Home » Modeling » EMF » Is it possible to exclude certain features from EMF Java code generation?
Is it possible to exclude certain features from EMF Java code generation? [message #1403410] Wed, 23 July 2014 10:03 Go to next message
we use a single ecore model for the configuration of two very similar products. From this model we generate C++ and Visual Basic code for product P1. And we generate C++, LotusScript and Java code for product P2 from it. For the Java code generation we use the code generation built into EMF.
Now we have the situation that for product P1 we would need a bidirectional 0..n to 0..1 reference between class A and class B. However, for product P2 we would need only a directed 0..1 reference from class A to class B.
Is there a way to mark (e.g. using a annotaion) the opposite reference (the 0..n reference from B to A) so that it is ignored in the Java code generation?
Thanks in advance for your help
Reinhold
Re: Is it possible to exclude certain features from EMF Java code generation? [message #1403434 is a reply to message #1403410] Wed, 23 July 2014 12:06 Go to previous messageGo to next message
Reinhold,
No, what you define in the Ecore model is what you get. Are these
bidirectional references proxy resolving, i.e., to they cross resource
boundaries? It sounds like not only don't you need the bidirectional
reference in P2 but it's presence is a problem. Why is that?
On 23/07/2014 4:03 PM, Reinhold Bihler wrote:
> Hello,
> built into EMF.
> code generation?
> Reinhold
Re: Is it possible to exclude certain features from EMF Java code generation? [message #1403493 is a reply to message #1403434] Thu, 24 July 2014 03:49 Go to previous message
Hi Ed,
the references are not proxy resolving. However, for product P2 we wrote a generic EMF to Lotus Domino Database serialization. Domino Databases are document oriented. Each document has a unique id. But there is no real reference concept not to mention checks for referential integrity.
Normally we store one object in one document. A reference to another object is stored as the unique id of the referenced document in a field of the referencing document. As we cannot always control document deletion there occur situations where a reference is pointing to a deleted document..
That is why we try to avoid unnecessary references for product P2.
So I think we will add a special annotation to the reference and extend the Domino serialization to ignore references with this annotation.
Thanks for your help Ed
Reinhold
Previous Topic:Problem parsing XML elements when loading XML schemas with EMF
Next Topic:Transactions API: determine if running in a transaction
Current Time: Wed Jul 30 07:06:59 EDT 2025
Powered by FUDForum. Page generated in 0.08662 seconds
