Home » Eclipse Projects » Remote Application Platform (RAP) » RAP 3.0?
RAP 3.0? [message #1403999] Tue, 29 July 2014 01:46 Go to next message
I see there is a RAP 3.0 planned, apparently for December. This implies
API breakage. How can I find out more about how this will affect me,
i.e., how will EMF's RAP integration be impacted?
I assume the Mars release train will include some RAP 3.x version and I
assume that the Luna service releases will include RAP 2.3.x releases or
perhaps a 2.4.x. Are these good assumptions?
Ed
Re: RAP 3.0? [message #1404009 is a reply to message #1403999] Tue, 29 July 2014 03:18 Go to previous messageGo to next message
Hi Ed,
yes... Luna service releases will include RAP 2.3.x releases. Mars
release train will include RAP 3.1 version. RAP 3.0 is planned for
December. About API changes - all deprecated classes (API) will be
removed (most of them are already removed from master branch, upcoming
3.0M1). You could give the latest nightly [1] a try to see how EMF's RAP
integration is affected. As usual, we will provide a RAP 3.0 migration
guide (similar to 2.0).
[1] https://www.eclipse.org/rap/downloads/
Best,
Ivan
Ivan Furnadjiev
Twitter: @EclipseRAP
Re: RAP 3.0? [message #1404010 is a reply to message #1403999] Tue, 29 July 2014 03:23 Go to previous messageGo to next message
.... and in RAP 3.0 we discontinue IE7/8 support and maybe some other
(non CSS3 based) older browsers.
Ivan Furnadjiev
Re: RAP 3.0? [message #1404012 is a reply to message #1403999] Tue, 29 July 2014 03:29 Go to previous messageGo to next message
Good Morning Ed,
you are correct in your assumption that RAP 3.0 will contain some breaking API changes. When we did the last breaking upgrade to RAP 2.0 we maintained a document with all our changes, but this document is not yet ready for 3.0. The same applies for the planning: I will try to summarize the already known changes in a document and/or in the project plan.
All our scheduled versions can be found here:
https://projects.eclipse.org/projects/rt.rap/documentation
Luna will see updates to our currently released 2.3 stream, i.e. Luna SR1 will include RAP 2.3.1, and Luna SR2 next year will include 2.3.2. Even if we could update theoretically in SR2 to RAP 3.0 we don't have any plans in this direction.
RAP 3.0 is planned for this December, and (similar to RAP 2.0 a few years ago) we are planning to contribute RAP 3.1 to the Mars release next year.
Hope that helps for the moment.
Markus
Re: RAP 3.0? [message #1404014 is a reply to message #1404009] Tue, 29 July 2014 03:29 Go to previous messageGo to next message
Ivan,
Thanks for the info. Our builds are pointing at RAP's nightly build,
and those have been picking up 3.x, which is why I noticed. (That's even
the case for the emf-maintenance build which is targeted for Luna SR0,
so that's bad.) At least the builds themselves haven't been failing, so
that looks promising.
On 29/07/2014 9:18 AM, Ivan Furnadjiev wrote:
> Hi Ed,
> RAP integration is affected. As usual, we will provide a RAP 3.0
> migration guide (similar to 2.0).
> Best,
> Ivan
Re: RAP 3.0? [message #1415635 is a reply to message #1404014] Wed, 03 September 2014 04:34 Go to previous messageGo to next message
Hi Ivan,
I am currently trying to migrate from 2.3 to 3.0. Do you know when the RAP 3.0 migration guide will be available?
Best,
Matthias
Re: RAP 3.0? [message #1415645 is a reply to message #1415635] Wed, 03 September 2014 05:07 Go to previous messageGo to next message
Hi Matthias,
I hope, it will be ready before RAP 3.0M3. Since them, do you have any
particular problems during the migration? If yes, ask here and I'll try
to help you. In RAP 3.0M1 all deprecated API have been removed -
basically in lifecycle package. The replacement is the new Remote Object
API introduced in RAP 2.1.
HTH,
Ivan
Ivan Furnadjiev
Re: RAP 3.0? [message #1415650 is a reply to message #1415645] Wed, 03 September 2014 05:24 Go to previous messageGo to next message
Hi Ivan,
thanks for your answer.
We wanted to have callbacks before and after a http request. Therefore we registered a PhaseListener:
RWT.getLifeCycle().addPhaseListener(impl)
which called our two methods:
a) beforeHttpRequest()
b) afterHttpRequest()
How would I now implement this feature? Also with the Remote Object API?
Re: RAP 3.0? [message #1415660 is a reply to message #1415650] Wed, 03 September 2014 05:49 Go to previous messageGo to next message
the replacement (not completely) of PhaseListeners is MessageFilter,
which is currently internal, but we want to make it API for 3.0 release.
The concept is similar to servlet filter and can be added to
ApplicationContext(Impl). Please note that the filter is processes
outside the UI thread (SWT compatible mode) and there is no access to
display/widgets in it.
HTH,
Ivan
Ivan Furnadjiev
Re: RAP 3.0? [message #1415664 is a reply to message #1415660] Wed, 03 September 2014 05:58 Go to previous messageGo to next message
When I want to add a MessageFilter, I need to have the ApplicationContextImpl?!
Is this the right way to obtain it?
ApplicationContextImpl impl = (ApplicationContextImpl) RWT.getApplicationContext();
Re: RAP 3.0? [message #1415673 is a reply to message #1415664] Wed, 03 September 2014 06:20 Go to previous messageGo to next message
Yes... When we make it API the cast will not be needed.
Ivan Furnadjiev
Re: RAP 3.0? [message #1416074 is a reply to message #1415673] Thu, 04 September 2014 05:19 Go to previous messageGo to next message
Hi Ivan,
thanks for your help, I was able to migrate.
I have one more question:
we use the following code
WidgetUtil.getAdapter(tree).getId()
Is there now another way to get the id?
Re: RAP 3.0? [message #1416086 is a reply to message #1416074] Thu, 04 September 2014 05:42 Go to previous messageGo to next message
org.eclipse.rap.rwt.widgets.WidgetUtil#getId( Widget )
HTH,
Ivan
Ivan Furnadjiev
Re: RAP 3.0? [message #1416177 is a reply to message #1416086] Thu, 04 September 2014 09:45 Go to previous message
awesome, thank you very much
Previous Topic:Shell setMaximized issue
Next Topic:FileChooser and iPad
Current Time: Fri Jul 25 23:50:46 EDT 2025
Powered by FUDForum. Page generated in 0.04849 seconds
