Home » Eclipse Projects » Oomph » Google authentication for gerrit/jenkins
Google authentication for gerrit/jenkins [message #1403344] |
Wed, 23 July 2014 02:56  |
i want to create Mylyn queries that check our Gerrit and Jenkins for updates.
This works fine when using normal authentication, an account with Gerrit or Jenkins itself.
However, we use our Google accounts to log into the sites. Does the Oomph setup support this, and if so, how?
Re: Google authentication for gerrit/jenkins [message #1403864 is a reply to message #1403791] |
Mon, 28 July 2014 06:36   |
No, the google authentication dialog does not pop up.
The reason is, that, in the oomph setup, there is no way for me to specify, that the connector should use google (or rather OpenId) authentication.
Maybe there is a way to specify this, but i don't know how.
If it is indeed not possible, i would humbly request as a feature the possibility to specify the authentication kind for a mylyn query.
If possible, the OpenId authentication should automatically happen with the user provided login data. If that's not possible, the authentication dialog should pop up.
Re: Google authentication for gerrit/jenkins [message #1403920 is a reply to message #1403864] |
Mon, 28 July 2014 11:06   |
Johannes,
Comments below.
> authentication.
How do you do it in the IDE manually?
Yes, we just need to understand how this is normally done.
There is some stuff in there already for a password, but I hate it. When
my password changed, it kept replacing the Mylyn-prompted password with
the one Oomph had cached. If we're going to prompt for passwords, we
should save them where the underlying technology expects to find them,
or better yet, let that technology do the prompting and saving...
Re: Google authentication for gerrit/jenkins [message #1403960 is a reply to message #1403938] |
Mon, 28 July 2014 13:52  |
Johannes,
I don't see the attachment, but in any case, it sounds like information
needed to configure the repo, so that does need to be in the task.
Please open an enhancement request.
On 28/07/2014 6:22 PM, Johannes Dorn wrote:
> When setting up a new repository, you can select "OpenID
> Authentication" under "Additional Settings". I've attached a screenshot.
> You don't have to manually type in the shown URL. Instead, the
> dropdown menu offers a selection of "Google Account" or "Yahoo
> Account" and then puts in the correct URL.
> When I used these settings, the previously mentioned authentication
> dialog seemed to pop up for half a second but then disappeared. I was
> correctly logged in then. I am not sure, if this is due to the
> username and password i supplied during the repository creation, or
> because it was already stored somewhere.
Current Time: Sun Jul 27 10:13:19 EDT 2025
Powered by FUDForum. Page generated in 0.04754 seconds
