Home » Archived » Test and Performance Tools Platform (TPTP) » Cannot perform execution time analysis for profiling OC4J
Cannot perform execution time analysis for profiling OC4J [message #140047] Mon, 09 February 2009 02:40 Go to next message
I've started Agent controller 4.5 (ACServer.exe) and try to start oc4j
10.1.3.3 with param
-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf. It can start
successfully. But when I profile in eclipse, it will stop suddenly with
console message:
[Error: EC JPIAgent received message (FATAL ERROR): Internal error (see
log file
Where is the log file to trace? Thanks.
Re: Cannot perform execution time analysis for profiling OC4J [message #140082 is a reply to message #140047] Tue, 10 February 2009 22:55 Go to previous messageGo to next message
Hi, anyone here can help?
Re: Cannot perform execution time analysis for profiling OC4J [message #140273 is a reply to message #140047] Wed, 11 February 2009 13:36 Go to previous messageGo to next message
Hi Matthew,
Only IBM and Sun JVMs are supported by TPTP. Could you verify that you are
using the supported JVM?
Eugene
"Matthew " <mhcheung@gmail.com> wrote in message
news:c6c3a063b3e43733a6503d6b7227ddca$1@www.eclipse.org...
> 10.1.3.3 with
> param -agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf. It can start
> console message:
> log file
Re: Cannot perform execution time analysis for profiling OC4J [message #140285 is a reply to message #140273] Wed, 11 February 2009 20:31 Go to previous messageGo to next message
I can run it on HeapProf and ThreadProf. Only CGProf cannot work. OC4J
standalone needs to specify JAVA_HOME variable to run. So it should use
Sun JVM.
Re: Cannot perform execution time analysis for profiling OC4J [message #140342 is a reply to message #140285] Thu, 12 February 2009 12:26 Go to previous messageGo to next message
Hi Matthew,
As posted in an earlier posting, could you check if your windows system32
folder has this dll. If so, create a backup and remove it from the system32
folder and try again
Eugene
news:72ddfc4d38ecfbe9789f14a5271c7f6b$1@www.eclipse.org...
>standalone needs to specify JAVA_HOME variable to run. So it should use Sun
>JVM.
Re: Cannot perform execution time analysis for profiling OC4J [message #140358 is a reply to message #140342] Thu, 12 February 2009 20:07 Go to previous messageGo to next message
Sorry. What is the name of dll?
Re: Cannot perform execution time analysis for profiling OC4J [message #140387 is a reply to message #140358] Tue, 17 February 2009 04:45 Go to previous messageGo to next message
any update?
Re: Cannot perform execution time analysis for profiling OC4J [message #140458 is a reply to message #140387] Wed, 18 February 2009 17:53 Go to previous messageGo to next message
Hi Matthew,
The dlls are
JPIBootLoader.dll
JPIAgent.dll
Eugene
news:53c1ed5fe59465fa7f3ac311f883038e$1@www.eclipse.org...
> any update?
Re: Cannot perform execution time analysis for profiling OC4J [message #140499 is a reply to message #140458] Wed, 18 February 2009 20:12 Go to previous messageGo to next message
There are no those dlls in c:\windows\system32 directory.
Re: Cannot perform execution time analysis for profiling OC4J [message #140531 is a reply to message #140082] Thu, 19 February 2009 09:56 Go to previous messageGo to next message
Please define the following environment variables and reproduce the problem:
set MARTINI_LOGGER_DIRECTORY=<path to an existing directory>
set MARTINI_LOGGER_LOG_LEVEL=5
Then, post the generated log file (MLog*.log) here (please compress it
first).
