Home » Modeling » ATL » [EMFTVM] Calling static methods
[EMFTVM] Calling static methods [message #1402904] Fri, 18 July 2014 05:48 Go to next message
How do I call static methods of a class, which does not have constructor (if it is possible at all)? Let say I have a java class
package example.com;
class TheClass {
    public static int one() {return 1};
    public static int two() {return 2};
I need to call its methods inside atl/emftvm code, how do I do it?
This code
rule somerule {
    from s : MM!SomeClass
    to t : MM2!AnotheClass()
    do {
        "#native"!"example::com::TheClass".one();
does not work.
Re: [EMFTVM] Calling static methods [message #1403453 is a reply to message #1402904] Wed, 23 July 2014 15:27 Go to previous message
> class TheClass {
> This code
> rule somerule {
> do {
> does not work.
ATL does not have static method invocation, but you can use reflection:
OclType::refInvokeStaticOperation(opname : String, arguments : Sequence(OclAny))
See also https://wiki.eclipse.org/ATL/EMFTVM#OclType_operations
SimpleOCL (https://code.google.com/a/eclipselabs.org/p/simpleocl/) does
implement static method invocation directly, but it's a bit overkill to use
for just a single static method call. In SimpleOCL, your call looks like this:
"#native"!"example::com::TheClass"::one()
Previous Topic:[ATL] Tool support for generating the xmi source model
Next Topic:Generate the XML file of an ATL Transformation
Current Time: Thu Sep 25 22:24:01 EDT 2025
Powered by FUDForum. Page generated in 0.06064 seconds
