Home » Modeling » Papyrus » How to open GMF Compare Viewer for merging
How to open GMF Compare Viewer for merging [message #1403484] Thu, 24 July 2014 02:51 Go to next message
Hi all,
I started investigating the status of the graphical comparison capabilities
of Papyrus Luna, but I must admit I failed to merely open the graphical
compare editor. I installed all the necessary plugins both from Papyrus
Update Site and EMF compare.
I followed the instructions at
http://www.eclipse.org/emf/compare/documentation/latest/user/user-guide.html#Graphical_Comparison
but with no success. Every time I try to compare the graphical file (i.e.
the notation file), the textual compare editor is opened.
I would appreciate any hint on what I am doing wrong.
Marc-Florian
Re: How to open GMF Compare Viewer for merging [message #1403847 is a reply to message #1403484] Mon, 28 July 2014 05:24 Go to previous messageGo to next message
Hi Marc-Florian,
In theory, the EMF Compare editor works fine when used on *.uml, *.di and *.notation files (Or the top-level Papyrus pseudo-folder). The support for *.notation and *.uml is natively provided by EMF Compare, whereas the support for *.di comparison is provided by Papyrus/UML Compare.
Note that EMF Compare relies on Content Types to identify models, which means that if you changed your content-type definitions in your workspace settings, this may prevent the comparison from working properly. Also, the current version of EMF Compare doesn't work properly when partial/invalid EMF/UML models are used (e.g. if a library/profile is missing). The scope of the comparison is the current project, so, trying to compare a Papyrus model when you have an invalid (even unrelated) *.xmi model in the same project will most likely not work.
HTH,
Camille
Re: How to open GMF Compare Viewer for merging [message #1403891 is a reply to message #1403847] Mon, 28 July 2014 09:20 Go to previous messageGo to next message
Hi Camille,
after setting the content type explicitly to .notation in the Preferences,
it worked as expected. Thanks for the hint.
I have encountered a different defect when playing around with branching and
merging. Everytime you merge with the content of a branch, the compare
editor finishes with an exception related to the textual compare annotations
in the XMI. See pictures 1-3. After manually removing the content within the
workspace annotations (see picture 4) the compare model can be calculated
without any problems.
The notation file seems a little bit more buggy, since the diagrams always
get corrupted when trying to merge. It can be corrected manually and then
merged as well, but with almost no visual support (since all references got
broken).
Is merging of branches conceptually treated differently from merging
revisions of the same URL? It seems so to me, since a simply synchronization
with the repository did not cause any such failures.
I am not sure whether this is a Papyrus- or EMF Compare-related defect, too.
Marc-Florian
"Camille Letavernier" wrote in message
news:lr54s8$q7u$1@xxxxxxxxe.org...
Hi Marc-Florian,
HTH,
Camille
Re: How to open GMF Compare Viewer for merging [message #1403901 is a reply to message #1403891] Mon, 28 July 2014 10:08 Go to previous message
Papyrus only provides a thin integration layer on top of EMF Compare (A few menu contributions). Most bugs (and questions) should be reported to EMF Compare.
I don't know. Maybe in some cases, the files are "pre-merged by Git"? I've had issues with that even for standard Java projects. The "Pre-merged" option wasn't really helpful last time I tried it (This might have been fixed since then). If you don't use "Pre-merged", these tags shouldn't appear.
HTH,
Camille
Previous Topic:Should C++ code generation work with Kepler SR2?
Next Topic:Mapping URIs
Current Time: Thu Jul 24 23:30:16 EDT 2025
Powered by FUDForum. Page generated in 0.27587 seconds