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Cannot perform execution time analysis for profiling OC4J [message #140597 is a reply to message #140531] Thu, 19 February 2009 20:53 Go to previous messageGo to next message
--------------090005010003080401030802
Attached
Content-Type: application/octet-stream;
name="MLog06104.rar"
filename="MLog06104.rar"
UmFyIRoHAM+QcwAADQAAAAAAAAB0i3TAkDIAJA8KAJf+EwECx13MtVtJVDod NQ0AIAAAAE1M
b2cwNjEwNC5sb2cAsHhbjqcYPMU5qMXuWAdi4Vs1/bFFgwOWWYj2Iz9wohfA 895/KBB8PalF
eIHkfqKFh5Mgcj6n93qjaO3uHu2nVfkbD2ER3Hy1Rf2QfxvHksxgJ1clbYhn wv9+keCgPOv2
X5tKebBrQ41jZ+B6mDtrgLUJP71d1p4QQYU+iypyCLVsbmE/57vhJYjcPdX6 1Lqbyb/xDRxe
q0+lA3ZVWmQyJQ21IEWwtaRSj7ptG5nJlsaA3rwMnpg7WBgR9u+lk9BptEAD yKpslddv1Shr
Rk4RVRKNO/OOt14zfLJkbilWfS9Nu3drfzFS4SejjvDoeREoQ3uRu7zXWWJz ybWKP4Cm2K6C
47O7HgTRSLZ4opceAvloq2zoU2GEAY2wmVGg4A3i5K2DYCjK+Iv/ULo3Sdn4 Oxz4atohX8WE
pWwoKq7thf+TPcR4Wuwi1BGEcfhf4CJdlB6asPeYgfk3ruYIbw2Lev6Imba5 SrYva787pWfI
Krsji5Cu/26eGWo6eSOLc1w8qqGCX2lbbW3/WsBkpZvurCD7MI+Oa0ohFmbi CfvaB/eSJorW
BlEWy5S57Plc990QAlLH/BTaZVOQoIp4lQEZnWZnMsT9YzOWUeCRp0AfHupp ypoBTBkvC1pC
5ZnUDP6rb+MP9x49sJY7ONrZoAEvF2FbADqjkKK1JD2jVQEvKA+lC8X7T9yQ Wr//f06Li6eb
zK7oaAoq608A2tsZzeSc59YwrFdQzfEvSgGO3nZ+e0w0dj3PjRUzlL+MK9n7 idIzKH9WX1+i
vyEdzK3qciG/OMikoxRGqRMPCxzLT+ivqty6E8ns125lYAVz0+aFyBT7fW2u y3dPtslNXlMv
KrVEAOalgtXWjDUkXVye/gvT0d6RV2UoJqfqQ4hR62Hx2FjC3yRqjc+PFURX UpOSmnWatgmU
24M6U/IFwTRGllV/t4doQh+O7HMbKkbHyBY6Y0nwIHM5yc/p+CxNDnVDY3Il xJ1EwLfJTgfv
WCkV2ElVrlE//jH2juExUdQ3w5JwagKMgWJV+i5D2cHsTkdlnCiYtlVjj1Kh qtHPVUUX+p+t
WgmpBMqegN3u5LA4HSjqZhlB6o0BfOJL6OdZtldLjlpk5jj7nrmTeN8v6sTU 0SeKvF6X3FJU
KgfJG3A9CTFZ4Yr1077gYudTKGj5xyLz7EDMuO73O124+PSGjHFydV60VTsK Gnq+sJoNtqw0
DaBAgE5MfYchEFg0d6mLUEKNzrDE/chZf5MduNu0v4Ye5Rx1JcR+c2n7a7tZ dnPMSFLB0SsX
5Gu73dhDVsfZCa0gCfZmo74WP+G1e+L/xEeO2/9imF9XapA2n8YWr0tDxaMf 0I8Msf+RcV21
XF+3Z/DT5ExlhzH+acBI7IDlmKl7ENXMthL/Nu2c57+b/C0WUdcvlqOqxtvE r5wlOCujbfoV
dmU1DJ99rILRltzv2gJlxChVdQiCA5zLY8Qi9vL9QBjyQ+oWTFR8w8ikMtQI P/9jvS4hg4gN
eUrfmNvW7EG73cTuAqVPtpaww45GiKBAD7vFD6z3i3M1uRPysT4xLg0lr+Oe IIoNrU5DEoLo
QFSeyEMAwR96uwbRtmRZywqD18oiYivdQpP5ct87wWTi1QQ5bqV4/RrAibQ6 OvdnGQ3BKiZK
Rm7gOdo2HpBe0B39qDRqtNCNjULBAwkVh4lts6iLKn4lLBtIV9k7F/55Gj1z ZZMo6aaGXZzU
Al28QPbDeWFT07kMOJR5SV3uyVhhxJTq7IkyXifNNdp/Mv3xQece08X73CwX z5vVZCPCgw96
AHRB3aU96Efw7/ywkWyRFIpkuo+IpOCyfwJa1ruMcJb6NihnTaGHImFrZGCk 7PmkD2n9AUmf
DPw3P01kHBfApsYcBo7qold7JbMwsEPYUcqVkjLSKNeDjzYbUjYlhUQvMM3E cblgJXJTvwww
AHgLok0JrjjHaDbMNbLjPH4y8CseG8grcNKhI8LP6ZDXxtISkRFaUwFxzS7T q9W0imoBkGW0
biNDD/VKW2c7R5xjVop8zBgv6H49C++UHmvu+fL2cyaYeZmTCPX6Nh11I9RC vuiEybJlnbED
7/t/rrxojcZgPjleMBtz73Y/QGxvwhWicXWDZUIN58AVoQmL1qCdHIryY2ak MlFmlZjttEXN
3wyUvcTnPqQOcaU0AayOXnRs1RjAkRwB55tCDYsOmoJrD9/YwskVKq3nPD+m 4UHy7mgOMNis
df5QV96Uqk75C8fVpr2X7gDQIjuafvuS01N29hrxL8Me831Ia+W7SOiGfUfq 0bGn69yuK7mN
ayPiUFc2a1zZT44Vc3dippJxZwh0rJzubyChFJw7ujn/9HEo0KB9mYQJu+1b t67D7fl8qb6R
TrvSgxZu4m3iUj2nFbsBsQlLbyyvO2BaBgf4Nid1izXbXXy+PaE1SUON+cpI Ye07nEKSteI2
4v40AgaUR6xewQyM9BvGJTxOAxZNdQRvMGjcp6ZHMmuOULkoWwEbbx9kOdPc lRJ4KkOvvV3+
cbnIhTSxOZ9zuKfQuZyfr9fCvNSQX7jrxm4oco8oaWgXDfnlrQOxcqFecoKV hu1Q5fNo+uge
sRXjd8Z86M4VC18YdcOriN638+4ww0k8gqes7Lm3FhOFKjLDScYoPnIa+hV3 yuuA7n3YMPco
icDDt7Ysh5B7+/R0TxHVT0Ypyuu+g/tMTdiQ0SnN+y9YndUzjDnIGCXjM7Di GYCQU2q9q7zr
yQ+8ZM1WQuKaJGmGiRAyMZAKZDyplKEN9ClTmK5RAAIE7lBfJaRnJWNMD3Hn gw42A+OPu0vM
3MZvfkbGv/hiLxoq4rfXaR1rFBcfMXa1sIJdRWmwXFzPddFtm1YZ8S+twwco DGV+EWU+/NXG
xtZGLnD/6spcWEBcvLgF1zQWQwMcYTEsvUd37PQN+W/BJQtocYX0/sQpa2AG 3pcsoPNcJW9K
GDssjPlp9qCpFAndwXkuV1E/hUCcGD1PVrw+u/04Fs4Ihv8HMFN0meTdTn9I SFzQ7k8VCKRY
W5SmqX+ursjDXb71TKNXcNNP+6SKaj1XPoKIUsUOXCF29dB3dN89WuKlTai9 bvTr06Cozqji
cljVgFB+RUQOF/quhl9gtdIBt5CYkqNeN8HiZ/ZmT67f3AMlfP4bjrLq0HlM ZGfDHFDU8Ozn
FqkZLpXC5mTD3sDKOpOBbZnNiEtBySnVE+SI2dsejlmOfidXklcmVDG/hCwO K8s8EZllrLf9
