Home » Eclipse Projects » NatTable » NatTable Repository
NatTable Repository [message #1402914] Fri, 18 July 2014 06:40 Go to next message
i have a problem with exporting my application because i always get an exception raised, regarding the nattable repository
NOTE: i tried the downloaded .zip and the online repo. giving me both the same error
i opened the org.eclipse.nebula.widgets.nattable.core.feature_1.1.0.201405012245.jar file and found one pom inside:
META-INF\maven\org.eclipse.nebula.widgets.nattable\org.eclipse.nebula.widgets.nattable.core.feature\pom.xml
   Copyright (C) 2012, 2013 Edwin Park and others.
   All rights reserved. This program and the accompanying materials
   are made available under the terms of the Eclipse Public License v1.0
   which accompanies this distribution, and is available at
   http://www.eclipse.org/legal/epl-v10.html
<project xmlns="http://maven.apache.org/POM/4.0.0"
    xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/maven-v4_0_0.xsd">
  <modelVersion>4.0.0</modelVersion>
  <parent>
		<artifactId>parent</artifactId>
		<groupId>org.eclipse.nebula.widgets.nattable</groupId>
		<version>1.1.0-SNAPSHOT</version>
		<relativePath>../org.eclipse.nebula.widgets.nattable.parent</relativePath>
  </parent>
  <artifactId>org.eclipse.nebula.widgets.nattable.core.feature</artifactId>
  <packaging>eclipse-feature</packaging>
  <name>NatTable Core Feature</name>
</project>
but i cannot find its parent pom.xml
any ideas whats going wrong?
is it my mistake or is the repository missing something?
thanks in advance
Ludwig
Stacktrace
[ERROR]          Invalid content:META-INF/maven/org.eclipse.nebula.widgets.nattable/org.eclipse.nebula.widgets.nattable.core.feature/pom.xml
[ERROR] Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact org.eclipse.update.feature,org.eclipse.nebula.widgets.nattable.core.feature,1.1.0.201405012245 into the local Maven repository.See log output for details. A file "META-INF/maven/org.eclipse.nebula.widgets.nattable/org.eclipse.nebula.widgets.nattable.core.feature/pom.xml" has been removed from the jar: C:\Users\moser\AppData\Local\Temp\signatureFile6296829412031548512.jar -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact org.eclipse.update.feature,org.eclipse.nebula.widgets.nattable.core.feature,1.1.0.201405012245 into the local Maven repository.See log output for details.
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:167)
	at org.apache.maven.cli.MavenCli.execute(MavenCli.java:584)
	at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:213)
	at org.apache.maven.cli.MavenCli.main(MavenCli.java:157)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Launcher.java:289)
	at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.java:229)
	at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(Launcher.java:415)
	at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:356)
Caused by: org.eclipse.tycho.repository.local.MirroringArtifactProvider$MirroringFailedException: Could not mirror artifact org.eclipse.update.feature,org.eclipse.nebula.widgets.nattable.core.feature,1.1.0.201405012245 into the local Maven repository.See log output for details.
