Home » Modeling » Papyrus » [Alf Editor] Where is it ?(Cannot access to the alf editor with Papyrus 0.9 (eclipse juno))
icon5.gif  [Alf Editor] Where is it ? [message #892279] Wed, 27 June 2012 11:08 Go to next message
I can't access to the new Alf editor :
It seems to be installed but I can not access it as in the previous version by clicking on the class operation and selecting "Edit Operation >> using ALF Editor".
Thanks for any help.
Re: [Alf Editor] Where is it ? [message #892283 is a reply to message #892279] Wed, 27 June 2012 11:17 Go to previous messageGo to next message
Hello Jean,
I don't think we ever shipped this editor with Papyrus (Even during milestones). The Operation editor is still available as an Extra plug-in, which can only be retrieved from the SVN repository.
The operation editor (org.eclipse.papyrus.operation.editor.xtext + org.eclipse.papyrus.operation.editor.xtext.ui) relies on Alf, but it is not (currently) part of it.
What do you mean by "previous version" ? Alf wasn't shipped at all with Papyrus, until now.
Camille
Re: [Alf Editor] Where is it ? [message #892472 is a reply to message #892283] Thu, 28 June 2012 07:21 Go to previous messageGo to next message
actually, after verification, I got Alf from another repository:
"http: www.math.unipd.it/~azovi/CHESS/CHESS_3.1"
The presence of Alf in "preferences>>Embedded Editors" misled me, sorry.
Re: [Alf Editor] Where is it ? [message #987406 is a reply to message #892472] Mon, 26 November 2012 08:49 Go to previous messageGo to next message
i'm stuck with the same problem. Can't use the alf editor in papyrus. You said the editor can be retrieved from a svn repository. Where do i find that?
Regards and thanks in advance,
Thomas
Re: [Alf Editor] Where is it ? [message #987408 is a reply to message #892279] Mon, 26 November 2012 09:02 Go to previous messageGo to next message
For Papyrus Juno (0.9.X on Eclipse 3.8.X / 4.2.X):
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/branches/0.9.X/extraplugins/alf/org.eclipse.papyrus.operation.editor.xtext
http://dev.eclipse.org/svnroot/modeling/org.eclipse.mdt.papyrus/branches/0.9.X/extraplugins/alf/org.eclipse.papyrus.operation.editor.xtext.ui
Camille
Re: [Alf Editor] Where is it ? [message #987641 is a reply to message #987408] Tue, 27 November 2012 07:07 Go to previous messageGo to next message
Thank you for the links. I checked the folders out (also the feature) copied them into the respective plugin and features folder and restarted eclipse using -clean.
The editor cannot be used still. It also seems that loading the plugins failed. Anyone had the same problem and has a solution at hand?
best regards
Re: [Alf Editor] Where is it ? [message #987642 is a reply to message #987641] Tue, 27 November 2012 07:11 Go to previous messageGo to next message
You should never modify the plugins/ and feature/ folders manually. You should use the Eclipse installation wizard (e.g. on each plug-in: Export / Deployable plug-ins / Install into host)
Camille
Re: [Alf Editor] Where is it ? [message #987732 is a reply to message #987642] Tue, 27 November 2012 14:23 Go to previous messageGo to next message
Alright that worked. But now I have again a problem with the dependencies of the org.eclipse.papyrus.operation.editor.xtext and the org.eclipse.papyrus.operation.editor.xtext.ui plugin.
Namely the following plugins are required but could not be found:
org.eclipse.papyrus.alf;bundle-version="0.9.1"
org.eclipse.papyrus.core;bundle-version="0.9.1"
org.eclipse.papyrus.properties.runtime;bundle-version="0.9.1"
org.eclipse.papyrus.alf.ui;bundle-version="0.9.1"
org.eclipse.papyrus.diagram.common;bundle-version="0.9.1"
org.eclipse.papyrus.profile;bundle-version="0.9.1"
I've installed papyrus using the update sites for juno. The plugins were not included. Once again i'm wondering if there exists a repository where i can get those plugins i require. does anyone know help?
best regards
Re: [Alf Editor] Where is it ? [message #1385953 is a reply to message #987732] Thu, 12 June 2014 08:54 Go to previous messageGo to next message
I'm also trying to install the ALF-Editor and stuck at the same place. Does anyone found an easy way to install the editor in the current Papyrus (for Eclipse Kelper) version?
Alex
Re: [Alf Editor] Where is it ? [message #1403510 is a reply to message #1385953] Thu, 24 July 2014 05:04 Go to previous message
Some information about this topic are available here: https://www.eclipse.org/forums/index.php/t/677538/
Arnaud
Previous Topic:Content of .di-file in Luna
Next Topic:Alf Editor problem in Keppler
Current Time: Wed Jul 23 04:37:06 EDT 2025
Powered by FUDForum. Page generated in 0.12946 seconds