KzY2ioeZJT+iVoQPeU/0MW/5fjhVGa3UAwXVFmv4qtjsugmkJMI/nL1pDSTG rZNgzMyiMvSS
BWpqouJgRSuNdQmvR4EINafF8//olZ0Lr759fjgfhMDmLd3+Bf+LJ+aOYlNH uiw1vS4ywLhw
wqi1G8epvAb7sudBMdw20FE0XQB8wjtLPQfwUWqRkk4RN3tjt+Pkatek869+ ZR/8pGf1lPAO
IOn5QEfR2gXGqjxmINSsKJ3T0Xu0hsWy/Mpgb5yhXGY99vCjrkp+cfqmBX/I ICqhSAp1V2dZ
dq0iLuztXQK4iBdYEmlSK/bFp9HKMFNFo0LzI6fEbLtKjIBKBE7PsZ4kuZI1 B5vRQ4rsaHcj
5SZKHpkoutdjD+WNi2WptUVvf1DRb6O3PvvIUx3piYh0sZ43LnEM3xZ5gsbR Wi3JdeoOWCwH
DoyV4+N0+6BRKrE4O+WuCcNyjSs+TKwap8t510ZP/O4UjCJG7RQZjQTpy9cE +UYO5rdE7wf7
lxyOudfZjUU7KKWK29nqThv671YTeR15VubvZeVlTC4NdjWJj15nvILCvPRl rv8COz/bqLIh
fcUd8UOn3dRMvLGgC/zPTjalwliX9OvPtuw7S1OLkvL/uGaPs2WaOB2iqYoH /w2bewbf68Hy
tf7sj5c3tzFHX3KKteOS/LTX2OoVqMLvdWC/QCIZHqqmxfQwPRyRPCwOsYf2 u2kT6B60CVT+
Huvt2U7sqy9YQiaEzXPvSVt98lqKfZk5x9qWXnIphnfpevFXQwtmg7SQ88L1 2zv+EL2RQ+zH
zqVxH09sepznFAwWiNzKXO04ivtrn2XI2AWi+QbuQpn6+9sfI9u1Lftvk0eR 8esnws/rV5JF
yuxppXdh+SA+a3WlwEjEuClCAVQ9Jy9jDYNm0eDTL/4f1eGK3chq+O0nkvGc Td7aDal8JU1k
deBtJzeLGAWoDGWuvgsMho3JkUyPifa3LKfjMThD15zH2qVsdfb7OvMl4sYp I7lfjP+tZFNx
ZZfGErU/JW/D3ManqmU2iQ8gvLxktZTEklUphRYWcosMmQHHn2lwR6HVTmS4 sDwQ6Y3wDhpP
4xVnmiRvRvVluO//Zs1WqDg6gGacGYp7nLDmVrE5lOCfX5dxNT8Ha0qp82zU 2XpCw0jIhBcX
KOXkWkcSTM3GO8p+vuCcBF1skHp1xKJUHJFlTckiFmGt6MWf68iXaj879UWI aqPk0wc114wW
JKlu3AL4176CWTDUBenp9xDIx6O8oREswvMbkGZEQh8bmMY80bCHOvYdC6+b 8hfbE/DZo1zq
yGUCQk73bY37/J44RyF16xPccxD/8sZr/YdOMV9h0BiVVD8peaOuaEfJwZaU jozNhkiDICh2
11A7gpj2RSqPXbjnvYVL6wST7zwwzjpJuh6ZPrSbURZDxxnvtEtDG1F9oGBd FQxtNisUef+C
GX7pLbdn3OXqo3yz3UwilG5GlRhG+szWJ75tlGoL/XMvFzcNcOgMOKIWToz2 2m2lQu+RJs3E
CKlogTi91LHE3Sd7u0B2HTyjsMPDsnlRq+mDW7GQvut69kvwQnhJTs721cp2 NOPUjOL2jQOy
O1xpDmCqFEMSrqQ9M53CWj3SvGtS59tNaLCYoUMr+TQQZBXqWWJpoqdhalv8 HS1JPVUyTjk2
2cK8Mn3wuD5uK4jqxcXAMcYSzYG9J4hHeMtbUe4Nb3IJ0TnAmGdS/PX9Q5+X jApxC9yl8+4y
3cI++gtvnZrVEX04ZLpaISDWfdUUhg6qxDYDrRQsC7RitDg6YC8Piqk9xKrz 87qLHlo+ml9e
pe31RqYku0RMYoRD77q1L9u9cVgCohN6FlkyzftYvhYaAa9zOPQdykerwoUG Lytt6GiUXDEe
KK67GalaAU1y82vrRTr/7v2tA4a9fbWAg/HDQZ53ALCyXwpyKvi2lUq6HeuJ /xVwo71SHbqi
ZMprJhlVhfOaL3K6o4+RRqa7q2SxSRHZLIxnWKDdAxWpQ3rC5Rtmp2MpC/EF sztjzbFsiMKc
tpCdc+40R3/vGyjTQ72f+pS8M4xaeYj+UlPrHGP94A8hLk+ri8l4kZe6T5nz EMg0aQadZ9L+
b6tHyjlza3k9h16KkGNlSDVMcEJpKLtWLZxVCSYINUYWE1JW3L5wZ1G06r/m a8fxX1145CE4
Vrqv5OeQ6cZrd6j9Nq2accxKg2ExgK80MWjedhVkBSSFqL6hz+GjsMlKv0vV k5AU54m35Q89
fTDawWTDpbaQrGTPZiGYRDjs3JmdCkwxTRAPIFD9vKukMh00wnuOUknCWoN6 l0sY/h6RUwjq
qE22AOEk6+IXEErEk+lKjZttcEI3YGai06VvSqANUoDo+8C5Os8u1zQ/ClSw l37qQVgcnOsD
eN1NhaZiF5XS8vh5OdRiOoCndzgh0Z+5TbgYddY3dbsgkg2wDbukBpR4YWIa Sm/3BNY6hFJn
8r2rGGK8g6lwsjy1/Q1rEuz2nw9RDKjsUhVYjcERqoI2Tr4yGBmCxAivAYUv GROLMeR+XVtZ
o1RnMz9wFDj92J8EoNvef268/d1eof/W1J0w2Jm87ScrPi0fwNgZHsF71B5t 0KHAXZrdLhnP
s/MvpPSwlrLv8H1+lht2rx3oS7XjBZhFZ+FlUmHFY+OU/pwf8lj5EHEbZvs0 YEaJFv962TMd
4j3b4FezWNpUCWlb45rQUnHtnFu6+7m5WZVSvfUJ5ePlb3AV9JBP5eVLi7oX kU8hFnGHwj0L
nqESSNaoSg9e4o61Un2Jga8eau4owUoE6xnRjG0BUzKIXGL2G7nWKH98CQaT 78XTnYpdc+Nv
EG78f2SBJnMuF8nW/m0larVj1+PgRtQfdxI7iJhm0YrAp/1a3v1736kLZHlV D2Zy3hyv4OMu
J27cQBLlyYChy16/xfj6gtHJ2VraCNXy4ubpWZ3sGFfIPNPoDxlpdFg9/nXz bqDhLE3dnSuk
pxLWRxMutEtZUw5+zFAGslIjWvhdKgyHr1y2ySobH/c1nBjJn6xywwU6RSEY bGkf/acioudB
A4hZ2xJffAHt4e6wdqAPB3rDrkOMUc3VTIM2xTsOKblWjJ+Z+LwGsczmwmlY 1sq87DP3tY7P
ipu7pAchXQ6VhhwTskCk9bw12V0P1CCy8pWjbDvMeUMEZdBpg+VQws7zNFeU 8rLyBumcG3np
rowXg9g13CPneCsGc8A5fJnHaVjnZvT2nQInjvOtd2vloV0RKjFVH+Ieptzw 9ZXAwuaXMORm
SXADNfnXXEpeb2Cu0uudeIxbSlhcUHc84d2RC0qHMw7yrKqzIpLNI4CQ+5I3 Xiin1yQDHdWV
AkVB0c6LhwDmM+3LZX7k1f3egGjA/R2w+KylA0AH4k9IzOf5DSRQ1KsKkVI3 g+36SebOuuI7
eT72j4T8uRwCvpIcpb9qaFPAlP4yzvCDRmnycIg0gehfPYRcndQnVyNOF2UX mWQ+2ol0Xy8b
0qzGRvVn+aZ26leI/r/pC+yMGQd6sobpfLrQcNkbwMFuR/+W2fTnFHdTTsQT IM4MxB4b8Z3x
zG8ykcSRhv8B4x5/r2qEGQxFgtgfgn3k5JnYk0Uqkut9OsRw0/6tmqzjGcS0 I03eoIpSKDFt