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.downloadArtifact(MirroringArtifactProvider.java:218)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.makeOneFormatLocallyAvailable(MirroringArtifactProvider.java:203)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.makeLocallyAvailable(MirroringArtifactProvider.java:174)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.getArtifactFile(MirroringArtifactProvider.java:118)
	at org.eclipse.tycho.repository.p2base.artifact.provider.CompositeArtifactProvider.getArtifactFile(CompositeArtifactProvider.java:70)
	at org.eclipse.tycho.p2.target.TargetPlatformImpl.getLocalArtifactFile(TargetPlatformImpl.java:146)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.addUnit(P2ResolverImpl.java:208)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.toResolutionResult(P2ResolverImpl.java:171)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:163)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:107)
	at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.doResolveDependencies(P2TargetPlatformResolver.java:348)
	at org.eclipse.tycho.p2.resolver.P2TargetPlatformResolver.resolveDependencies(P2TargetPlatformResolver.java:321)
	at org.eclipse.tycho.core.resolver.DefaultTychoDependencyResolver.resolveProject(DefaultTychoDependencyResolver.java:109)
	at org.eclipse.tycho.core.maven.TychoMavenLifecycleParticipant.afterProjectsRead(TychoMavenLifecycleParticipant.java:75)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:317)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:155)
	... 11 more
Caused by: org.eclipse.osgi.signedcontent.InvalidContentException: A file "META-INF/maven/org.eclipse.nebula.widgets.nattable/org.eclipse.nebula.widgets.nattable.core.feature/pom.xml" has been removed from the jar: C:\Users\moser\AppData\Local\Temp\signatureFile6296829412031548512.jar
	at org.eclipse.osgi.internal.signedcontent.SignedContentImpl$SignedContentEntryImpl.verify(SignedContentImpl.java:164)
	at org.eclipse.osgi.internal.signedcontent.SignedContentFile.getSignedEntries(SignedContentFile.java:51)
	at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verifyContent(SignatureVerifier.java:82)
	at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.verify(SignatureVerifier.java:59)
	at org.eclipse.equinox.internal.p2.artifact.repository.SignatureVerifier.close(SignatureVerifier.java:100)
	at org.eclipse.equinox.internal.provisional.p2.artifact.repository.processing.ProcessingStep.close(ProcessingStep.java:85)
	at org.eclipse.equinox.internal.provisional.p2.artifact.repository.processing.ZipVerifierStep.close(ZipVerifierStep.java:41)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.reportStatus(SimpleArtifactRepository.java:1183)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.downloadArtifact(SimpleArtifactRepository.java:591)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:723)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.getArtifactFromOneMirror(RepositoryArtifactProvider.java:209)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.getArtifactFromAnyMirror(RepositoryArtifactProvider.java:192)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.access$1(RepositoryArtifactProvider.java:187)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider$1.perform(RepositoryArtifactProvider.java:167)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifact(SimpleArtifactRepository.java:707)
	at org.eclipse.equinox.internal.p2.artifact.repository.simple.SimpleArtifactRepository.getArtifacts(SimpleArtifactRepository.java:778)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.getArtifactFromAnyChildRepository(RepositoryArtifactProvider.java:179)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.getArtifactFromAnyFormatAvailableInRepository(RepositoryArtifactProvider.java:149)
	at org.eclipse.tycho.repository.p2base.artifact.repository.RepositoryArtifactProvider.getArtifactFromAnySource(RepositoryArtifactProvider.java:135)
	at org.eclipse.tycho.repository.p2base.artifact.provider.CompositeArtifactProviderBaseImpl.getArtifact(CompositeArtifactProviderBaseImpl.java:50)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.downloadCanonicalArtifact(MirroringArtifactProvider.java:236)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.downloadMostSpecificNeededFormatOfArtifact(MirroringArtifactProvider.java:229)
	at org.eclipse.tycho.repository.local.MirroringArtifactProvider.downloadArtifact(MirroringArtifactProvider.java:214)
	... 26 more
Caused by: java.lang.SecurityException: A file "META-INF/maven/org.eclipse.nebula.widgets.nattable/org.eclipse.nebula.widgets.nattable.core.feature/pom.xml" has been removed from the jar: C:\Users\moser\AppData\Local\Temp\signatureFile6296829412031548512.jar
	at org.eclipse.osgi.internal.signedcontent.SignedBundleFile.getEntry(SignedBundleFile.java:119)
	at org.eclipse.osgi.internal.signedcontent.SignedContentImpl$SignedContentEntryImpl.verify(SignedContentImpl.java:159)
	... 48 more
Re: NatTable Repository [message #1402984 is a reply to message #1402914] Sat, 19 July 2014 02:37 Go to previous messageGo to next message
Sorry, I don't understand what is doing wrong. We haven't changed the build since a while, despite updating the version.
I also don't understand the error, as it says that the pom.xml was removed. Are you building with m2e? Or what are you doing?
