Home » Modeling » TMF (Xtext) » Xtext maven and Xcore model
Xtext maven and Xcore model [message #1403232] Tue, 22 July 2014 10:31 Go to next message
I am using Xtext 2.6 and I have a grammar which uses an Xcore model contained within the same project as the grammar.
Now I want to generate my DSL with Maven and I followed the instructions in the Xtext documentation.
I managed to generate Java classes from my Xcore model and then the generation of the grammar is started, but fails, because the path to my Xcore model is unmapped:
The path '/com.hlag.fit.sql/model/FitSql.xcore' is unmapped
I did try to map it to classpath:, but then I get an error that the src folder under C:\{Path to my JRE\ext is not accessible (which is true, as I am not admin on my PC).
What resource does Xtext try load from this strange location?
Does somebody have a working Maven example with an Xcore model in the same project?
Jan
Re: Xtext maven and Xcore model [message #1403446 is a reply to message #1403232] Wed, 23 July 2014 13:31 Go to previous messageGo to next message
> same project?
Yes :) here it is:
https://github.com/LorenzoBettini/xsemantics/blob/tycho/plugins/it.xsemantics.dsl/pom.xml
but I'm not using the method in the documentation: I use the fornax
plugin to run the mwe2 workflow (also for the Xtext artifacts), so that
I don't have to change the mwe2. In the above pom the first mwe2
generates the emf-gen with Xcore.
Hope this helps
Lorenzo
HOME: http://www.lorenzobettini.it
Xtext Book:
http://www.packtpub.com/implementing-domain-specific-languages-with-xtext-and-xtend/book
Re: Xtext maven and Xcore model [message #1403578 is a reply to message #1403446] Thu, 24 July 2014 09:39 Go to previous message
Yes, it did help a lot. But I also figured out, that for the workflow to work correctly I need the .project file in my project build directory, which I figured was not necessary for the Maven build. But now it works.
Jan
Previous Topic:org.eclipse.xtext.parser.impl.PartialParsingHelper - Invalid replace region [0 / length: 30]
Next Topic:XtextDocument Resource empty after getContents()
Current Time: Sun Jul 27 09:37:58 EDT 2025
Powered by FUDForum. Page generated in 0.03350 seconds
