Home » Modeling » TMF (Xtext) » Action for a context menu on XtextEditor
Action for a context menu on XtextEditor [message #1403378] Wed, 23 July 2014 07:13 Go to next message
Hi everyone,
I am trying to implement a pop-up menu with an action for any kind of XtextEditors.
My plugin-configuration looks like this:
<plugin>
   <extension
         id=" Xtext Action"
         name="Xtext Action menu"
         point="org.eclipse.ui.popupMenus">
      <viewerContribution
            id="simple.editor.action.viewerContribution1"
            targetID="#TextEditorContext">
         <visibility>
            <objectClass
                  name="org.eclipse.jface.text.ITextSelection">
            </objectClass>
         </visibility>
         <action
               class="simple.editor.action.Action1"
               id="simple.editor.action.action1"
               label="Annotate xtext element"
               menubarPath="additions">
         </action>
      </viewerContribution>
   </extension>
</plugin>
The pop-up menu works fine, but only on every kind of texteditor (and not only for XtextEditors) (see : targetID="#TextEditorContext"). Is there maybe a targetID for only XtextEditors? I explored the XtextEditor in the runtime-workbench and found the following informations:
https://dl.dropboxusercontent.com/u/18688378/eclipseCoding/ids/xtexteditor.jpg
Maybe someone has any ideas how to solve this?
~Alex
[Updated on: Wed, 23 July 2014 11:20] by Moderator
Re: Action for a context menu on XtextEditor [message #1403416 is a reply to message #1403378] Wed, 23 July 2014 10:24 Go to previous messageGo to next message
what happens if you use
targetID="org.eclipse.xtext.example.domainmodel.Domainmodel.EditorContext"
instead of
in your plugin.xml ?
~Thomas
Re: Action for a context menu on XtextEditor [message #1403421 is a reply to message #1403378] Wed, 23 July 2014 11:19 Go to previous messageGo to next message
that's not the point. I want that the popup menu appears in EVERY XtextEditor for EVERY kind of DSL, wich is written in Xtext. Not for a specific XtextEditor, but for every XtextEditor.
To answer your question:
The popup menu would appear only in the editor of this specific Domainmodel-DSL.
~Alex
Re: Action for a context menu on XtextEditor [message #1403436 is a reply to message #1403421] Wed, 23 July 2014 12:14 Go to previous messageGo to next message
Ok, sorry for my misunderstanding.
To your original question:
I think it boils down to registering a new context menu id (in addition to "#TextEditorContext" and "#AbstractTextEditorContext") to a subclass of XtextEditor (or the XtextEditor itself).
Something similar to what is done in class org.eclipse.ui.texteditor.AbstractTextEditor in method createPartControl(Composite):
getEditorSite().registerContextMenu("#XtextEditorContext", ...);
But I must admit, I'm running out of knowledge here.
Btw: Thanks for pointing out the Plug-in Selection Spy. I wish I found this tool earlier.
~Thomas
Re: Action for a context menu on XtextEditor [message #1802559 is a reply to message #1403436] Mon, 11 February 2019 16:12 Go to previous message
Hi Alexander,
Can you share with me the content of the class Action1?
[Updated on: Mon, 11 February 2019 16:12] by Moderator
Previous Topic:Loading classes in Xbase-based DSL with interpreter
Next Topic:Cross reference problem with rename element
Current Time: Mon Jul 21 03:52:38 EDT 2025
Powered by FUDForum. Page generated in 0.10182 seconds
