Home » Eclipse Projects » Sirius » Model operation for adding reference
Model operation for adding reference [message #1403536] Thu, 24 July 2014 06:13 Go to next message
In the model operation, I did not see any function to add reference to the model element.
For example
model element A have a reference to model element B
I created element A using tool and used the model operation SET to set its featuere 'name' accordingly.
But what operation should i use to add the reference to B.
Any help much appreciated
Arun
Re: Model operation for adding reference [message #1403544 is a reply to message #1403536] Thu, 24 July 2014 06:32 Go to previous messageGo to next message
To display a reference on your diagram you will need an edge mapping
using the mapping you created to represent your model element A and B as
source/target. See Documentation "Sirius Specifier
Manual/Diagrams/Layers and Graphical Elements/Edges" for futher details
on Edge Mappings. You can also check into the tutorial part
https://wiki.eclipse.org/Sirius/Tutorials/4MinTutorial#Add_a_Relation_Based_Edge.
Then, to be able to add a reference from model element A to model
element B, you will need to add an "Edge Creation" tool referencing your
"Edge Mapping". See Documentation "Sirius Specifier
Manual/Diagrams/Layers and Graphical Elements/Edges/Edge Tools" for
futher details on Edge Mappings.
> the model element.
> For example
> Arun
Re: Model operation for adding reference [message #1403548 is a reply to message #1403536] Thu, 24 July 2014 06:43 Go to previous messageGo to next message
> the model element.
> For example
You can use a Set operation too, in the reference, you just enter the
name of the EReference in your meta-model. Then in the value expession,
you put an expression whose result is B, for example var:target, if you
are in a tool which defined a varable named target which is your B.
> Arun
Maxime
Re: Model operation for adding reference [message #1403559 is a reply to message #1403548] Thu, 24 July 2014 07:57 Go to previous message
Thanks Maxime and Steve.
It worked!
Previous Topic:Creating some part of models textually
Next Topic:preTarget variable not available in Connection Complete Precondition
Current Time: Sun Jul 27 09:05:46 EDT 2025
Powered by FUDForum. Page generated in 0.18165 seconds
