Home » Archived » Visual Editor (VE) » UnUnderstanding of a problem in a visual class
UnUnderstanding of a problem in a visual class [message #135440] |
Thu, 01 February 2007 06:14  |
Originally posted by: immyhumi.hotmail.com
------=_Part_216_28484389.1170328661681
Content-Type: text/plain; charset=ISO-8859-1
Content-Disposition: inline
I've created the following file it shows ok but can't run and object declaration is also shown as error. what is the actual problem in this that it can't run plz tell me after review it.
imran khan.
Content-Type: application/octet-stream; name=copypastedialog.java
Content-Disposition: attachment; filename=copypastedialog.java
package Dialogs;
import Wizards.*;
import javax.swing.JPanel;
import java.awt.Frame;
import javax.swing.JDialog;
import java.awt.Dimension;
import java.awt.Color;
import javax.swing.JLabel;
import java.awt.Rectangle;
import javax.swing.ImageIcon;
import javax.swing.BorderFactory;
import java.awt.Font;
import javax.swing.JTextArea;
import javax.swing.JButton;
import java.awt.SystemColor;
public class CopyPasteDialog extends JDialog {
private static final long serialVersionUID = 1L;
private JPanel jContentPane = null;
private JLabel jLabel = null;
private JLabel jLabel1 = null;
private JTextArea jTextArea = null;
private JButton btnOK = null;
* This method initializes jTextArea
* @return javax.swing.JTextArea
private JTextArea getJTextArea() {
if (this.jTextArea == null) {
try {
this.jTextArea = new JTextArea();
this.jTextArea.setBounds(new Rectangle(14, 64, 428, 181)); // Generated
this.jTextArea.setBorder(BorderFactory.createMatteBorder(1, 1, 1, 1, Color.blue)); // Generated
} catch (java.lang.Throwable e) {
return this.jTextArea;
* This method initializes btnOK
* @return javax.swing.JButton
private JButton getBtnOK() {
if (this.btnOK == null) {
try {
this.btnOK = new JButton();
this.btnOK.setBounds(new Rectangle(329, 248, 59, 22)); // Generated
this.btnOK.setBackground(Color.white); // Generated
this.btnOK.setBorder(BorderFactory.createEmptyBorder(0, 0, 0, 0)); // Generated
this.btnOK.setIcon(new ImageIcon(this.getClass().getResource("/images/ok.jpg"))); // Generated
this.btnOK.addActionListener(new java.awt.event.ActionListener() {
public void actionPerformed(java.awt.event.ActionEvent evt) {
btnOkActionPerformed(evt);
this.btnOK.addMouseListener(new java.awt.event.MouseAdapter() {
public void mouseEntered(java.awt.event.MouseEvent evt) {
btnOkMouseEntered(evt);
public void mouseExited(java.awt.event.MouseEvent evt) {
btnOkMouseExited(evt);
return this.btnOK;
private ImageClass northPanel;
/** Creates new form CopyPasteDialog */
public CopyPasteDialog(java.awt.Frame parent, boolean modal) {
super(parent, modal);
try
this.northPanel = new ImageClass("back/back1.jpg");
this.northPanel.setLayout(null);
this.northPanel.setBounds(0,0,728, 524);
this.northPanel.setVisible(true);
this.add(this.northPanel);
}catch(Exception e){/*handled in paintComponent()*/}
Dimension scrn = this.getToolkit().getScreenSize();
this.setBounds( (scrn.width-this.getWidth())/2, (scrn.height-this.getHeight())/2, this.getWidth(), this.getHeight() );
private void btnOkActionPerformed(java.awt.event.ActionEvent evt) {
setVisible(false);
private void btnOkMouseExited(java.awt.event.MouseEvent evt) {
btnOK.setIcon(new javax.swing.ImageIcon(getClass().getResource("/images/newImages/ok.gif ")));
