exception resurfaces [message #1410329 is a reply to message #1404740] Wed, 20 August 2014 08:47 Go to previous messageGo to next message
Christophe,
I have spoken with Eike and while he does not have time to research this problem he believes there is nothing wrong with our repository, but something in it is causing the CDO code to fail. I can share the repo with you from a google drive if you give me your email, mine is stpdave using a gmail account. What is hard to understand is we save the elements in the model as we design them in our environment and everything works for possibly 100 model elements persisted and suddenly persisting (a model element that has had same class saved many times previous) the repository ends up in this state.
To quote Eike - "... the collection size values in the attribute tables are inconsistent with the actual number of associated rows in the *_refs tables. I know that we fixed a very subtle multi-threading issue ~1 year ago that was a little similar (is your data or your server code from that time?). On the other hand, IIRC, there were only two bad states:
1) *More* reference rows than mentioned in the size column. In this case the extra rows were silently ignored. No exception, "just" possibly wrong collection values.
2) *Less* reference rows than mentioned in the size column. In this case there was an exception but it was totally different."
He also said you had a SQL script that might be used to detect errors, can you shares this?
We also switched to the EcoreUtil.copy, it made no difference, except make our code smaller and neater
Thx.
David
Re: [CDO] Old class cast exception resurfaces [message #1410765 is a reply to message #1410329] Thu, 21 August 2014 11:03 Go to previous messageGo to next message
I checked the database and all the *_LIST counts matched the SUM of reference counts. Here is an example query:
SELECT SUM(INRELATIONSHIPS) FROM RECORD This has to match the number of rows in RECORD_INRELATIONSHIPS_LIST
Then by chance we found the issue.
All our Classes subclass a class called BaseModel and it has an attribute called UUID. For a RECORD class CDO_ID we had 2 CDO_VERSION values (i.e. 2 rows) 1 and 2. But in the related (through the RECORD.UUID) column value we have 2 records for UUID one with CDO_VERSION = 1 and the 2nd with CDO_VERSION = -2. Now -2 means deleted. This caused the exception. By changing it to 2 the whole repo loads. What I don't know is how it got like this?
So next I checked linked UUID and RECORD records with.
SELECT UUID.CDO_ID, UUID.CDO_VERSION, UUID.CDO_CREATED, UUID.CDO_REVISED,
R.CDO_ID, R.CDO_VERSION, R.CDO_CREATED, R.CDO_REVISED
FROM UUID INNER JOIN RECORD AS R ON UUID.CDO_ID = R.UUID
Here is some of the output, showing this deleted UUID record related to a non deleted RECORD is very common
CDO_ID	CDO_VERSION	CDO_CREATED	CDO_REVISED	CDO_ID	CDO_VERSION	CDO_CREATED	CDO_REVISED
34738	-2	        1392398553811	0	        941	1	        1392392444298	1392398553810
34738	1	        1392392444298	1392398553810	941	1	        1392392444298	1392398553810
34762	-2	        1392398553811	0	        943	1	        1392392444298	1392398553810
34762	1	        1392392444298	1392398553810	943	1	        1392392444298	1392398553810
34714	-2	        1392398553811	0	        939	1	        1392392444298	1392398553810
34714	1	        1392392444298	1392398553810	939	1	        1392392444298	1392398553810
40800	-2	        1406301336029	0	        40799	1	        1392399859424	1392635298848
40800	1	        1392399859424	1406301336028	40799	1	        1392399859424	1392635298848
Re: [CDO] Old class cast exception resurfaces [message #1410787 is a reply to message #1410765] Thu, 21 August 2014 11:58 Go to previous messageGo to next message
I am now working on the next error we have, different repository. While we can open the repository in our design tool, as soon as we try to expand part of the model in the tree viewer we get the sync error I reported elsewhere
[ERROR 2014-08-21 16:08:58.362 BST] main:com.yambina.mdwmui.MDWMUIWorkbenchAdvisor - Unhandled event loop exception
java.lang.IllegalStateException: Invalid synthetic type: -38
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:315)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:298)
	at org.eclipse.emf.cdo.spi.common.revision.RevisionInfo.readResult(RevisionInfo.java:166)
	at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:143)
	at org.eclipse.emf.cdo.internal.net4j.protocol.LoadRevisionsRequest.confirming(LoadRevisionsRequest.java:1)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientRequest.confirming(CDOClientRequest.java:97)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExtendedInput(RequestWithConfirmation.java:125)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doExecute(RequestWithConfirmation.java:105)