9umgdMaj/AyQml3qwvytgxbwnGsGRJpZ1Fehb2udG8OhF4NYTyWv9yP7/4Xa KMqfS49JWCT0
5Ok/7llCfKIwhT5Q3NkoVuwBpCA6rFN5TtoYf6swFyiO/BJY+8qSAuMQ0NZX G9wDY59eqLxN
uXvzcaO0JtMtTI4tr/faVgT+gfrQw+T+fe1L+rdcP7miVlpCTY9MLt7K/g6q UMl3tGuj4yxP
KyOBmTJmdkwjyzwKaovi2lXQSopsGMsk2Gb/GzvUPZTU5K7TJrlkm84xQipS T2c7gYdw26FL
yj6piUuT9KeMlSqB7wwGgIEyOkalwbTSeRMzkJvmtVx61rHvK7FCJOYd1dgm PqYrCaQF62DS
7hjzHVHLz1NCXjU9225UNgIPpE+pl7XPxNVPy3iE+kF1t1V/K+MMlPno83c1 z6vy0eC6UxEz
cgrk7GWJV3aIoNN1WPXq0aOc5hQz1smTJWnPGUJfdLoN54AYTcjUFzKjjU/c T3FAmWf/jzMw
n1X7dgOel6rbo/fTJBYiv/TI41oygz7jdWQBLML93UAPusJcHHRsOwdgtXKZ 7YsZHdaqIf2H
GCliHG20tmOPdw23IkOEyUWMn6amy7EtDBsPnxlM3bci53gfegsz2LJmlYm1 ZpcG7XVfpEun
YLkm2QvbIy0rp+l8tgld10uzg4DMepH5x/jzEuUUAjXBYDif/qY5o9Ip643M EcHo5HTMiS22
xbRiX6ADX5YxrlEUzETAE1WKsDIdwR/xWhQ085fxLlVdhVzFvksPVFtJuwgK CPsk/sXWmpwz
SPZu9vNly9bAQMV7wU1zXfkurEM4/f3PitEr+mwZL04TU2sIgv7VtQdIaW3g nIIeXiCIEhRM
zvHA02U+4LaxHSZAZjm4OPenQVtQbyc/9Lxf76oCDMqNPF8Gcc2nZJzyflnc CMl0Pvpg3vaf
j35pfw6dR6enm8gKCYi1aqkT6Nqt6iuLnU8lY51WV3PN1RuN2MNdfNWQ6uHF SnLZbgm5xuh2
Sju/4SQ4LYteEPl1pS+ST+IHFRBLxzXm2548SMlh3soLhnvNsD3D5gJX9iBp WhJZBHSdFZLY
9y+9QrE7maHXj86KJ/eZuCuOv8sSH/vu6Jbio2XD0tT7HF89gTVtd4w2bmvO xfOqvHGTmn/K
g4PMBQaMG2Av4MLtFqPfY5kjlSgfWjO2/b9F5r1v1H8pKNCVe7SODm0MvhrR 8NgiVSMUN+bM
gd0/AKxUHUun0zEpxmHTNLL40twVmmdY/5EVkbINaczH91/bnXbiNlwXFR+l kBVWicsWLY6D
hKup3YfN962W729bKjqejlJ5/RCCl8PNMLMeO05Ew/PAfJwzUJ+uso9GFnzX 5Vb/5ieooeHn
9WPshtnEMSJMhyGjWj95QGmblyG8JCGqM/3Oa5LGclcRnNiByE7PiOcv8mxh esL6biKf23Ey
a19epvFIk/6opXXIurim2F8e6Cld28nuepQFyOaGPgOdfzoRVJrYLOVJe/WT hKvVEH50m6B2
ISRx/Sk4pP8LwymvSaRsRJen60B73mkHdUoU69EhjHr8MZjl+8fGcKadRQ+q 9yFVbEasbIGD
B28ELQRlNdIkv7hfAWHztgVziOriSEiqh+NchrL8VNkYkSzR/hqlyu4B9ruU YrkZNM5z2WoN
LuGf1OylnmBd442auz/F3Nha6jbvPdZZBTwyVwJ6R/7gIJIauVPHabYTcywh wiSYp/m4AYs6
bkiJeSzpOC/hNjY02pD+anA4tr0FLTSfmLcrqXKqLy+xqcLsks8lUkKqWUOj nbun9pgkqXmC
cClzbU7ApNkQ46fgF76dyTKT4w9id1IhaUm97FwvvGNzb3r8eVwolF7deeUV 2zeHxETMv2QB
rLpOOXeqK6P7CmCEddwwUVwFWTohT2HlPFn28A+XNuvNm9KFex8e9BGuJCey gNlaBgKFgVgt
pqHMupxFwviudp/Gi0vYhdwn+YBv4vElGMhdKT6x9maeTSPDCtxthkr9ntDw 3hiXts7OWvKF
se+wpuz3KP0MH7WgmDV3IOZl1LymsUfYLyaIs3JD2kvsBXnFOJSCQvaBSPpX AaZwV9rrNfDK
5IZ8tZiyeZtgpx7LQgQ2wifB7/WL0FTkuH4m63HxGn8SnYzFZ9W3jXlxWdRD Zd5bDs3a7kdA
4A3mosmOplDh3X11wNzufcYTXEZxUYYwVaRvzqqy4xPwOMOwsMkir22ouWRl KE8RVwfCqFg2
Ch8ySmEnamvNfBez6f+G8WXisanVA7HgZuI/NV6OyCrmNsOodkyKVl0KhEeD TRxaTGLPisNU
5JfVKg1pO9Mj+eUXt/zEL+9GprjzYBKj25XIxUkvf4fOtM6e51ipT73XWr6/ kYKiFWlPaq5j
hFjgsVesKrdE0nblfZSnzle90HYV85hxXXqutntxWNWx4j/RO3rBTqVoFcB7 DT6H04qC2BcO
0UsFR/xwdo0CkoPwUMhRYEnUmPUjac6e+lZC7t7EeUCsNKeuYGOij6jUFyUe 8JC807tqCqeh
x6uvudx6QBh81VbT3SJ17fDSzpyHNpcrMIJaZWjNZQmROjxVW0rOwOfvjrZ3 Sdk3Rr8Vs9S6
GUNFtpF9R4Qs7PT/1jU1zvWf5YtNmW8N+KxKM87jjWvUzsszKLUSOqOTQtDg X5vUJWW8w+3R
1XY+n9QsfolcBIQ8PW8erSH5oQyERMXf4x3VC8Yjek89gtWgZi/U8l3Cpvxu duQ3aiRvHiDM
C0gbPyDXm5b963WaQPzVl5ye4aqTVqiWybCYwXxhFUqmy03mHF+LWMItnZXl bLgoeyURwsrg
lpYdZ8yFmPRprbBB5lEzvYgmzVHZxGhbKzTgRiC5vFtZ+Ljr3i4YVrLgw/qx B6zyUnF+AwtA
KzNAbMY2v/M49dkg7WD2AsKAlymui6bT/+9VUin5OZ448IsgfxmvFzbXw9On o6CHME2HPL2K
Y1wpwWlH5nEjPp1khZoiWxQWSFGRQurVrFXGSayg9ZaFHsjN4ayGm2wTDtYO eKAq9d7MY4IY
v/f6XloFFipwKO8neOovQBRBrv9VQWiCUM/KSkhposgG4zkGhgKsf3lGXhSX +BtRSOlCObvm
dr+iLWfQROQ8Gt4MoaenpZu/UPF8n1/D2HJqnGHBRqZOP/fDP/47v57nf3IO 8IpvYojhHmNV
SvVHTWzzW7xzJoYfO33RP0k5DyIfwguPuXxi6mQw69FdfGzRerssRYtByQ5s KpqgdhEMMr88
NwI6Oxzwn7BL4zi3xserlge67n0ryhOLQ+wOlYHsKZbU6xP33HD0e+srI+oB Q//6/xL7VaQW
xQq5/+HWP6n4HWVg7i6OwyL75TWxac+Pelzflm//i8sSaKrG59wXZX61ZoaW 1rA63PfT2ABm
+y1dhYQ+rODbG5g71EP2LDS3MAmr53nNpQu/1Q/FAhJSW5jZ1Dcyz5ACMW2I 2EYx5/dEmFQI
+ZXZuIRulxCROcXuvY5Ow8STykipKAm9BCRmH3dAz22k8oDMh3bqyLkcMMU1 qc4fGHv32QsZ