private void btnOkMouseEntered(java.awt.event.MouseEvent evt) {
btnOK.setIcon(new javax.swing.ImageIcon(getClass().getResource("/images/newImages/ok-over.gif ")));
* @param args
java.awt.EventQueue.invokeLater(new Runnable() {
public void run() {
new CopyPasteDialog(new javax.swing.JFrame(), true).setVisible(true);
* @param owner
public CopyPasteDialog(Frame owner) {
super(owner);
this.initialize();
* This method initializes this
* @return void
private void initialize() {
this.setSize(467, 309);
this.setContentPane(this.getJContentPane());
* This method initializes jContentPane
* @return javax.swing.JPanel
private JPanel getJContentPane() {
if (this.jContentPane == null) {
this.jLabel1 = new JLabel();
this.jLabel1.setFont(new Font("Tahoma", Font.PLAIN, 12)); // Generated
this.jLabel1.setForeground(new Color(0, 153, 255)); // Generated
this.jLabel1.setBorder(BorderFactory.createEmptyBorder(0, 0, 0, 0)); // Generated
jLabel1.setBounds(new Rectangle(137, 39, 257, 24)); // Generated
this.jLabel1.setText("Paste Text Message"); // Generated
this.jLabel = new JLabel();
this.jLabel.setIcon(new ImageIcon(this.getClass().getResource("/images/InputMessage.jpg "))); // Generated
this.jLabel.setBorder(BorderFactory.createEmptyBorder(0, 0, 0, 0)); // Generated
jLabel.setBounds(new Rectangle(45, 7, 142, 31)); // Generated
this.jLabel.setText(""); // Generated
this.jContentPane = new JPanel();
this.jContentPane.setLayout(null);
this.jContentPane.setBackground(SystemColor.control); // Generated
this.jContentPane.add(this.jLabel, null); // Generated
this.jContentPane.add(this.jLabel1, null); // Generated
this.jContentPane.add(this.getJTextArea(), null); // Generated
this.jContentPane.add(this.getBtnOK(), null); // Generated
jContentPane.add(jLabel, null); // Generated
jContentPane.add(jLabel1, null); // Generated
return this.jContentPane;
} // @jve:decl-index=0:visual-constraint="10,10"
Content-Type: application/octet-stream; name=copypastexml.java
Content-Disposition: attachment; filename=copypastexml.java
package Dialogs;
public class CopyPasteXML extends JDialog {
* @param owner
public CopyPasteXML(Frame owner) {
super(owner);
this.initialize();
* @return void
this.setSize(487, 374);
this.jLabel1.setBounds(new Rectangle(90, 36, 258, 30)); // Generated
this.jLabel1.setText("Paste XML Message"); // Generated
this.jLabel.setBounds(new Rectangle(7, 2, 149, 32)); // Generated
try {
this.jTextArea.setBounds(new Rectangle(16, 75, 441, 224)); // Generated
this.jTextArea.setBorder(BorderFactory.createLineBorder(Syst emColor.activeCaption, 1)); // Generated
// TODO: Something
try {
this.btnOK.setBounds(new Rectangle(374, 304, 63, 30)); // Generated
this.btnOK.setBackground(SystemColor.control); // Generated
CopyPasteXML.this.btnOkActionPerformed(evt);
CopyPasteXML.this.btnOkMouseEntered(evt);
CopyPasteXML.this.btnOkMouseExited(evt);
// TODO: Something
return this.btnOK;
this.setVisible(false);
this.btnOK.setIcon(new javax.swing.ImageIcon(this.getClass().getResource("/images/newImages/ok.gif ")));
this.btnOK.setIcon(new javax.swing.ImageIcon(this.getClass().getResource("/images/newImages/ok-over.gif ")));
public void run() {
new CopyPasteXML(new javax.swing.JFrame(), true).setVisible(true);
------=_Part_216_28484389.1170328661681--
Current Time: Sat Jul 26 20:38:46 EDT 2025
Powered by FUDForum. Page generated in 0.03588 seconds
