Home » Eclipse Projects » Equinox » Unresolved requirement: Require-Capability: eclipse.platform(Issue updating Equinox/OSGi platform from Kepler to Luna)
Unresolved requirement: Require-Capability: eclipse.platform [message #1403713] Fri, 25 July 2014 10:01 Go to next message
We recently decided to drop Java 1.7 support and I have been working on updating our software to require Java 1.8 and in the process found out that the libraries we were using from Kepler had some dependency issues and it was suggested somewhere that the new Luna libraries fixed things. So, I've been migrating our libraries to Luna-based libraries.
Now, I believe I have everything updated and I have it in a compilable state, however, it doesn't run successfully. Currently, I have it to the point where I receive the following errors in the workspace/.metadata/.log file:
!SESSION 2014-07-25 09:23:07.218 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.8.0_11
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Framework arguments:  -pluginCustomization configuration/plugin_customization.ini
Command-line arguments:  -clean -pluginCustomization configuration/plugin_customization.ini
!ENTRY org.eclipse.core.filesystem.macosx 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.macosx [122]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=macosx) (|(osgi.arch=x86) (osgi.arch=ppc) (osgi.arch=x86_64)))"
!ENTRY org.eclipse.swt.win32.win32.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86 [75]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))"
!ENTRY org.eclipse.core.resources.win32.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86_64 [9]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.equinox.launcher.win32.win32.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.win32.win32.x86 [29]
!ENTRY org.eclipse.equinox.launcher.cocoa.macosx 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.cocoa.macosx [55]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (|(osgi.arch=x86)(osgi.arch=ppc)) )"
!ENTRY org.eclipse.core.filesystem.linux.x86 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.linux.x86 [90]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.ui.cocoa 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.ui.cocoa [23]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(osgi.ws=cocoa)"
!ENTRY org.eclipse.swt.cocoa.macosx.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx.x86_64 [71]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=cocoa) (osgi.os=macosx) (osgi.arch=x86_64) )"
!ENTRY org.eclipse.equinox.launcher.win32.win32.x86_64 2 0 2014-07-25 09:23:09.754
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.win32.win32.x86_64 [128]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86_64))"
!ENTRY org.eclipse.swt.win32.win32.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.win32.win32.x86_64 [118]
!ENTRY org.eclipse.core.filesystem.win32.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86 [124]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.os=win32) (osgi.arch=x86))"
!ENTRY org.eclipse.core.resources.win32.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.resources.win32.x86 [95]
!ENTRY org.eclipse.equinox.launcher.cocoa.macosx.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.cocoa.macosx.x86_64 [133]
!ENTRY org.eclipse.swt.gtk.linux.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.gtk.linux.x86 [127]
  Unresolved requirement: Require-Capability: eclipse.platform; filter:="(& (osgi.ws=gtk) (osgi.os=linux) (osgi.arch=x86))"
!ENTRY org.eclipse.core.filesystem.win32.x86_64 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.core.filesystem.win32.x86_64 [60]
!ENTRY org.eclipse.swt.cocoa.macosx 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.swt.cocoa.macosx [28]
!ENTRY org.eclipse.equinox.launcher.gtk.linux.x86 2 0 2014-07-25 09:23:09.755
!MESSAGE Could not resolve module: org.eclipse.equinox.launcher.gtk.linux.x86 [50]
!ENTRY org.eclipse.osgi 4 0 2014-07-25 09:23:09.756
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "<my.app>.workspace.ui.<application>" could not be found in the registry. The applications available are: org
.eclipse.equinox.app.error.