nKNfPZkf+0qYtei8JkajQxGuO1+oU4UNyt3I8m1BJDQWH0RHiJRp/vSX8w4m hD334zoaxKR0
u0pavG0ehgUC51Tk31O/nxK0CQN9EpDh9GztueaFQ0bNDdZHsb6oQXx4UWHB 9ZGIPhtcHJNz
0+glEfXj3p2QucaiG0MRr4c6S9ZzP1FhRR9zUo1tfHiEfWLusNGb0+mn5i4K UopMKRTwaJd5
EjY7D1R53DeiTH+5cq4l1k0iOHQl8kr0hYKP8G7dyhkG2twtV9pFqI1KTZr5 vO8e+4g+oSBK
2zclwUtySh89LvJWQPxDWEJxmBI5hCRXzsbG2bD+3Bu3pm4dFZUpr189Fa9C BEfdbot/sg8E
I7R4p1mPXCwogEVD3WD8AJoBM5rElXJAyzhBgbQsMloHvMgXg72JTYOBU6rV qC4JH/SZUTgN
IyTbuVdERZJuij2vjUNuttKMd4h6F8oMq7ImbF9OJBp3jb5qfZRT/6Kkwrq9 V9amGqWDVydg
ztHqjktaiKWllL/8eNEqiZv/36y1GTxEwmOHvHbZFJc0wGJ3GxDZG7KHOaBa lGPmcJ7VbbB6
hBLzwy3UnLnJkklxXv+qN3dcPrmBAh8du9vuAqtWlbYpn5oScWgVHFfGypRM JtJjL/sdpRKu
qx9kpCzbTT9nyXt+2U8O9SsUBOcupZYb2JkcvtVMhgCJsZfqgyXxljno5TGO 74p1bjJQjET2
Sgru3YiAvUA/emCEzbzHPkAH+cDI2rli0pIL6ZVCQ0PzHjIQ7I5LvBec6DFi if9n4oCu7+AL
fiQEyV4Y/1a3681IlcGRhekMUc81LFRMZistDpHg/rZm+Dpe9PyQb7/3pKis Ou5nljSwU8Xs
20KlysKozwSvew0gnlOA2s8f7u9Ya6OzIb1RzQtXJ+o4MUKrpEjy2NrjOJoj qpU4Pbdpspv0
iHV+9uTMDF9qbe5b4DhRAGfwPtksU62dqz48HBRw0nbAGZaII4/sdQk9Hp76 3MoR0xm0MFDh
FRKurhujhv5S8zg+gFJ/g0hMfVmVhIWhrMRLRnpXGndJQGXbI2qqyPvGI1y6 cff2LXGPdQYU
1KgWEHoU4FyUANVlwx7BNS7IymSFj/A5tCjfUbrH+7lrX3RGmC2S1ZHFs3Uj MRxIoUdXoLEZ
2T7cVO8aNW6gs/v+pAW6/oXrIR1D47wdZ6AfQ4gprIF+5A+IGVKmykSQk/KM dL1jGh/VaBQP
XYd0NpZDavLr0BmSwSqKiDHfgsBAteBAU3j/Rw7A7Tjn2wwTSspUpvgwmkiC ZV8y3Vdks+2+
2iskBSQgv99naDnsybDFjyLvhFq0+HMgiAv/n7N5CYI8ayWt8rQG4Fri6/Zr OuBT+RovyX6V
7yt0kXplNdGFadY8YrVfjZoUzVWG21HF28KpvAdUhjYMgCiLHTJaJvBD0vqS ceQ+fE4q7eth
XsxwRs+p1qYxJ+B8gV6M4bXv3vvjt0WxwpH/Bw4dQYAM81zJ/FxgeagU27jX h2KUoU8ZxSn7
M7juwUTwT7Z1qPnWt8n5PFt7JGHAwLTK1/4YDMAgUIMm+Rr/7+m5H9ONrNfB jX2TeYnm8S5P
Eaw9evXnwas6NWPczFr7Tw7641MBvT/kgg2U1mvA7n4h433lytiIA9jm/nmv mjVOEeP85mwB
Z/jOEKH/iCNC5YfFxeg+ggkFIpva9H2w8pnzWPrlHi62wDk8+I80RPSFUcGe IBh3fa6Tdv2n
RbI9Y0PYMgkuHQMBy72VWf50i2sBBEnCcD3/EU5mehgtSakTBZfXvetcxDNx P2bQv/Cbp16v
qIyg9/ON5E9P9ZUcXlnla5PrSGCIy+DOGILMtK3A1x+/V34HfzCRlq55WrS+ o2nH/edvN3U3
C1knIZGVdpTvqit9YI8Da/YpPkM3I35xWwrVi9/0UVhgZwtbhnKVUUJvVDDf pqAGNa1IwQPR
wk7qFCz33k5wSeft82RklwlD4Qail+2sr5ynI0Mw3yutB44vFkghd7cICSBU OlIVyGVlXQOb
+lkRaGqzf6WVXfhlUi8MjCDtsEQcNtfSOJVC4fhVbSJr2wus5KVxn2dEejxd qAzQeAlQdVO6
OK6PrZHb4T9cgDFBKoP/CByW7UBT+NmWHAqHypDpHX1GMEzKa9jkttw3JGZW Benv3Ee6yZV8
kZfpAGdOeAE8Zk8lytJ68gsXdfQcSn+llLPv4vuFd4qHZrNdrmS1butyJ/w1 o74CrpjeYSCv
ToI6N/gRWjP6Id3T2OEOnocqxlOU5FZShUW88GX94GN0y1dUe8DNZXm2uOiG j7yRzoalQIYM
qU/xHvQgYPga4L+d8ghhypE8wi3+N3yk40ZV7b4t/6q6ldtWBVu97fO5JAiR fGUawsO3H77R
ky22zp+9QDXiQJICQKhZJNOkT3k/mf117/Ft47o7OZvKn88qKq2QnpFTQiaZ hS/eQtiSw7sr
bcixXwafcFU/90vvXkUl0yPYOe+4x2s2EhywfHtu1tloi2jCH6sbCHdpkPwp rHxo6mtui1ZJ
LOVnBAZmbG2ke9lwfBobB3btKv33F+fIgMtyEztxSLYb7XUgKNIx6owZwdfE KylGCDO0ppeC
c9tLlx98ffYpaM6jyGOhJG3Glkj5TPcPpJoL4Wpun02cgFmD9+gFV9u0SZ5V HBPfZ4UNgYme
6uOBf5T/G3IMbt0fazRFG8H+lurkTWoGmkz5tUQ+yfBIy3NS2uYT/pMsqoOu PsGO4eWuAbuo
knklYSR8Sgv4aepjzYRQH8R7ZZhievkd6+yMkDl8YTBcqrdJX3KzYR7FjUFM /YSAvpOSpK+b
W5NaeYijzvUBc/kEFQIz1QbuTrq3/2G1/LhgnoRm1L+Gm4qS2OIOvR+Cvsi7 4Sg3YSW6o90O
edYy4RO7eFHS6TAjnniPDW/va1HMcnjzy3NPf0tNv6sO2cT+8XMw1aioRGxM bexlNl9+jF/h
XokxlzwxVtQ7NQXuMjTNvHWGwfLyKDLQygAW2F+g4JHh/aeNaeF5ewimqv/k Q+ioxS/jGMFy
zG+ESKhq2YiV4CBSFx0IApU2+prHkB/E8BUOD4ILVvPuu9z4lMowBECJdSet uZilppi6Lqsb
52W7oUAZIYxtrvPBndPg2Wts/X/nL2zvVdBN/A4G2tz/ZLok2GRhXbxhrB/0 pcAoVuFPpWZY
NoAA+BnKk793W1HpiLlcY8uL+oMRxnNRTyo90eI8yK8VwA7krN2lNgt2HkyT OVntXJ0LMnqI
F9frd6Dpu8zeLnbnAHycBGRkg89GNB6FEhsdn+ODgup5gG4GhxV2OVBydGnR aLU6qhBaujHD
N6RutxYicYCIjXJ9ZnuuKe27XcEX+2tKJNf1O+diiGlGevQmLDF5WScsmJCG f6+/YZvfIu04
fD2sdu4bTNKPJUIm9DiYl7gpQerJrimGMObM8CX/1GUob+WRX0A7MugclXKR 7md0XS1Ai5sJ
abKJlNsdOK7ZGelQmrbAukdiCMfUjYkY1KMlbleag0LjFdHAjw/u4p6YXlmk X9gSKALsMxWE
o4yTX+mizsgacKQKb7z82WogjBrRtkn4HcD8Lzi96nt1UDW4JOWC2a9+sFE8 z8MJ3uWjnvP+
