Home » Eclipse Projects » Oomph » p2 & gmf errors(Error log shows p2 & gmf errors on an installation from scratch)
p2 & gmf errors [message #1403912] Mon, 28 July 2014 10:41 Go to next message
Hello. I'm using Oomph to install Papyrus using the setup file
http://git.eclipse.org/c/papyrus/org.eclipse.papyrus.git/plain/releng/org.eclipse.papyrus.oomph/setups/papyrus.setup
While I do get a working environment, I find a couple of errors on the Error log. One seems to be from p2 and the other one from GMF. The details are below. I see that the p2 exception says the BundleContext is no longer valid. Since this is an installation from scratch, I am wondering what is the problem.
I'm on MacOSX 10.9.
Thanks.
The p2 error is as follows:
eclipse.buildId=4.4.0.I20140606-1215
java.version=1.7.0_51
BootLoader constants: OS=macosx, ARCH=x86_64, WS=cocoa, NL=en_US
Framework arguments:  -product org.eclipse.epp.package.standard.product
Command-line arguments:  -os macosx -ws cocoa -arch x86_64 -product org.eclipse.epp.package.standard.product -data /Users/eposse/Development/PapyrusRT/workspaces/papyrus-ws-3
org.eclipse.equinox.p2.core
Error
Mon Jul 28 10:15:04 EDT 2014
FrameworkEvent ERROR
org.osgi.framework.BundleException: Exception in org.eclipse.equinox.internal.p2.core.Activator.stop() of bundle org.eclipse.equinox.p2.core.
	at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:847)
	at org.eclipse.osgi.internal.framework.EquinoxBundle.stopWorker0(EquinoxBundle.java:950)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$EquinoxModule.stopWorker(EquinoxBundle.java:324)
	at org.eclipse.osgi.container.Module.doStop(Module.java:626)
	at org.eclipse.osgi.container.Module.stop(Module.java:488)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.decStartLevel(ModuleContainer.java:1623)
	at org.eclipse.osgi.container.ModuleContainer$ContainerStartLevel.doContainerStartLevel(ModuleContainer.java:1542)
	at org.eclipse.osgi.container.SystemModule.stopWorker(SystemModule.java:248)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule.stopWorker(EquinoxBundle.java:145)
	at org.eclipse.osgi.container.SystemModule.stop(SystemModule.java:186)
	at org.eclipse.osgi.internal.framework.EquinoxBundle$SystemBundle$EquinoxSystemModule$1.run(EquinoxBundle.java:160)
	at java.lang.Thread.run(Thread.java:744)
Caused by: java.lang.IllegalStateException: BundleContext is no longer valid
	at org.eclipse.osgi.internal.framework.BundleContextImpl.checkValid(BundleContextImpl.java:983)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.getServiceReference(BundleContextImpl.java:559)
	at org.eclipse.equinox.internal.p2.core.helpers.ServiceHelper.getService(ServiceHelper.java:63)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.getPreferences(AbstractRepositoryManager.java:497)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.remember(AbstractRepositoryManager.java:879)
	at org.eclipse.equinox.internal.p2.repository.helpers.AbstractRepositoryManager.stop(AbstractRepositoryManager.java:1075)
	at org.eclipse.equinox.internal.p2.core.ProvisioningAgent.stop(ProvisioningAgent.java:134)
	at org.eclipse.equinox.internal.p2.core.Activator.unregisterAgent(Activator.java:262)
	at org.eclipse.equinox.internal.p2.core.Activator.stop(Activator.java:248)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:827)
	at org.eclipse.osgi.internal.framework.BundleContextImpl$4.run(BundleContextImpl.java:1)
	at org.eclipse.osgi.internal.framework.BundleContextImpl.stop(BundleContextImpl.java:820)
	... 13 more
Root exception:
And the GMF error:
org.eclipse.gmf.runtime.common.ui
Error
Mon Jul 28 10:15:03 EDT 2014
org.osgi.framework.BundleException: Exception in org.eclipse.gmf.runtime.common.ui.internal.CommonUIPlugin.stop() of bundle org.eclipse.gmf.runtime.common.ui.