Re: NatTable Repository [message #1403002 is a reply to message #1402984] Sat, 19 July 2014 12:37 Go to previous messageGo to next message
Yes i am using m2e.
i crated pom files for my application. I have a freatue which includes nattable and a lot of other plugins and features. This is exported into an update site. This update site is used when i build my own app features. Then this error message comes up. It is the only error and i cannot rrsolve it or ubderstand why it is raised at all...
Re: NatTable Repository [message #1403007 is a reply to message #1403002] Sat, 19 July 2014 13:57 Go to previous messageGo to next message
On googling I saw some similar issues regarding m2e. Did you try to build from the command line?
Re: NatTable Repository [message #1403022 is a reply to message #1403007] Sun, 20 July 2014 01:44 Go to previous messageGo to next message
Command line with m2e? I did not know rhis is possible!
Or is there a way to install tycho with maven outside of eclipse? (My problem is i do not habe admin rights on this computer. And our it staff is on holiday for 3 weeks)
Re: NatTable Repository [message #1403024 is a reply to message #1403022] Sun, 20 July 2014 02:38 Go to previous messageGo to next message
Tycho is a Maven plugin out configure as dependency in your pom. So you can execute the Maven build from command line as usual.
Re: NatTable Repository [message #1403039 is a reply to message #1403024] Sun, 20 July 2014 11:25 Go to previous messageGo to next message
Mvn is not available in my cmd/path... need to talk to our edv staff when he is back
Re: NatTable Repository [message #1404172 is a reply to message #1403039] Wed, 30 July 2014 04:54 Go to previous messageGo to next message
finally i installed maven.
when i run m2e in debug on one of my features it ends with SUCCESS
the same feature with mvn from command line ends in error not resolving 'org.eclipse.equinox.security.win32.x86'
this jar IS included in my own updatesite (but seems to be ignored) therefore i added repository
<repository>
      <id>Eclipse Kepler UpdateSite</id>
      <layout>p2</layout>
      <url>http://download.eclipse.org/releases/kepler/</url>
    </repository>
this should be fine. but still does not find the jar! (m2e was able to locate it!)
so from cmd i do not even reach the problem, which i mentioned in the beginning of the thread. *frown*
just for completeness here is the Log from mvn clean install in my command line (on feature at.biooffice.feature)
[INFO] Scanning for projects...
[WARNING] No explicit target runtime environment configuration. Build is platform dependent.
[INFO] Computing target platform for MavenProject: biooffice:at.biooffice.feature:1.0.0-SNAPSHOT @ D:\Java7\Workspace3\at.biooffice.feature\pom.xml
[INFO] Fetching p2.index from http://download.eclipse.org/releases/kepler/ (0B at 0B/s)
[INFO] Adding repository http://download.eclipse.org/releases/kepler
[INFO] Fetching p2.index from http://download.eclipse.org/releases/kepler/201402280900/ (0B at 0B/s)
[INFO] Fetching p2.index from http://download.eclipse.org/releases/kepler/201309270900/ (0B at 0B/s)
[INFO] Fetching p2.index from http://download.eclipse.org/releases/kepler/201306260900/ (0B at 0B/s)
[INFO] Fetching p2.index from http://download.eclipse.org/technology/epp/packages/kepler/ (0B at 0B/s)
[INFO] Adding repository file:/D:/Java7/Workspace3/UpdateSite
[INFO] Resolving dependencies of MavenProject: biooffice:at.biooffice.feature:1.0.0-SNAPSHOT @ D:\Java7\Workspace3\at.biooffice.feature\pom.xml
[INFO] Cannot complete the request.  Generating details.