	at org.eclipse.net4j.signal.SignalActor.execute(SignalActor.java:53)
	at org.eclipse.net4j.signal.SignalProtocol.startSignal(SignalProtocol.java:442)
	at org.eclipse.net4j.signal.RequestWithConfirmation.doSend(RequestWithConfirmation.java:89)
	at org.eclipse.net4j.signal.RequestWithConfirmation.send(RequestWithConfirmation.java:75)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:502)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.send(CDOClientProtocol.java:535)
	at org.eclipse.emf.cdo.internal.net4j.protocol.CDOClientProtocol.loadRevisions(CDOClientProtocol.java:172)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.loadRevisions(CDORevisionManagerImpl.java:387)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:292)
	at org.eclipse.emf.cdo.internal.common.revision.CDORevisionManagerImpl.getRevisions(CDORevisionManagerImpl.java:282)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.convertToEMF(CDOStoreImpl.java:652)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.toArray(CDOStoreImpl.java:350)
	at org.eclipse.emf.internal.cdo.view.CDOStoreImpl.toArray(CDOStoreImpl.java:372)
	at org.eclipse.emf.ecore.impl.EStoreEObjectImpl$BasicEStoreEList.delegateToArray(EStoreEObjectImpl.java:309)
	at org.eclipse.emf.common.util.DelegatingEList.toArray(DelegatingEList.java:203)
	at org.eclipse.emf.ecore.util.DelegatingEcoreEList.toArray(DelegatingEcoreEList.java:338)
	at com.yambina.mdwmui.ui.providers.DataContentProvider.getChildren(DataContentProvider.java:125)
	at com.yambina.mdwmui.ui.providers.BaseEObjectExplorerContentProvider.getChildren(BaseEObjectExplorerContentProvider.java:142)
	at com.yambina.mdwmui.ui.providers.DataContentProvider.getChildren(DataContentProvider.java:1)
	at com.yambina.mdwmui.ui.providers.BaseEObjectExplorerContentProvider.hasChildren(BaseEObjectExplorerContentProvider.java:160)
	at com.yambina.mdwmui.ui.providers.DataContentProvider.hasChildren(DataContentProvider.java:1)
	at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2146)
	at org.eclipse.jface.viewers.TreeViewer.isExpandable(TreeViewer.java:588)
	at org.eclipse.jface.viewers.AbstractTreeViewer.isExpandable(AbstractTreeViewer.java:2176)
	at org.eclipse.jface.viewers.AbstractTreeViewer.updatePlus(AbstractTreeViewer.java:2858)
	at org.eclipse.jface.viewers.TreeViewer.updatePlus(TreeViewer.java:852)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createTreeItem(AbstractTreeViewer.java:849)
	at org.eclipse.jface.viewers.AbstractTreeViewer$1.run(AbstractTreeViewer.java:823)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:797)
	at org.eclipse.jface.viewers.TreeViewer.createChildren(TreeViewer.java:644)
	at org.eclipse.jface.viewers.AbstractTreeViewer.createChildren(AbstractTreeViewer.java:768)
	at org.eclipse.jface.viewers.AbstractTreeViewer.handleTreeExpand(AbstractTreeViewer.java:1500)
	at org.eclipse.jface.viewers.TreeViewer.handleTreeExpand(TreeViewer.java:952)
	at org.eclipse.jface.viewers.AbstractTreeViewer$4.treeExpanded(AbstractTreeViewer.java:1511)
	at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:132)
	at org.eclipse.swt.widgets.TreeItem.sendExpand(TreeItem.java:1036)
	at org.eclipse.swt.widgets.Tree.expandItem_expandChildren(Tree.java:1253)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5819)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSendSuper(Native Method)
	at org.eclipse.swt.widgets.Widget.callSuper(Widget.java:221)
	at org.eclipse.swt.widgets.Widget.mouseDownSuper(Widget.java:1101)
	at org.eclipse.swt.widgets.Tree.mouseDownSuper(Tree.java:2044)
	at org.eclipse.swt.widgets.Widget.mouseDown(Widget.java:1093)
	at org.eclipse.swt.widgets.Control.mouseDown(Control.java:2563)
	at org.eclipse.swt.widgets.Tree.mouseDown(Tree.java:2012)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5556)
	at org.eclipse.swt.widgets.Widget.windowSendEvent(Widget.java:2104)
	at org.eclipse.swt.widgets.Shell.windowSendEvent(Shell.java:2318)
	at org.eclipse.swt.widgets.Display.windowProc(Display.java:5620)
	at org.eclipse.swt.widgets.Display.applicationSendEvent(Display.java:5057)
	at org.eclipse.swt.widgets.Display.applicationProc(Display.java:5206)
	at org.eclipse.swt.internal.cocoa.OS.objc_msgSend(Native Method)
	at org.eclipse.swt.internal.cocoa.NSApplication.sendEvent(NSApplication.java:128)
	at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3648)
[Updated on: Thu, 21 August 2014 12:17] by Moderator
Re: [CDO] Old class cast exception resurfaces [message #1413455 is a reply to message #1410787] Thu, 28 August 2014 10:57 Go to previous message
We tried the ECoreUtil.Copier method but it triggers the notify mechanism (why this occurs when you are copying I have no idea) and that causes:
