Home » Eclipse Projects » Eclipse Scout » Decorating a boolean column with SWT
Decorating a boolean column with SWT [message #1403173] Tue, 22 July 2014 02:56 Go to next message
In our application we would like to replace the checkboxes in a bolean column with a red dot or a green checkmark instead of the normal checkbox when displaying a value.
I've tried using execDecorateCell() to do this (using cell.setIconId() depending on the getValue() of the column). However, this does not seem to have any effect with SWT. I know that Scout "abuses" the icon in ListFields and TreeFields to render checkboxes and can therefore not display an icon for those (unlike Swing). Is this the same issue with BooleanColumn?
If this were a read-only table I guess I could change the type of the column to an ObjectColumn and then use execDecorateCell() to render the information. However this will be an editable column so we would want to fall back on the checkbox when editing this column.
Can anyone think of a way to solve this? Would it be possible to use an ObjectColumn for display but a CheckboxField for editing? If so, how would I do this?
Re: Decorating a boolean column with SWT [message #1403193 is a reply to message #1403173] Tue, 22 July 2014 05:54 Go to previous messageGo to next message
Urs Beeli wrote on Tue, 22 July 2014 08:56
Yes... The implementation of Boolean Columns brings some problems...
We already discussed some of your issues with Boolean Columns here.
You can provide the field you need with "execPrepareEdit" (this is true for all types of Columns). Here for example I have used a smart field with a YesOrNoCodeType.
index.php/fa/18609/0/
public class MyColumn extends AbstractColumn<Boolean> {
  protected String getConfiguredHeaderText() {
    return TEXTS.get("MyColumn");
  protected boolean getConfiguredEditable() {
    return true;
  protected IFormField execPrepareEdit(ITableRow row) throws ProcessingException {
    AbstractSmartField<Boolean> f = new AbstractSmartField<Boolean>() {
      protected Class<? extends ICodeType<?, Boolean>> getConfiguredCodeType() {
        return YesOrNoCodeType.class;
    f.setValue(BooleanUtility.nvl(getValue(row)));
    return f;
To make it work, you need to use "AbstractColumn<Boolean>" instead of AbstractBooleanColumn (I do not know why). The problem you have indicated with the misusage of the Icon in the SWT implementation is still present.
Following this example I have tried something closer to what you need:
public class MyColumn extends AbstractObjectColumn {
    return true;
  protected void execDecorateCell(Cell cell, ITableRow row) throws ProcessingException {
    if (BooleanUtility.nvl((Boolean) getValue(row))) {
      cell.setIconId(Icons.Bookmark);
    else {
      cell.setIconId(Icons.Gears);
    AbstractBooleanField f = new AbstractBooleanField() {
    f.setValue((Boolean) getValue(row));
    return f;
I think we are near to what you expect. I see something that could be improved: The icon does not disappear when the field is displayed to edit the value.
index.php/fa/18610/0/
I hope writing a custom column implementation is not your only option.
[Updated on: Wed, 23 July 2014 01:37] by Moderator
Re: Decorating a boolean column with SWT [message #1403341 is a reply to message #1403193] Wed, 23 July 2014 02:15 Go to previous messageGo to next message
Jérémie
Thank you for your help with the execPrepareEdit, I'll have a look at this. As to the initial value, maybe the following will work (untested):
    f.setValue(getValue(row));
    return f;
The need for the custom column comes not from this issue. We've already implemented a TriStateField to display a checkbox with three states (true, false, indeterminate) in order to represent a TriState object. We now also need to be able to display such values in tables. One option might be to use an ObjectColumn and to then set the icons accordingly and using execPrepareEdit to use the TriStateField instead of creating a custom TristateColumn. Anyway, thanks for the link (it's a bit embarrassing to see I've asked this question before Smile, I'll have a look, though the blog article seems to focus mainly on RAP, I guess it would also work with SWT.
Re: Decorating a boolean column with SWT [message #1403343 is a reply to message #1403341] Wed, 23 July 2014 02:47 Go to previous message
I think you will be fine with AbstractColumn<TriState> similar to my example AbstractColumn<Boolean>. You do not need a custom table implementation for this.
Thank you for your pointer on the missing "setValue(..)" line. I have udpated my code snippets.
Previous Topic:Using icons in a table
Next Topic:Setting Ctrl-+ as keystroke on a table
Current Time: Wed Jul 23 11:56:24 EDT 2025
Powered by FUDForum. Page generated in 1.07096 seconds
