Home » Eclipse Projects » BPMN 2.0 Modeler » using Sequence Flow in graphiti
using Sequence Flow in graphiti [message #1403451] Wed, 23 July 2014 15:18 Go to next message
We use Graphiti Api to develop our models.The Sequence flow connection is not available in Graphiti.Is there a way we could use BPMN2 sequence connection api in graphiti?.
Re: using Sequence Flow in graphiti [message #1403462 is a reply to message #1403451] Wed, 23 July 2014 17:09 Go to previous messageGo to next message
I'm guessing you're talking about the Manhattan Routing algorithm that is being used by default for Sequence Flows, correct? This is actually implemented as a Layout Feature on the BPMN2 model objects that represent these types of connections. You have no idea how insanely difficult this was Wink
Please have a look at the class ManhattanConnectionRouter. This is the thing that calculates the FreeFormConnection bend points (with collision detection, oooh, ahhh!) that make up the orthogonal line segments.
The algorithm has just recently been updated for "better behavior", and you can test this out with the nightly build of the BPMN2 Modeler.
Bob
Re: using Sequence Flow in graphiti [message #1403464 is a reply to message #1403462] Wed, 23 July 2014 17:29 Go to previous messageGo to next message
yes. But you didn't answer if I could use the BPMN2 manhattan router in graphiti .We don't use bpmn but we need the connector similar to the one used in BPMN2.
Re: using Sequence Flow in graphiti [message #1403466 is a reply to message #1403464] Wed, 23 July 2014 17:56 Go to previous message
Sure...go for it. I'm not sure what you're asking. The source code is open source subject to eclipse licensing, so...
I was saying that the Manhattan router algorithm you see is written as an UpdateFeature as part of the BPMN2 Modeler editor. Maybe you need to go through the Graphiti tutorials to learn what an Update Feature is?
Previous Topic:BPMN Modeler in Luna problem
Next Topic:Customize import dialog
Current Time: Tue Jul 22 23:00:34 EDT 2025
Powered by FUDForum. Page generated in 0.05020 seconds
