Home » Archived » Hudson » Writing to Test-Result from REST-Assured-Log(System.out in RESTAssured-LoggingFilter does not apply to Test-Result)
Writing to Test-Result from REST-Assured-Log [message #1403366] Wed, 23 July 2014 05:39
Hi guys,
when I'm using System.out inside of a Test (JUNIT/RestAssured) the output is written to the Test-Result in Hudson.
RestAssured (which I use to test a REST-API) provides Filters for Requests and Responses and uses a PrintStream (by default System.out) for the output.
Unfortunately the output is written inside the Console Output but not in the Test results.
I tried to create a new instance of PrintStream with System.out which I passed to Rest-Assured because I thought "maybe the System.out has to come from the Test itself" - but without success.
   public static PrintStream stream = new PrintStream(System.out);
   @BeforeClass
   public static void startUp() {
      RestAssured.filters(new RequestLoggingFilter(stream), new ResponseLoggingFilter(stream));
Is there an option to get some output of the PrintStream inside of the Logger to the Test-Result?
[Updated on: Thu, 24 July 2014 03:57] by Moderator
Previous Topic:Can't really kill a job
Next Topic:Auto Deployment
Current Time: Mon Jul 21 06:02:53 EDT 2025
Powered by FUDForum. Page generated in 0.03454 seconds
