Re: Having trouble with launching Ecliplse .log file [message #1404225 is a reply to message #1404145] |
Wed, 30 July 2014 10:41   |
On Tue, 29 Jul 2014 19:30:25 -0400, Zach Prince wrote:
> I've been searching around and seen several different solutions but unfortunately none of them worked for me to get my Eclipse up and running. I am new here and it was working yesterday perfectly but I'm guessing when I closed it yesterday it might have somehow gotten corrupted. If you could point me in the right direction I'd very much appreciate it :)! Here is some of the things I've tried so far based on other thread solutions that worked for others:
> Changed SHOW_WORKSPACE_SELECTION_DIALOG=false (to true to see if a new workspace would resolve issue but it did not)
> Tried adding -clean to the beginning of the eclipse.ini that did not work as well.
> Tried finding any .snap files from the .plugins\org.eclipse.core.resources\ but I did not see any to delete.
> Tried reinstalling the jdk and that didn't work
> Tried to delete and fresh install Eclipse to see if that would work and it didn't either.
> Thank you for your time and help!!
> Here is the information from my .log file:
> eclipse.buildId=4.4.0.I20140606-1215
> java.version=1.7.0_45
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
> !ENTRY org.eclipse.osgi 4 0 2014-07-29 23:16:09.198
> !MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: C:\Users\Zach\Desktop\eclipse\configuration\org.eclipse.osgi
> !ENTRY org.eclipse.jdt.annotation 2 0 2014-07-29 23:16:14.210
> !MESSAGE Could not resolve module: org.eclipse.jdt.annotation [190]
> Unresolved requirement: Require-Capability: osgi.ee; filter:="(&(osgi.ee=JavaSE)(version=1.8))"
> !ENTRY org.eclipse.osgi 4 0 2014-07-29 23:16:14.220
> !MESSAGE Application error
> !STACK 1
> org.eclipse.e4.core.di.InjectionException: java.lang.InternalError
> at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:62)
> at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:114)
> at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:337)
> at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:258)
> at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
> at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createDefaultContext(E4Application.java:502)
> at org.eclipse.e4.ui.internal.workbench.swt.E4Application.createE4Workbench(E4Application.java:210)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:601)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:579)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:150)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:135)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:134)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:104)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
> Caused by: java.lang.InternalError
> at java.util.Currency$1.run(Unknown Source)
> at java.security.AccessController.doPrivileged(Native Method)
> at java.util.Currency.<clinit>(Unknown Source)
> at java.text.DecimalFormatSymbols.initialize(Unknown Source)
> at java.text.DecimalFormatSymbols.<init>(Unknown Source)
> at java.text.DecimalFormatSymbols.getInstance(Unknown Source)
> at java.text.NumberFormat.getInstance(Unknown Source)
> at java.text.NumberFormat.getIntegerInstance(Unknown Source)
> at java.text.SimpleDateFormat.initialize(Unknown Source)
> at java.text.SimpleDateFormat.<init>(Unknown Source)
> at org.eclipse.osgi.internal.debug.EclipseDebugTrace.<clinit>(EclipseDebugTrace.java:51)
> at org.eclipse.osgi.internal.debug.FrameworkDebugOptions.newDebugTrace(FrameworkDebugOptions.java:404)
> at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.setDebugOptions(WorkbenchLogger.java:137)
> at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
> ... 23 more
> Caused by: java.io.FileNotFoundException: C:\Windows\jre\lib\currency.data (The system cannot find the file specified)
> at java.io.FileInputStream.open(Native Method)
> at java.io.FileInputStream.<init>(Unknown Source)
> ... 42 more
I would rename the eclipse folder to eclipse.bak then unpack a new
eclipse folder from the file you originally downloaded
or even get the latest from the Eclipse Downloads site.
Then before running it, I'd run:
java -version
Make sure that looks correct (an actual JDK and version you intended) then run:
where java.exe
Make sure the one that is running is the one you think is running.
Then run:
set
Look for the PATH and JAVA_HOME (if set) to make sure they
look right.
Dilton
FUDForum. Page generated in 0.07109 seconds