[INFO] {osgi.os=win32, osgi.ws=win32, org.eclipse.update.install.features=true, osgi.arch=x86_64}
[ERROR] Cannot resolve project dependencies:
[ERROR]   Software being installed: at.biooffice.feature.feature.group 1.0.0.qualifier
[ERROR]   Missing requirement: at.biooffice.feature.feature.group 1.0.0.qualifier requires 'org.eclipse.equinox.security.win32.x86 0.0.0' but it could not be found
[ERROR]
[ERROR] Internal error: java.lang.RuntimeException: No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from at.biooffice.feature.feature.group 1.0.0.qualifier to org.eclipse.equinox.security.win32.x86 0.0.0.; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.0.v_OTDT_r220_201306071800 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.1.v_OTDT_r221_201309101918 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.2.v_OTDT_r222_201402180730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; No solution found because the problem is unsatisfiable.] -> [Help 1]
org.apache.maven.InternalErrorException: Internal error: java.lang.RuntimeException: No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from at.biooffice.feature.feature.group 1.0.0.qualifier to org.eclipse.equinox.security.win32.x86 0.0.0.; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.0.v_OTDT_r220_201306071800 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.1.v_OTDT_r221_201309101918 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.2.v_OTDT_r222_201402180730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; No solution found because the problem is unsatisfiable.]
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:166)
	at java.lang.reflect.Method.invoke(Method.java:483)
Caused by: java.lang.RuntimeException: No solution found because the problem is unsatisfiable.: [Unable to satisfy dependency from at.biooffice.feature.feature.group 1.0.0.qualifier to org.eclipse.equinox.security.win32.x86 0.0.0.; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.0.v_OTDT_r220_201306071800 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.1.v_OTDT_r221_201309101918 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; Unable to satisfy dependency from org.eclipse.jdt.core 3.9.2.v_OTDT_r222_201402180730 to org.eclipse.objectteams.otdt.core.patch.feature.group [2.0.0,3.0.0).; No solution found because the problem is unsatisfiable.]
	at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.newResolutionException(AbstractResolutionStrategy.java:98)
	at org.eclipse.tycho.p2.resolver.ProjectorResolutionStrategy.resolve(ProjectorResolutionStrategy.java:88)
	at org.eclipse.tycho.p2.resolver.AbstractResolutionStrategy.resolve(AbstractResolutionStrategy.java:63)
	at org.eclipse.tycho.p2.impl.resolver.P2ResolverImpl.resolveDependencies(P2ResolverImpl.java:157)
	at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:310)
	at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:154)
	... 11 more
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e switch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please read the following articles:
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/InternalErrorException
and this is the log from debug m2e clean install
[INFO] Fetching &countryCode=at&timeZone=1&format=xml from http://www.eclipse.org/downloads/download.php?format=xml&file=/releases/kepler/201402280900/ (0B at 0B/s)
[INFO] Fetching org.eclipse.equinox.concurrent_1.1.0.v20130327-1442.jar.pack.gz from http://download.eclipse.org/releases/kepler/201402280900/plugins/ (0B of 11,04kB at 0B/s)
[INFO] Resolving class path of MavenProject: biooffice:at.biooffice.feature:1.0.0-SNAPSHOT @ D:\Java7\Workspace3\at.biooffice.feature\pom.xml
[INFO]
[INFO] Using the builder org.apache.maven.lifecycle.internal.builder.singlethreaded.SingleThreadedBuilder with a thread count of 1
[INFO]
[INFO] ------------------------------------------------------------------------
[INFO] Building at.biooffice.feature 1.0.0-SNAPSHOT
[INFO]
[INFO] --- maven-clean-plugin:2.5:clean (default-clean) @ at.biooffice.feature ---
[INFO] Deleting D:\Java7\Workspace3\at.biooffice.feature\target