Caused by: java.lang.UnsupportedOperationException: Unsupported notification received: ADD_MANY - Product.workflow
	at com.yambina.edm.commons.platform.listeners.EObjectNotifyChangeListener.checkMany(EObjectNotifyChangeListener.java:247)
	at com.yambina.edm.commons.platform.listeners.EObjectNotifyChangeListener.notifyChanged(EObjectNotifyChangeListener.java:88)
	at com.yambina.edmmodel.impl.NotifyingAdapter.notifyChanged(NotifyingAdapter.java:56)
	at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
	at org.eclipse.emf.ecore.util.DelegatingEcoreEList.dispatchNotification(DelegatingEcoreEList.java:355)
	at org.eclipse.emf.common.notify.impl.DelegatingNotifyingListImpl.addAllUnique(DelegatingNotifyingListImpl.java:449)
	at org.eclipse.emf.common.notify.impl.DelegatingNotifyingListImpl.addAllUnique(DelegatingNotifyingListImpl.java:392)
	at org.eclipse.emf.common.util.AbstractEList.addAll(AbstractEList.java:370)
	at org.eclipse.emf.ecore.util.DelegatingEcoreEList.set(DelegatingEcoreEList.java:566)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copyContainment(EcoreUtil.java:595)
	at org.eclipse.emf.ecore.util.EcoreUtil$Copier.copy(EcoreUtil.java:490)
	at org.eclipse.emf.ecore.util.EcoreUtil.copy(EcoreUtil.java:357)
	at com.yambina.edm.validation.RawExporter.clone(RawExporter.java:97)
	at com.yambina.edm.validation.RawExporter.run(RawExporter.java:72)
Still finding the whole CDO mechanism impenetrable. Now I after reverting to our clone code I get this exception when trying to export my model to XMI.
Caused by: java.lang.ArrayStoreException
	at org.eclipse.emf.ecore.util.DelegatingEcoreEList.validate(DelegatingEcoreEList.java:147)
	at org.eclipse.emf.common.util.DelegatingEList.addUnique(DelegatingEList.java:334)
	at org.eclipse.emf.common.notify.impl.DelegatingNotifyingListImpl.doAddUnique(DelegatingNotifyingListImpl.java:379)
	at org.eclipse.emf.common.notify.impl.DelegatingNotifyingListImpl.addUnique(DelegatingNotifyingListImpl.java:275)
	at org.eclipse.emf.common.util.AbstractEList.add(AbstractEList.java:303)
	at com.yambina.edm.validation.RawExporter.maintainAssociations(RawExporter.java:152)
Here is maintainAssociations
    private void maintainAssociations(final Collection<EObject> eObjects) throws InvocationTargetException {
            EObject eObjectClone = this.clones.get(eObject);
            assert eObjectClone != null;
            for (EReference reference : eObjectClone.eClass().getEAllReferences()) {
                try {
                    if (reference.isContainment()) {
                        } else {
                        Collection<EObject> list = (Collection<EObject>) eObjectClone.eGet(reference);
                        for (Object object : (Collection<?>) value) {
                            EObject child = (EObject) object;
                            EObject childClone = this.clones.get(child);
                            assert childClone != null;
                            try {
                            	list.add(childClone); // ArrayStoreException here
                            } catch (ArrayStoreException ase) {
                    } else {
                        EObject child = (EObject) value;
                        if (child != null) {
                            eObjectClone.eSet(reference, childClone);
                    this.invalidObjects.add(eObjectClone);
                    LogPlugin.error(LOG, true, "{0}#{1} references an object that can't be found", Utils.getFullyQualifiedName(eObject), reference.getName()); //$NON-NLS-1$
            this.maintainAssociations(children);
Here is where the error is found from line 141 of org.eclipse.emf.ecore.util.DelegtingEcoreEList
  protected E validate(int index, E object)
    super.validate(index, object);
    if (object != null && !isInstance(object))
      throw new ArrayStoreException();
    return object;
  protected boolean isInstance(Object object)
    return getFeatureType().isInstance(object);
The featureType is set to our com.yambina.edmmodel.Resource and the object is com.yambina.edmmodel.UUIDImpl I cannot understand how this mismatch occurs.
These 2 classes related where Resource has an attribute ref which in a non containment reference to a BaseModel abstract class that has one attribute, the aforementioned UUID class. Somehow the feature of the Resource class gets set to the related UUID class. Not sure of the formality of the management of Feature related to the Class.
Jump in anyone...
Previous Topic:Custon type in <xs:list>
Next Topic:EMF generated code and MVC pattern customization
Current Time: Thu Nov 06 07:40:42 EST 2025
Powered by FUDForum. Page generated in 0.09198 seconds