dGy9vad+X1cNZsuhBusC1VY/bXARb57of8tVRr+NMA4f14+GQLiEfcDALXie QylqxInORZaO
dmPTG6dSAXKCzB+HXYK5e1Vt6dMvBxqKmUHrxhjgkIMXuj/hZqX3WlhF7uWB zbekQteIqOT1
Ap0Xck+pKNmWeY49cMIHuCUG+wbHmxrAt8npRfnVjgqXNWVP1XhhtHXNQaj+ giw7c9QtiF3r
jrEdXWTdcfCHXrsSTu2KM2DVqxwPtv4Oalf5eO5ic2ROwKfCnhNuMPJeFN7r 35sd4mKgBhI8
fdVtFaqT1HfwiPWgI3gia7hT6WgLi0xZCO4xe8MrDH9rVpCCcykvC7cAS/m1 jC1c6NeNegtN
HjX/eAj2FwQAmkMga3aviJrqFgUPl0gmOKXjfj3iEHwe75QkFLZUgA1+bVAY AOd0h/u/JcBF
ZdYCAb3/2I5Ao/dLk5P7na4abASoTMIhI2tzfE71FYr0ANrhouoZOwdLMdG3 W26IlILeSvls
OG9nvZskkGKQCY/ggRJd20aKfq3yS7Na7JQLJ/oD5R1tjgUx069csmYIzD2D lIVppl9maU9D
H4BbM41apLAPGO3OHvDzBWDIlHVH0mpkPyqX8uqiwxRBMtgaoKCy/H3Yjcdl MARyy400cB9g
/i1ZlYf931MXPAtnRSH3v+9OO8YLXGSQ9rxtJ8zrTezXOW4i44lC3w1qURLx y/i0Fm9GOKgb
veBxjB7xkfL6F6vkn+UxGqHPfgEYzYOL0LFE/e3SbUNK1687sQCUjzLLyKrd 2dQY9xp4fTzo
aGRfkmyrKv1zLx4laZXH4XH5Lygdxt98Kpxru4k//bWQQSmaPWhOkFH8NE77 uVfAOhWmjKnQ
GadES1lQJdbIJ2ZAp9xhRZyJPO/rVO69ap2ae91D/WeFZPnImGhza3uu253B DYXkrwIhlNpT
sXvQVjXwnEKm0D2T5kyDxDiO5CbjBB2ENFrjv3sWaD3RLORF+DR5WVtE13Au /N7zt1YJSKnJ
edKbWjkRNg1WoQREKjG/U+OndQCtbnns/JoSLJaI7msAbuqyj16/e99Bg1JH OEup6P5kMD2X
h6At6hDPuQhvG1auBJL0Gvcc1IPpnF0hLJqMVHWCNxxxS69d3tufhNB2/QJF X81c/2MFePe0
I5xbGa2zc/O39PBDTrwbSElRs52W7C+Db/2VHvrKYoXUqRp1uyq3xrCACrQU Ol33Jz2reolx
+auGref6pp4+otcjE3DM2Rte4lkoa1PbDpzsf05gMcMH4WLMGaKa3+DFSfFI qeM+TMxkn6nW
B+DOO37oox3xmL4ZO+Nwu48hgInMLlBSUBpwVTaL4f1Vl6CBDG8N15rjFx3Q 6Od1j8qc4hMN
OkwuxTFzlkDOkvrYztqxauYOkMt/WkkbYAYJ5SDEvywdzoVVLALDkK1DcBx4 xQmdG4ZiaV71
bzySoI36P0rPowMzpx4OMMmYpiU60dMLnntPYFdFm8Ir38AoSO3bbYKVQiDt 8I4Ys2elZpD+
LAB05j+JNuRsQECnkykvjaaSSCypDpk+kkB5tenk+qj1Gmjy53nZO1Wdf1my 7sr6BMTYhBtO
jPFF4nfGVAay+owwq1c2n+aYbPz7WW+kN8BXaOItOUGGGnmzp7/ymordUBi2 VR5ICzp0irJV
KLXUm3/Hmb7AEPLxibZi5b+oRxfhV3ZG+sqrL2ODcqXnBk8J7ROg5mTZPY0B kNOhSgjCRbw8
NfAPnak3ZzrhESsyrdYCOF+IHfujyjuqZZ/e+Q/4+PKoKr24aqpNieUf6Tjs YTuZcekhPesi
0MWvTSaNPBZcVRJH36DRKFBJ3c1N6u4HiPBkBPaglCpFlXDGTF00hZqUYCI1 70PCLOJh0eCT
3rrubxC8Al9MQk/aCRDrkI14dS+UjCDTXuJ1VsORyPtstWwxZLMrOsOFf/jn QW3N8jqpCfb2
65Gz9+yogBWNj2qvD6KYIGzB5v71iR9DnPdxgog9y7MLWokIKk+uR8a+IbQn hAuZglz64Hby
xqhYz76YAH1S9SAGRM+newnFe2IHGKw+Ujt1+pacmuDvuoTAg6fX4j29YY3a ymfWcj2Bgul/
tKLml2bZ0RbHMEYdK78QRe6BzlOax5E76iQgXKV237We2JlQSpZkaqhHUhH3 x+C2asBFo01N
o7/6nMm099uSSNcFTJl/sj8A/gJlNfS+TyyxyxPvLjKA7yCpHiCsAk+LBzd4 r8kMglE6TtSo
qw/DbQRQdQZ6Z8qm33bbOeXOl9lJegFOLmTvqDP5mFHtGeejkGn/OrZbRO5s cHLEZ6fVuFjY
rawVwRixibtT/N7DBMc9gkjoAiS7Z1wRCGtZHQe8PQp6+wAwvL3I8Wy53Kk2 X/zge1frUyxl
5O2hJOTic/lH8LE9bciiXe2dJ1N7s2owfPtRPB3auMH7QYChUeo+hKXtHs89 t0kTZA+H9cGa
eveulg4SNGYWXZCkLB4ODfFf2s6D1Vc1gzR2SqHeLlEOYUukjmRIjEK6frL7 thQ5Z8KoFJVT
oOrIykyT35YUDj30KEU3NfVO/GGfplKnQt6f6JLF/ws8t5LRjc2Ld9EtM2zK ungB2DGZ192c
NKigIidkX2zA9J6jC9FupZ80BCgt/Bw3D8wU8YDQQ4UoPrM4XFJKrmVudBzX EMk4OifTTRu+
iHAlkK8L5zy6xvwEqHvYr9SRc5bOEN+hv4Zj9NpzCanHH2Fd0hbx7nH6VhRe DjrGT3FEJxMU
fRDdGNDt3VsYFDAL4bR+cwsYpNMeEgG+3nOzO8lVR2Rk0La2cXQVuZfkrjSr 7hIRZLKqoNim
SLzchphUwp3s16JI8D+NXlJHHMha3fFOhUWcI1hGFBVcUXIdzvKCaClL4FUS vOoxGLgvwe0i
GKxY6x2Oh2jFl8T3dUQ+pmRaw4g2lDToKLqbUlCmXXlV36t6vJMWj+rQOSlL BVgFHd8hp/mA
llSk4CSnLzlOgzf1SP+F3rzVHsKRWwZ5UdGlnVzMFKaiGULO3ICHdu9sE3Ry Eg0fdloTvWgi
h9hd/wTV5CX0+WONcQWYmLjel9vokq6YBh453O0XgetKl9zYU1TJhM/6o8CF VfqmaDKult35
gf0PRt2+CQ+v5nyfL3I96bD/NPhuENLVZlc1gmWZo436tph3xFB+OiLPRheo PEeFw/7njlv2
nqjlfXK+cAvqBf15F0HYKGyN/6XQz3V2Mi7i2gvNObpcijZcMpitOQEGeH7/ +P/BTqPZt9/T
C1Ne/jmisqv5MEWFkKAR5UqSHjMmY/qQDjLHhqEWaHs9sAgKXtZjlow0Pbbq lEzaTvSFxkla
k5hhV7LY9YqXzg7Fe0IWyGX3h6Nwos4N1+5jSp9i5IoyaDB+psD14jYomWM4 oANh3/IOMnqg
AP/4+aLIX4YYi1aWLbhydcJfAA9cwTHcDgZI8rjwI1tD6mJWg/PsUNHJmNrw NmmB2Lgl1l0/
rYvxYdYD21P8Bu+TXnTaxa3AkASAC0Va/6YvO7BtFMU0fS9A+qyvX2bC8688 ZD/+jLd9+nFJ
bLhnNKpm5sZve4f6t105egpLUK0VtHx6GQ75QJFBrqI+iryGbSD9X208Qbgl c/TuRd5N0xw8
