Home » Eclipse Projects » EclipseLink » Cache coordination with tomcat 6
Cache coordination with tomcat 6 [message #1403418] Wed, 23 July 2014 10:39 Go to next message
I'm trying to use EclipseLink cache coordination within my tomcat 6 application. I'm using activeMQ which already works find in my environment. In my server.xml I've defined the following Resources:
 <Resource
        auth="Container"
        brokerURL="tcp://jms:61616?daemon=true"
        description="JMS Connection Factory"
        factory="org.apache.activemq.jndi.JNDIReferenceFactory"
        name="jms/connectionFactory"
        type="org.apache.activemq.ActiveMQConnectionFactory"
    <Resource
        description="Change Notification Topic"
        name="jms/changeNotification"
        physicalName="T.SERVICE.INT"
        type="org.apache.activemq.command.ActiveMQTopic"
And my persistence.xml looks like this:
<property name="eclipselink.cache.coordination.protocol" value="jms" />
<property name="eclipselink.cache.coordination.jms.topic" value="jms/changeNotification" />
<property name="eclipselink.cache.coordination.jms.factory" value="jms/jmsConnectionFactory" />
If I startup my tomcat I get the following exception:
[EL Warning]: 2014-07-23 16:19:35.146--ServerSession(1669472530)--Exception [EclipseLink-22103] (Eclipse Persistence Services - 2.4.1.v20121003-ad44345): org.eclipse.persistence.exceptions.RemoteCommandManagerException
Exception Description: Could not look up remote connection under name jms/jmsConnectionFactory with URL null
Internal Exception: javax.naming.NameNotFoundException: Name jms is not bound in this Context
Any ideas what's wrong? Is it possible with tomcat anyways? Could not find any information about it in the www. Smile
Greetings,
Sascha
[Updated on: Wed, 23 July 2014 13:36] by Moderator
Re: Cache coordination with tomcat 6 [message #1403496 is a reply to message #1403418] Thu, 24 July 2014 03:57 Go to previous messageGo to next message
Ok, small update. This did the trick inside the persistence.xml
<property name="eclipselink.cache.coordination.jms.topic" value="java:comp/env/jms/changeNotification" />
<property name="eclipselink.cache.coordination.jms.factory" value="java:comp/env/jms/connectionFactory" />
But... it seems EclipseLink is not sending any notifications via JMS. I can't see the cache coordination working in my logging.
Any assistance? Smile
Greetings,
Sascha
[Updated on: Thu, 24 July 2014 04:59] by Moderator
Re: Cache coordination with tomcat 6 [message #1403515 is a reply to message #1403496] Thu, 24 July 2014 05:21 Go to previous message
It seems that EclipseLink JMS Connection is established but EclipseLink is not sending any sync messages. Entities are configured correctly I guess:
@Cacheable(true)
@Cache(type = CacheType.FULL, coordinationType = CacheCoordinationType.SEND_NEW_OBJECTS_WITH_CHANGES)
If I send a text message manually via activeMQ EclipseLink is responding in my logging with:
[EL Warning]: 2014-07-24 11:20:24.706--ServerSession(992328659)--Received unexpected message type: org.apache.activemq.command.ActiveMQTextMessage from topic: T.SERVICE.INT; ignoring
So it seems EclipseLink is listening via JMS, but why isn't it sending any sync messages?
Greetings,
Sascha
Previous Topic:Same code not working same way in JSE as in JEE
Next Topic:Running JPA entity with native queries from TestNG
Current Time: Wed Jul 23 12:57:10 EDT 2025
Powered by FUDForum. Page generated in 0.27618 seconds
