Home » Eclipse Projects » NatTable » Selecting the entire row
Selecting the entire row [message #1403242] Tue, 22 July 2014 11:18 Go to next message
How can i implement complete row selection, Multi row selection
Only cell is getting selected.
I have a context menu contribution to Nattable which is on a view.
I would like the entire row selection whenever i left click or right click on a row.
Can any help me to solve.
Re: Selecting the entire row [message #1403245 is a reply to message #1403242] Tue, 22 July 2014 11:21 Go to previous messageGo to next message
Use the RowSelectionModel. There are several examples in the examples application.
Re: Selecting the entire row [message #1403566 is a reply to message #1403245] Thu, 24 July 2014 08:39 Go to previous messageGo to next message
Thanks for the reply. It worked.
Now i have a another problem where in i have to select the entire row on right click.
I tried
natTable.getUiBindingRegistry().registerMouseDownBinding(MouseEventMatcher.bodyRightClick(SWT.NONE), new SelectRowAction());
It does not call the action all.
Also tried this one.
uiBindingRegistry.registerFirstMouseDownBinding(new MouseEventMatcher(SWT.NONE, GridRegion.BODY, MouseEventMatcher.RIGHT_BUTTON), new IMouseAction()
ViewportSelectRowAction selectRowAction = new ViewportSelectRowAction(false, false);
public void run(NatTable natTable, MouseEvent event)
int rowPosition = LayerUtil.convertRowPosition(natTable, natTable.getRowPositionByY(event.y), selectionLayer);
if (!selectionLayer.isRowPositionSelected(rowPosition))
selectRowAction.run(natTable, event);
Run method itself doesnot get called.
Can someone help me.
Re: Selecting the entire row [message #1403572 is a reply to message #1403566] Thu, 24 July 2014 09:06 Go to previous messageGo to next message
Not sure but I think the following code should work. Or using registerFirstSingleClickBinding when you want to override already registered actions.
uiBindingRegistry.registerSingleClickBinding(new MouseEventMatcher(MouseEventMatcher.RIGHT_BUTTON), new ViewportSelectRowCommand(natTable,
    false,
    false));
Re: Selecting the entire row [message #1403585 is a reply to message #1403572] Thu, 24 July 2014 09:52 Go to previous messageGo to next message
It works but another question.
If i have mutiple Mouse event binding registered how does it work?
Eg i have some thing like following:
natTable.addConfiguration(new AbstractUiBindingConfiguration()
public void configureUiBindings(UiBindingRegistry uiBindingRegistry)
PopupMenuAction(bodyMenu));
uiBindingRegistry.registerFirstSingleClickBinding(new MouseEventMatcher(SWT.NONE, GridRegion.BODY, MouseEventMatcher.RIGHT_BUTTON), new IMouseAction()
System.out.println("Position is " + rowPosition);
In this case if i right click on the row it does not get selected.
If i have only one binding it works fine, m oment i inroduce other one it just shows the popup menu, but does not get selected.
I want both action to be preformed when i right click on the row\
i.e row selection and context menu popup.
Please help me to achieve that.
Re: Selecting the entire row [message #1403589 is a reply to message #1403585] Thu, 24 July 2014 10:05 Go to previous messageGo to next message
It doesn't work that way. You need to create a custom action that performs both, selecting the row and opening the menu.
Re: Selecting the entire row [message #1403596 is a reply to message #1403589] Thu, 24 July 2014 10:13 Go to previous messageGo to next message
Can you please help me hpw the custom actions looks like?
As you already seen i tried using the custom action bu implementing IMouseAction like as shown below.
But in this case run method is never get called.
Please let me know if i am worng in implementing custom action.
Re: Selecting the entire row [message #1403599 is a reply to message #1403596] Thu, 24 July 2014 10:18 Go to previous messageGo to next message
Create an action like this
public class SelectAndOpenMenuAction implements IMouseAction {
  private Menu menu;
  public SelectAndOpenMenuAction(Menu menu) {
    this.menu = menu;
  public void run(NatTable natTable, MouseEvent event) {
    //execute the command for selecting a row
    if (natTable.doCommand(new ViewportSelectRowCommand(natTable,
        false,
        false))) {
        //open the configured menu (identical to PopupMenuAction)
        menu.setData(event.data);
        menu.setVisible(true);
and register like this
uiBindingRegistry.registerSingleClickBinding(new MouseEventMatcher(GridRegion.ROW_HEADER, MouseEventMatcher.RIGHT_BUTTON), new SelectAndOpenMenuAction(deleteMenu));
Thats how it will look like in my upcoming tutorial.
Re: Selecting the entire row [message #1403600 is a reply to message #1403599] Thu, 24 July 2014 10:22 Go to previous message
Thank you so much i did it in this way and it is working.
natTable.getUiBindingRegistry().registerMouseDownBinding(MouseEventMatcher.bodyRightClick(SWT.NONE), new IMouseAction()
bodyMenu.setVisible(true);
new SelectRowAction().run(natTable, event);
Previous Topic:Sorting Nattable based on column
Next Topic:Mutiple selection By holding control Key
Current Time: Sat Jul 26 21:43:36 EDT 2025
Powered by FUDForum. Page generated in 0.05105 seconds