[INFO]
[INFO] --- tycho-packaging-plugin:0.20.0:build-qualifier-aggregator (default-build-qualifier-aggregator) @ at.biooffice.feature ---
[INFO] The project's OSGi version is 1.0.0.201407300847
[INFO]
[INFO] --- tycho-packaging-plugin:0.20.0:validate-id (default-validate-id) @ at.biooffice.feature ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.20.0:validate-version (default-validate-version) @ at.biooffice.feature ---
[INFO]
[INFO] --- tycho-packaging-plugin:0.20.0:package-feature (default-package-feature) @ at.biooffice.feature ---
[INFO] Building jar: D:\Java7\Workspace3\at.biooffice.feature\target\at.biooffice.feature-1.0.0-SNAPSHOT.jar
[INFO]
[INFO] --- tycho-p2-plugin:0.20.0:p2-metadata-default (default-p2-metadata-default) @ at.biooffice.feature ---
[INFO]
[INFO] --- tycho-p2-plugin:0.20.0:feature-p2-metadata (default-feature-p2-metadata) @ at.biooffice.feature ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ at.biooffice.feature ---
[INFO] Installing D:\Java7\Workspace3\at.biooffice.feature\target\at.biooffice.feature-1.0.0-SNAPSHOT.jar to C:\Users\moser\.m2\repository\biooffice\at.biooffice.feature\1.0.0-SNAPSHOT\at.biooffice.feature-1.0.0-SNAPSHOT.jar
[INFO] Installing D:\Java7\Workspace3\at.biooffice.feature\pom.xml to C:\Users\moser\.m2\repository\biooffice\at.biooffice.feature\1.0.0-SNAPSHOT\at.biooffice.feature-1.0.0-SNAPSHOT.pom
[INFO] Installing D:\Java7\Workspace3\at.biooffice.feature\target\p2content.xml to C:\Users\moser\.m2\repository\biooffice\at.biooffice.feature\1.0.0-SNAPSHOT\at.biooffice.feature-1.0.0-SNAPSHOT-p2metadata.xml
[INFO] Installing D:\Java7\Workspace3\at.biooffice.feature\target\p2artifacts.xml to C:\Users\moser\.m2\repository\biooffice\at.biooffice.feature\1.0.0-SNAPSHOT\at.biooffice.feature-1.0.0-SNAPSHOT-p2artifacts.xml
[INFO]
[INFO] --- tycho-p2-plugin:0.20.0:update-local-index (default-update-local-index) @ at.biooffice.feature ---
[INFO] BUILD SUCCESS
[INFO] Total time: 29.001 s
[INFO] Finished at: 2014-07-30T10:47:20+01:00
[INFO] Final Memory: 73M/190M
Re: NatTable Repository [message #1404188 is a reply to message #1404172] Wed, 30 July 2014 06:08 Go to previous messageGo to next message
So that means in is not a general issue with the NatTable update site but related to m2e?
Re: NatTable Repository [message #1404189 is a reply to message #1404188] Wed, 30 July 2014 06:20 Go to previous messageGo to next message
actually i cant tell.
as m2e can build at least the at.biooffice.feature, which mvn from command line fails... trying to figure out why (but i am new to mvn and m2e so its pretty hard)
Re: NatTable Repository [message #1404192 is a reply to message #1404189] Wed, 30 July 2014 06:32 Go to previous messageGo to next message
Hm, typically an issue with the locations you build against. I prefer to build against a target platform rather than building against a repository. As in a repository you are not sure which versions are used.
Do you have a target platform and added it to your Maven Tycho build as such?
Re: NatTable Repository [message #1404193 is a reply to message #1404192] Wed, 30 July 2014 06:43 Go to previous messageGo to next message
tried, but my target platform include an installation and directories/folders which are not supported by maven/tycho
thats why i build features, which include all needed plugins and create an local update site from it, which i then can access with tycho
is this bad?
Re: NatTable Repository [message #1404196 is a reply to message #1404193] Wed, 30 July 2014 06:58 Go to previous message
well, if you have a local update site, why don't you build a target platform based on the local update site?
I don't think this is bad, but it sounds like there is an issue with the dependencies that needs to be solved.
Sorry, but I don't think I can help you at this point any further here.
Previous Topic:Column Header selection when body has one row
Next Topic:Performance for selection and scrolling
Current Time: Sat Jul 26 02:48:20 EDT 2025
Powered by FUDForum. Page generated in 0.05082 seconds
