Usage of NSCL [message #1403081] |
Mon, 21 July 2014 04:55  |
I have a question on the usage of NSCL. I am confused about the meaning of a NSCL inside the architecture of ETSI M2M.
In the REST API that you have described, the NAs send subscription requests to GSCLs, and the GSCLs send notifications directly to NAs. Even if NAs are registered in the NSCL, but I haven't seen NSCL participate in other procedures.
This is because what you have introduced is a simplified use case?
Thanks for any response.
Re: Usage of NSCL [message #1403812 is a reply to message #1403081] |
Sun, 27 July 2014 20:53   |
Hello hao,
The NSCL can do all the primitive procedures provided by the GSCL and more, especially that the NSCL knows the ip addresses of all authenticated GSCLs.
Here are some interesting procedures provided by the NSCL:
1) The NSCL acts as proxy to retarget NA requests to the right GSCL. NA sends request to NSCL (e.g GET http://NSCL-IP:NSCL-PORT/om2m/GSCL-ID), NSCL retargets request to GSCL, GSCL sends back response to NSCL, and NSCL retargets back response to NA. The retarget mechanism is seamless for NA. NA don't care of the GSCL IP and port.
2)The NSCL can act as proxy between several GSCLs. If we have GSCL1 and GSCL2 both authenticated to the NSCL, then a sensor connected to GSCL1 is able to send a request to an actuator connected to GSCL2 via the NSCL. GSCL1 don't care of GSCL2 IP and port (and vice versa).
3) NA can create a container on the NSCL, and use it as contactURI to subscribe to GSCL resource. The notifications will be retargeted from GSCL to NSCL and stored on the NA container.
4) A constraint GSCL can announce some applications on the NSCL. Announced resources will be created under NSCL-ID/scls collection. The GSCL benefits of an external data base to store its data. (e.g A smart meter can create all its measuring data on to NSCL)
5) A GSCL can announce some resources on the NSCL to advertise them in order to simplify their discovery by NAs. NAs will easily find, on the NSCL, links to original resources located on the GSCL.
Mahdi
Re: Usage of NSCL [message #1698595 is a reply to message #1698328] |
Tue, 16 June 2015 10:57  |
Hello Daniel,
Regarding scenario N°4 (Announcement),
The smart meter application is created locally on the gateway under GSCL/applications/SmartMeter, and an announced smart meter application is created automatically on the server under NSCL/scls/GSCL/applications/SmartMeterAnnc.
So technically yes the application is created in both, however the data is not duplicated. Two benefits here:
- SmartMeterAnnc contains only a link to SmartMeter. This enables to simplify the discovery process so an application can directly find relevant links to applications on the server without the need to search for them in each gateway.
- You can chose to store your Smart Meter data on the server since real containers could be created under an announced application such SmartMeterAnnc.
By default, the announcement is deactivated when creating an application.
You have to add the "announceTo" tag, set "activated" to true, and of course specify the SCL link where you want to announce your application (e.g. nscl).
You can update your application representation like this:
POST http://ip:port/om2m/gscl/applications
<om2m:application xmlns:om2m="http://uri.etsi.org/m2m" appId="SmartMeter">
<om2m:announceTo>
<om2m:activated>true</om2m:activated>
<om2m:sclList>
<reference>nscl</reference>
</om2m:sclList>
</om2m:announceTo>
</om2m:application>
Then you can retrieve the announced applications on the NSCL under nscl/scls/gscl/applications
GET http://ip:port/om2m/nscl/scls/gscl/applications
<om2m:applications xmlns:om2m="http://uri.etsi.org/m2m" xmlns:xmime="http://www.w3.org/2005/05/xmlmime">
<om2m:accessRightID>nscl/accessRights/AR_ADMIN</om2m:accessRightID>
<om2m:creationTime>2014-05-05T12:09:44.683+02:00</om2m:creationTime>
<om2m:lastModifiedTime>2014-05-05T12:16:11.659+02:00</om2m:lastModifiedTime>
<om2m:applicationCollection />
<om2m:applicationAnncCollection>
<om2m:namedReference id="Heating_App_001Annc">nscl/scls/gscl/applications/SmartMeterAnnc</om2m:namedReference>
</om2m:applicationAnncCollection>
<om2m:subscriptionsReference>nscl/scls/gscl/applications/subscriptions</om2m:subscriptionsReference>
<om2m:mgmtObjsReference>nscl/scls/gscl/applications/mgmtObjs</om2m:mgmtObjsReference>
</om2m:applications>
Mahdi
FUDForum. Page generated in 0.04662 seconds
