Re: Import sample model => family members aren't imported [message #1402887 is a reply to message #1402831] |
Fri, 18 July 2014 04:28   |
In that case, I think that something is missing around the step
https://wiki.eclipse.org/Sirius/Tutorials/4MinTutorial#Import_the_projects_defining_the_sample_Domain_Model
.. Are you sure that you imported the 3 projects in your workspace, then
launched a new Eclipse runtime before creating a modeling project with
the basicfamily sample?
Steve
Le 17/07/2014 18:50, Eric B a écrit :
> Steve, Thanks for your reply.
> To be more precise, I had installed Sirius and Acceleo via the Eclipse
> MarketPlace, and added the following new software : Ecore Diagram Editor
> EMF - Eclipse Modeling Framework SDK
> In the mean time, I've added other software (see list below) but did not
> yet overcome my obstacle.
> I've downloaded the sample model example.basicfamily
> http://www.eclipse.org/forums/index.php/fa/17018/
> I've imported this sample model in the new Modeling Project (menu File >
> Import > File System).
> I'm in the Sirius perspective. Unfortunately, double-clicking on this
> sample model DOES not open a tree editor generated by EMF, as shown by
> https://wiki.eclipse.org/images/9/99/Sirius_4mtuto_05-2.png
> Should the import trigger an automatic generation of the tree? Or should
> it be generated when doing a Refresh F5 ?
> A right-click on example.basicfamily in the model explorer does not
> provide a specific menu to generate a tree editor. What am I missing?
> Thanks !
> Eric
> Acceleo 3.5.0.201406101309 org.eclipse.acceleo.feature.group
> Eclipse Modeling Project
> Eclipse Standard/SDK 4.4.0.20140612-0500 epp.package.standard
> null
> Ecore Diagram Editor (SDK) 2.0.0.201406112035
> org.eclipse.emf.ecoretools.sdk.feature.group Eclipse Modeling Project
> EMF - Eclipse Modeling Framework SDK 2.10.0.v20140519-0339
> org.eclipse.emf.sdk.feature.group Eclipse Modeling Project
> EMF Compare Core 3.0.0.201406111328
> org.eclipse.emf.compare.feature.group Eclipse Modeling Project
> OCL Classic SDK: Ecore/UML Parsers,Evaluator,Edit
> 5.0.0.v20140609-1739 org.eclipse.ocl.all.sdk.feature.group Eclipse
> Modeling Project
> OCL Examples and Editors SDK 3.4.0.v20140609-1739
> org.eclipse.ocl.examples.feature.group Eclipse Modeling Project
> Sirius Core Runtime 1.0.0.201406040902
> org.eclipse.sirius.runtime.feature.group Eclipse Modeling Project
> Sirius Documentation 1.0.0.201406040902
> org.eclipse.sirius.doc.feature.feature.group Eclipse Modeling Project
> Sirius IDE Support for Acceleo 1.0.0.201406040902
> org.eclipse.sirius.runtime.ide.ui.acceleo.feature.group Eclipse
> Modeling Project
> Sirius Runtime IDE 1.0.0.201406040902
> org.eclipse.sirius.runtime.ide.ui.feature.group Eclipse Modeling Project
> Sirius Runtime Support for Acceleo 3 1.0.0.201406040902
> org.eclipse.sirius.runtime.acceleo.feature.group Eclipse Modeling
> Project
> Sirius Runtime Support for OCL 1.0.0.201406040902
> org.eclipse.sirius.runtime.ocl.feature.group Eclipse Modeling Project
> Sirius Specification Editor Support for Acceleo
> 1.0.0.201406040902
> org.eclipse.sirius.specifier.ide.ui.acceleo.feature.group Eclipse
> Modeling Project
> Sirius Specification Environment 1.0.0.201406040902
> org.eclipse.sirius.specifier.ide.ui.feature.group Eclipse Modeling
> Project
> XSD - XML Schema Definition SDK 2.10.0.v20140519-0339
> org.eclipse.xsd.sdk.feature.group Eclipse Modeling Project
FUDForum. Page generated in 0.04843 seconds