	at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
	at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
	at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:236)
	at java.lang.reflect.Method.invoke(Method.java:483)
	at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:648)
	at org.eclipse.equinox.launcher.Main.basicRun(Main.java:603)
	at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
	at org.eclipse.equinox.launcher.Main.main(Main.java:1438)
Not sure what the eclipse.platform is referring to. There's a platform.jar in the eclipse luna platform but copying that to my plugins directory doesn't fix the issue. Also, I have gotten it running ifI run it from within Eclipse (which make me think my previous issue is a bundle missing or incorrect start order) but then I get the following errors:
java.lang.NoClassDefFoundError: javafx/scene/Parent
	at java.lang.Class.getDeclaredMethods0(Native Method)
	at java.lang.Class.privateGetDeclaredMethods(Class.java:2688)
	at java.lang.Class.getMethod0(Class.java:2937)
	at java.lang.Class.getMethod(Class.java:1771)
	at <my.app>.cfp.container.FxGadgetContainerBeanInfo.<init>(FxGadgetContainerBeanInfo.java:10)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
	at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java:62)
	at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorImpl.java:45)
	at java.lang.reflect.Constructor.newInstance(Constructor.java:408)
	at java.lang.Class.newInstance(Class.java:433)
	at com.sun.beans.finder.InstanceFinder.instantiate(InstanceFinder.java:96)
	at com.sun.beans.finder.InstanceFinder.find(InstanceFinder.java:66)
	at java.beans.Introspector.findExplicitBeanInfo(Introspector.java:448)
	at java.beans.Introspector.<init>(Introspector.java:398)
	at java.beans.Introspector.getBeanInfo(Introspector.java:173)
	at <my.app>.bean.ComponentUtils.getBeanInfo(ComponentUtils.java:51)
	at <my.app>.bean.ComponentUtils.getDisplayName(ComponentUtils.java:332)
	at <my.app>.bean.ComponentUtils.getName(ComponentUtils.java:358)
	at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$6.compare(VisualizationComponentList.java:207)
	at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$6.compare(VisualizationComponentList.java:1)
	at java.util.TimSort.countRunAndMakeAscending(TimSort.java:351)
	at java.util.TimSort.sort(TimSort.java:230)
	at java.util.Arrays.sort(Arrays.java:1435)
	at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList.updateListData(VisualizationComponentList.java:203)
	at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList.access$0(VisualizationComponentList.java:198)
	at <my.app>.workspace.ui.compositiongraph.VisualizationComponentList$4.run(VisualizationComponentList.java:170)
	at <my.app>.util.concurrent.RunQueue$1.run(RunQueue.java:33)
	at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
	at java.util.concurrent.FutureTask.run(FutureTask.java:266)
	at <my.app>.util.concurrent.MonitoredFuture.run(MonitoredFuture.java:193)
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
	at <my.app>.util.concurrent.Executors$1$1.run(Executors.java:90)
	at java.lang.Thread.run(Thread.java:745)
Caused by: java.lang.ClassNotFoundException: javafx.scene.Parent cannot be found by <my.app>.cfp_3.1.0.qualifier
	at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:423)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:336)
	at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:328)
	at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:160)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 36 more
Here's my config.ini
osgi.splashPath=platform:/base/plugins/<my.app>.workspace.ui
eclipse.application=<my.app>.workspace.ui.<application>
osgi.bundles=org.eclipse.equinox.common@2:start,\
 org.eclipse.update.configurator@2:start,\
 org.eclipse.equinox.ds@3:start,\
 org.eclipse.equinox.registry@4:start,\
 org.eclipse.equinox.app@5:start,\
 <my.app>.openglstuff@4:start,\
 <my.app>.logviewer@start,\
 org.eclipse.osgi@5:start,\
 <my.app>.workspace.collab@start,\
 <my.app>.workspace.collab.app@start,\
 <my.app>.messaging.app@start,\
 org.eclipse.core.runtime@3:start
osgi.bundles.defaultStartLevel=6
osgi.startLevel=6
Any help would be greatly appreciated. If anyone knows where to get some kind of runtime dependency debug or info about how Luna's libraries are different from Kepler or anything that might help me fix my issue I'd be greatly appreciative. (Also, some packages were obfuscated a bit; I don't think it'll cause issues determining what's going on)
Re: Unresolved requirement: Require-Capability: eclipse.platform [message #1404067 is a reply to message #1403713] Tue, 29 July 2014 08:21 Go to previous messageGo to next message
All the eclipse.platform requirements are coming from bundles that you have in your target that do not match your running environment:
Is that the exact error message? Or did you remove your specific application name here? Similar question on the config.ini settings:
Re: Unresolved requirement: Require-Capability: eclipse.platform [message #1407881 is a reply to message #1404067] Wed, 13 August 2014 13:49 Go to previous messageGo to next message
Yes, I did remove the exact string. In previous versions of eclipse having non-platform jars in my target platform it would just ignore.
However, removing them only fixes the platform specific things; it doesn't fix the javafx exceptions (which are part of the java8 classpath by default). It will, however, run successfully when I remove the non-platform jars from my platform but when I go to open anything that requires javafx, it throws the javafx exceptions from before.
Re: Unresolved requirement: Require-Capability: eclipse.platform [message #1697476 is a reply to message #1407881] Thu, 04 June 2015 05:22 Go to previous message
Stephen - are you still facing the problem? I am facing it and don't know how to proceed. Please share the solution if you were able to resolve it. By the way, if you are still facing the problem I came across this Eclipse 4.4 porting guide which is available here: https://eclipse.org/eclipse/development/porting/eclipse_4_4_porting_guide.php. I think this could help you identify differences between Kepler and Luna.
Previous Topic:Execute custom touchpoint that is not pre-installed
Next Topic:Eclipse install fails on conflicting equinox p2 dependency
Current Time: Sun Jul 27 01:57:43 EDT 2025
Powered by FUDForum. Page generated in 0.24091 seconds
