Home » Eclipse Projects » Eclipse Scout » Deploying RAP product target(HTTP 403 error)
Deploying RAP product target [message #1403581] Thu, 24 July 2014 09:48 Go to next message
I have a basic RAP scout app which works perfectly on the local machine under eclipse. I am using DataSourceSecurityFilter and everything is fine.
When I deploy to the live target or any machine other than the eclipse environment the problems start.
The browser displays the login dialog and then I get a blank screen. Looking at the tomcat access log I get a 403 error on all my GETS
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/res/html-styles.css HTTP/1.1" 403 961
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/res/eclipseScoutBackground.png HTTP/1.1" 403 961
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/res/loading.gif HTTP/1.1" 403 961
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/rwt-resources/rap-client.js HTTP/1.1" 403 961
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/rwt-resources/resources.js HTTP/1.1" 403 961
192.168.0.17 - - [24/Jul/2014:14:33:46 +0100] "GET /bindersWeb/rwt-resources/web-resources/ca-16.png HTTP/1.1" 403 961
My RAP plugin has the DataSourceSecurityFilter defined below, is there an alias problem? if so how does it work on the local machine?? I tried changing the /web alias to just / with the same result.
Any ideas????
/Dominic
    </filter>
      <filter
            aliases="/web"
            class="org.eclipse.scout.http.servletfilter.security.DataSourceSecurityFilter"
            ranking="40">
         <init-param
               name="active"
               value="true">
         </init-param>
[Updated on: Thu, 24 July 2014 10:09] by Moderator
Re: Deploying RAP product target [message #1403592 is a reply to message #1403581] Thu, 24 July 2014 10:10 Go to previous messageGo to next message
Just updated the alias for the security filter to "/ /web" ... still no luck
Re: Deploying RAP product target [message #1694948 is a reply to message #1403592] Sun, 10 May 2015 06:32 Go to previous messageGo to next message
i experience the same problem even when i totally deactivate all filters on my app.
it fails at export time on both installed tomcat 7.0.52 & jetty 9.2.10
note: everything worked fine a short time ago ... with probably an old increment of tomcat 7 (that i unfortunatelly forgot due to regular updates of my linux system)
any help would be very appreciated! Wink
Re: Deploying RAP product target [message #1695640 is a reply to message #1694948] Mon, 18 May 2015 06:18 Go to previous message
not doing basic, or ldap, db or anonymous authentification, I wrote my own auth filter (where HttpServletRequest#getUserPrincipal() & HttpServletRequest#getRemoteUser() returns null wich is normal for my business), so I had to deactivate the HttpAuthJaasFilter in my production config.ini file like this:
org.eclipse.scout.rt.server.commons.servletfilter.helper.HttpAuthJaasFilter#active=false
[Updated on: Mon, 18 May 2015 06:52] by Moderator
Previous Topic:Scout M7: Require-Bundle: org.eclipse.rap.fileupload
Next Topic:RAP: Open File (pdf, xls,...) openUrlInBrowser
Current Time: Fri Jul 25 23:50:41 EDT 2025
Powered by FUDForum. Page generated in 0.04001 seconds
