Home » Archived » Jubula » Externalisation of string for Jubula
Externalisation of string for Jubula [message #1402834] Thu, 17 July 2014 13:26 Go to next message
We actually used Jubula to test a RCP Application.
We have a lot of controls done on different kind of labels.
My problem is : when a developper make even a small change on one of
this labels, it provide us a lot of modification to keep the jubula
scripts in a correct matter. Moreover, if I want to modify quickly a
high number of label used in my script, it is really boring to have to
manage a modification for each one.
I am looking for a way to use key (and not value) in parameter, and to
say to Jubula to use a file for the value of this key.
There is a way to achieve this?
Thanks for any help.
*Tony HEDOUX*
/Test Manager/
Mail : toh@xxxxxxxx
6 rue Léonard De Vinci - BP 0119 - 53001 LAVAL Cedex - FRANCE
www.all4tec.net <http://www.all4tec.net>
Re: Externalisation of string for Jubula [message #1402893 is a reply to message #1402834] Fri, 18 July 2014 05:01 Go to previous messageGo to next message
I am assuming that you are talking about checking the text or other properties of the labels, not about object mapping.
To specify value for parameters you have at least two options.
* You may use an Excel file to specify the values.
* Or you may use variables which are either defined in your test using the StoreValue action or predefined using environment variables.
Please have a look at the user and reference manual for further information.
- Achim
Re: Externalisation of string for Jubula [message #1402927 is a reply to message #1402893] Fri, 18 July 2014 07:52 Go to previous message
Thanks for this information, i will give it a try.
Tony
> information.
> - Achim
*Tony HEDOUX*
/Test Manager/
Mail : toh@xxxxxxxx
Previous Topic:Problem with example to extend Jubula
Next Topic:Iteration of items
Current Time: Thu Jul 24 23:23:17 EDT 2025
Powered by FUDForum. Page generated in 0.03964 seconds