Caused by: org.eclipse.swt.SWTException: Invalid thread access
	at org.eclipse.swt.SWT.error(SWT.java:4441)
	at org.eclipse.swt.SWT.error(SWT.java:4356)
	at org.eclipse.swt.SWT.error(SWT.java:4327)
	at org.eclipse.swt.widgets.Display.error(Display.java:1083)
	at org.eclipse.swt.widgets.Display.createDisplay(Display.java:840)
	at org.eclipse.swt.widgets.Display.create(Display.java:823)
	at org.eclipse.swt.graphics.Device.<init>(Device.java:130)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:714)
	at org.eclipse.swt.widgets.Display.<init>(Display.java:705)
	at org.eclipse.swt.widgets.Display.getDefault(Display.java:1403)
	at org.eclipse.gmf.runtime.common.ui.util.DisplayUtils.getDisplay(DisplayUtils.java:41)
	at org.eclipse.gmf.runtime.common.ui.util.UIModificationValidator.dispose(UIModificationValidator.java:208)
	at org.eclipse.gmf.runtime.common.ui.internal.CommonUIPlugin.stop(CommonUIPlugin.java:83)
	... 13 more
Root exception:
Re: p2 &amp; gmf errors [message #1403924 is a reply to message #1403912] Mon, 28 July 2014 11:24 Go to previous messageGo to next message
Ernesto,
Comments below.
> Error log.
We see the first one too. It seems harmless enough but is also
annoying. I don't think there's a bugzilla to track it yet, so please
open one.
The GMF one looks more odd. There should be no assumptions about which
thread does the shutdown, and it's odd to do anything with the display
in a bundle shutdown. It even appears they're trying to create a new
display, which seems completely bogus during a shutdown... Better to
ask about that on the GMF newsgroup. Although you never know if
something about they way the IDE is installed is leading to these odd
shutdown problems in general. Perhaps if we track down the first problem
(that we can reproduce) and fix it, this second problem goes away too...
> I'm on MacOSX 10.9.
> Thanks.
> java.vendor=Oracle Corporation
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> valid
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at java.security.AccessController.doPrivileged(Native Method)
> at
> ... 13 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> And the GMF error:
> Error
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 13 more
> Root exception:
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: p2 &amp; gmf errors [message #1403963 is a reply to message #1403924] Mon, 28 July 2014 14:08 Go to previous messageGo to next message
Hi, Ed, Ernesto,
Papyrus always triggers (somehow, I don't know) the GMF plugin shutdown
trying to create the display again. That problem is definitely not
unique to an Oomph-provisioned Papyrus; it's quite old.
cW
On 2014-07-28 15:24:38 +0000, Ed Merks said:
> Ernesto,
> Comments below.
>> Error log.
> open one.
> problem (that we can reproduce) and fix it, this second problem goes
> away too...
>> I'm on MacOSX 10.9.
>> Thanks.
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 13 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> And the GMF error:
>> Error
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> ... 13 more
>> Root exception:
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
Re: p2 &amp; gmf errors [message #1418675 is a reply to message #1403912] Sun, 07 September 2014 08:35 Go to previous messageGo to next message
Am 28.07.2014 um 16:41 schrieb Ernesto Posse:
> at
> at
> at
> at
> ... 13 more
> Root exception:
> at
> at
> at
> at
I hope that we've fixed this problem via:
443466: Exception "BundleContext is no longer valid" in AbstractRepositoryManager.stop()
https://bugs.eclipse.org/bugs/show_bug.cgi?id=443466
It would be great if you could confirm that your exception doesn't come anymore.
Cheers
/Eike
http://www.esc-net.de
Re: p2 &amp; gmf errors [message #1426939 is a reply to message #1418675] Fri, 19 September 2014 08:57 Go to previous message
about the GMF stacktrace: this is a reported GMF issue with Luna https://bugs.eclipse.org/bugs/show_bug.cgi?id=424074 which will be fixed in next maintenance release.
[Updated on: Fri, 19 September 2014 08:58] by Moderator
Previous Topic:Git clone task how-to
Next Topic:Perform set up tasks and user.setup
Current Time: Wed Jul 30 19:22:49 EDT 2025
Powered by FUDForum. Page generated in 0.25098 seconds