7VLo7PcGt8ptGbVNLODilfynP8B44Z3x0+Z55Tlt5g4cRfvrUKDwqDjrC/x5 eIQZvbjpmnJ+
bDNRvHrjSDhTbEesQoFAv9SY9rfaI55LMEAggajHgOPQq3bziYaroU15lUaH cd1kE9JcO2kB
kLGwlyTN7MOWXX6eUmcPXn/fAu+RmZljn9zp7LpK2yhitKQgNGuVsaxennpb hW7YLml1g7iZ
NdVY16eWStzHW6quRmcHAnVqOGVIRZStPuvs79/CBzEE+hrA+YpgsD31Awel zdm+NN0y8tdM
5llBZgZuvL0Ngj4fa9FvttmufxSvbJ9486jslGngkWwWi815NbR51lbAGKLz cYJaO5uNY/p5
vn2sP9gDUaUPVc1owcDjsfZJKq3YRgJDRlAhNWWTRYwdOtruqvL33s2+Ol9/ Vv+if4xW6jbE
bcSIn4se/OKnlUO/qM7o3YPkIpDQr/GhderCQyYXg+D9OtyTBOw2VKKrn9jd ix9mR8Cw57Z5
xcZ2P9BpeAkq6JVmPufbovw2Pw9DM8NMIqkxMa9L0QgUbUlX6KmzhUPmuIMe wVEVk2mjr8v1
ZbjbD6tLxYt+v15/tRXSu/Owl/4nn2kWXAVuRHIRhfFPFQZYDA8PHWe/5siC 5qIupJhXcsm2
si8hBDNkTS7MHWWUWPH9g4P+c60tp/pj2zbjJSFg2pLxFiaKK0XomZPuWmT1 bfI5S3hLmTQf
b9z/yo75B1FM4g88tOtaH+aqPa3Ees4vF32JlMjAb6JoE2cjoasRKb4pqIaZ 5ZTXLTV3GGnu
Ob+47laWUNqSC7lBWJDjeXUgSnFAnoVM24V6Qqu9cai2zXE3U9yhOiaoeE1r aE7JSXIs/CyH
aN7blZigQJuPbCWRcvC9/cRHySEeaSUlLad6NGjobmJxRGm9yTt/JPQdGP3F g2korYwQIAHY
1ZpS+OVGViLzuEu7nlh0ah+K9t0ImdpOBfj1izMAP+1BQ594HxV7Ka3fvz2F oYpE3Io2WA/k
cXltUImrWUBUkqK6J0i2Oc5qmOerj8Y5dqd801YfD9vJvEvMFPBboGMk9gJP pGjC5euTgsgZ
3Xllm8PxtqBvHY2LiWR7wRmy4oSOal3I5SXBOTfwtzEAW6aVmuh4VjfPC1vt BHDA//LQ1KYp
gfYtpt8NMdNV8O6/aVhZhu77cHbJ9F9Z0B+24L+aq49nXEGY6n0lLFgHRM/L +kOkioS9+T+X
+Dm7+RZnumChGu/ukALQqTi8/S1aZB/MqJo26lsKfp6O2KkCv69+x0lxvqNe SrjuTcpyb2Lb
icq5zd4+o1jiY0cpc12hc2LOOzu3QXrMqNAhUQIWiLsPzDP2SPNnUdnFxwmi BqgZSaXwxC1z
IJJAHmOhVAddYXwf7SSKu17h6rMQV3U1rELKEvw2lV0DYFM/XygcK7LKDqBE 5/POTOqzBp/M
rAD+JPCCbos7sEs4+tdt/w1MkOy4sr5iXOzLbzW41QX0TP7m5V4aUilfGZ6u E0Ugj9zPvX6E
luDoVTIOKxhsTtIsdLCZ/k/P07IpbX+v5N6dRneGT0O/nLhsvVOpeMlQXJ27 AUhutND+NTPv
AZ35aPGkoSCZEr0HpxSHKLFF5sSB9UB/LVqkxN2ISgKw7d32T88Ev+uM71mx idC+1szs/4iO
iXQCPaY+8ZHFASpx6UHLdyYETdpL2rXqXFWjK0XTRweLGirA6FTqxasPj3qL SNtXSO9IGEHF
k3wff+K+i+LxJxSdgtkQixNVkwjzKO3/JQudPZ2yNXIasXBA/Wy299YHCFrn i/HIeMvbKVls
x5uEWO3Hcor3eEwUUI58iuR93dGMju0ME4qyU55uMRTAEx9vYP4vxPh+I+oV qhtbtjZtbKk2
L119deX3n7JS8806YKeXuGyd1ufuZaOIoFEfwSemTjjQa36YSvMY0yRFJ7IY 5MTavdJ/fS6A
APD8UM/AmNLnM/8kb1+2PZ0O8vbVO9Ivt/bz2XA+GnMnDmf8r4pvdR1alaHM df7/V87pkTvs
XCFjGiG23yM1pC2m6IAwUN03tyCx9i1g7GQPGTFjYo3YXN9v4yzxCjPHn/mQ D1WiwuHvFHhz
uf6PS7frtFboNDDPaVghT17DNkvvaMjVD4BdVwxLLiN5e29B2G4dQdBPOPMv 6jse893SHood
2CaBj1EOZf20hf4trQQ5NLuG7P60R5kwEIw2bdpp3zcFSdF8komM8aXD553e wwmseB7nMnZd
8h1LqpUueOxwW4FWffm7oBtH6cDfc1sqFnuGuihd3i9xH8DkcSb6RZcf4Uyb Xn+mT7P4hITA
hsGiIYC2viXqtJ659HeKrJGIZe7UG/8P9p3SgOBJev6MPNrjSxpQ+SQVxo1t QS/OCy5iHiG7
vywrJzcDV0Dx4WaUX1WzRGZDJcuUi76A4jna2CW7j8a0m3Q+cMzJXKVyzFTu QZHcdX+Ry2O6
/unhn86eAtITogcDpMDtWSRyYi5zfhkG0cz+yQO+Z7IV6+ljKNSSpy2miV4s vzV+GPBzhQVf
2zAjcRXDzqDWsf6PU946sJ299PiIS0qMtKA/SXGu3g0T/b0Eg3PngNvyhIzl Qa4TNNaGPxx3
N1PkrqEOi97vpbarjoNmB4hHdAnisnmq/4cXEJgid3hGGkiI+7kPu7yh/Ims R5JrjWLEZUF7
SSIrP3qYY7HaLsRlRKWdyZ2pU4hyIKq+X7dtjXJ+Hv0Lj8cfx4mWsbQx8ym1 jzi8VAmKRIEw
lJ2liK1i3o0b8D4TVravGkD8Ly/x814cllI88x4/uyukHraD60sGKc+Aeozm 7UhcGqqQiG7t
njtq2ZTN+GaT8Q0HNzatcBGAV2gv89G1a7FVMVEHJugKSr5TtMS8RhwbFfVM N2tvvfEjgVZs
jBXv0RSGM+HgobudIZfP+DBtycxGEsoIkSiplbHY+dPwAcjCHDRFXh0zUMqB DkuNm7kpQzVV
DKBj2NGho/o8/R2EgWrQjP6bvHJczPLyi/YPQIoUDDmdhOfmOMv623sevP2L nz9vWRI4NKXu
PgzsAsjIZA4pDlWxKm2QLpNyB0AafF5vluOmFEMf8yI2er44uhyElQvwWkL+ BvCZtgf8pfOd
8+CBygouO4rgiEhG73VaVYxrod6FqAzTmv8V/lSm8aiV5je3/US9wpkoa4hT Z9YEJUGKxQcE
RfrsDjD99uwYh6czY/Zb1Gs0//C9FMIZPQIIRzeQ/HIf9kpOZMoQu/2l0BqN prUFnyYzkrkN
DG1t7lFJCybVqLmS1RedJPjqnhKvD+xUwxuX/oRErZaLA5NxZoxBKz7RHzGi TWFH+hVNcAUw
oyv84tgAXW89J+OqXw+MqXA9SvdgBnlRXDpwc0KMw7tS90EpdPyEbWA14Sef 6BTLsc1qAxRD
UggFFiqKoYUB4CAtXX5FCcCGJB6aGK1/ilopvHrX5Ggt2qOUQpUlFxfwPf3Z kYmRuO4itsPa
2tbqR7fkK6tfVp2j+Y6wxDRni8wmnmJu9NaXN7HfwkRy17iO42h9T5Eg8R3b Xvr1VeWwYmko
z68ifNI1L/bM76k64Z/s/wRdRxwzf338SKCnhvVF2X08Qb03PptermFQO718 k8VR9JeNTiHt
IaWcldOwUcrwfg3ausBIcdgWD8b/nsf+hmc3sZ33fEyiGFcS9vKX2P/4ms6y xByFxN3o9/T/
iEMxq6G3MHYJlnWP3KdalB73h/cWHDaWSjgZH2GqatHdhkahZ9zo47GuFYk7 YUn4x2XXW9AX
vobIJrfR+dSJhGkk4MoHQD311cxPbCCegyBWrmtQ0wPQHdsWpUKNFcTtqq2/ LRBZoesjX/bY
6VKUQznj0MJy4rU9VSagU+AReqYb3tFTCngc8XuhDFHCtj1ztqNE5BtlR5GG deQeOLEY8KUl
nuD+GRlk9xa0SX81Zh4zevGYBOMvyrd1mwrUyndB0qdNiJG3Clf3yv7pPGUx v6WBj/lHyrqC
k3LVy1nV4ogEC84Yx4yVGyrBv30Zn8KCso5GO/wJHeu9P+AWvzjyiJkOpTmI fdg2RIW0iZSO
mAPi0BK1F/kJd+R4ugoZJ6qcoxhlh0nrYkbl2IWuoUEZW0tSZ53VgW3/co7U mbmHv9w+KAjk
Bp/wdhsVGWxYltRPo6PqP2HFoXLUbLR8kbczmqA8Pk1L2G1/CJac1WF/YzJU C9+ejtWCUdWU
kE0mMFcc4EowwChsm9e4+M2hi4w78yfZMUHHfuK5O0F6JCuKvL3sXv5NBg0I HiQu+kbljeU2
bM9aL6ij+awxDKEzdWuzGeUdp9mCq4L7faqMAvbrLPdiOFy5rg+eOn9sX0Ml 9w9OToF4oQXa
AdtrRzF9ks8GaAuAnOaxcmwj5/UKz2Rp9pVuSYmfgFApmod5zgqK5EmW2X0t wgx5H8+ZB9NA
qBFQzeFEBuaPQTQCIwpXaedErIhuzxniGrvl5gjkTMt28paC74sHSBlQ6sXH fgBXwl2gJ2un
XYB29QA6/Fj4uqLsuPsvDrtE0JoblfETuRA45PlsrHLRSDg6eX6kwv+aAQ7d e+ud1CFoWCVg
JWtCfMiM2MNoNuE0KVTz+2MSm2IQy0/OhZIYjl8Bah6ob8rIO7meM+hHN/7U 1tWHNFhTdckD
+jxlA23oFhuTJFzw4ZMnm+fLKBG1Axo3CPwgfVuBQ+jgUClkxu3qfDMXJAex hM1Y9AXM6EXl
MJDodjBhqOnjm/Boz2Mh4XV83ifxOyDY49Lh6bgVHHrf494vMVgMD9UUPxEo uXZUycUW2wy9
fQ232JMbhjNAuivZC6kP3Zq03BBMzK8Oh78oNCqy9g17hT3YiMQuZNcuHhI/ PTCJ1Ev4bizq
6lAVj6IqNWh5PxibDotKbP5i7/WPsxLmyJxrwtn642wRzYXksvGKDTkvAcZC tM1Cs5N56+e1
d97AH0Vj6p5jSU9fz/STLl4lD6qxSnId8rJc0+a/VXaJ/BkUMRJNsweEfaKv 3doLfxYRyKNG
pntr3OX5xl6csbvYgIDKl8vNdcLnyW3sGcx1W/OAMfsPYP/luyGgqFoRwc8M I6z6O+pZ14Tt
HZmmEZp7gxuaM2t0uZHvh5eJLR/HPyfagsat+jBAORX6LubOxTeXhWcJVCDB 3S0GJXLS3MsG
2u7JghFFM3OvikSpeLX53RLz1vwmk6SRV8xAaXtdN54Om1bhKeZr+IUWtkmW NFuygUvKeHIN
PD/zzqU78j6kARpXmenfZ9Bfl9scmQsS+9WH086P603Y13bC2BdKMIz9z4lX MmFg/JBeosTj
wUmd+3+WhsrwPpIbvzGpIUheUU7o7M8lfI8k7Df32DLBKo2GvIq6Q+maCVHH MNoP50lVIBvV
RfHIVwYFd+ZL9qbc1E9ZDR3c9jEF69MWkZsRRM6MxYf3aZ7Fz28lNl37h5vf fc+tJEQe/VxZ
gvvWqu1x9WDHtxhyBXa0gkpKTN2+15achhgPzGUp1GR5xIxE4JWMacq8Wq/v N8vdltYb3SRS
zrgXmTfAFcEjT3V1TE+CXLvDwgr2xc9IG6lGYPRyJM4tHXGPxFnuGRezCt9X lWs+1WUh7riP
TAGfSyonxP4aBfSxcpKIs+ZBA8etvbhQa6FWH5spfIralv7sILgtYfi31xoE SJCoFO8QGH7T
qqjj3uWw3amzQ7C8Suj5JoXRACLKJCRFxmM1FkAZ2P4qwnWEstjwwhJoLsyH 0poMAbUcqRE/
armdXYti3Lyzpq72F4sxSnkPeVB3d/i23RlLjatIz7t8S+XNUZl7X4+v+/0C 1kvfKkE2ro98
W5+V5V66I2HrmMI87VSJxwL+tskeFeC/jXSISyI3lfMmQE+60MnhxRklcsVm c9EK4EYhEpAk
rTWOYS2B/ywhmxFt2pgigyOvFg/xZZLSNgmii+sz1eOHygBr/RTS0O1lP1kt hxKPRhvMCypv
zu0HXa4Gmp9bDiDSCzUH3W4cvPGyEu0V5q+1s8qSG6qq90UayI6z1Fn85FGq mZyx8X29LdoH
TTC7NJCxwEa/idkZaA6KaAtvRK1nzt9BhoO8JgVvCDdpmlbieuzN5zrgIERx MNTnN3YUVu7o
iJ6zIY6CWYIAtPC7LqOPmc11UFcZ9u1woyg+3nYyo6EHfQNe9dmaL5Os4o6B XszapODziou+
idt7eU8AVflz1BqN7JltN+SxaCVGUpNtua8fJPMSSg0hDm8HbePXnJGiwV4e TbKxHXHKmy1O
nNN0I4s0I0lLeXXYXmuj652JYmtLfqA7g3pE/lKvxEwlJamGVn8hw+bP3oJl v9xJvaqFD1Nt
qpXGs3uI3I+7flG/yYluFP6gg7jIulMvEDSnupNX8aGNnWjyJikHdvF71hXI MT8fjGLoyfKx
ksfxTuXieczV0W/YQe70sDFvdemN5XjJDMt9EqSdy+YMg27f3ttbNeBOrjKH 5wG1Yu6tWDX5
WLucDsE+0QcFR5VrbxiveQVABPDTzGVBykeQuNX0Zqz7U1/CyAOJJVqs0NpN 7uXRe9D/KOzO
AF9qXF5OeBaXDEZSdxup854RKqELwC2yLl6f938uAuxra6r+CZ5GFZbdhcUt FN4oP2H+miU+
uzrtPzva3YnamReb4FkMJo/Zz4UgdSj5tX46XLfjD3PDnc8hNi48Zjml+DJe QjacTO99aM9c
yXazSqGIOCcljMbZjR9ZGVA1LXwrzIlknlS+9rSD2Z2kAsRHL5odlbLABmLg Vlo/otH61HAE
huZKOpPk06PfJcDIiLankIZgmQa1qlujoExMrm5phx7qCrDuXgkoTE5Pu0K5 ikf7u/toATQq
m439G4EHt7t9jrGAlPSoenFs2AxkT/9YRIhdcebvkrKTvmWXGqAa/IVC9pMV sGFWIr97m0q8
r6/Fpa3oZNxlvfQn0zkZ/3XFKBGw0XQNAtkqgh/rDCFGxkz8XisTE4nqLZA+ FXvB20K2TFB/
VnhnLMboEAjn2nJ5Iv14EsCcXbNX38Xwed4WB8F5g/Kvf6ldo7jsT71P2hA6 Vq1Y9j8leoqJ
nf9ZaEB/Y8sQfVTSJJGRda215dHpFDClX36jPjhcT6H/L1JAiplFdCHZh/am QFDiTofFbB8Q
MfPutGTEAgb6AtMHz89ehfl9EHV9GhMzObJ1r4bZdlL5+aZkm9zYexiIIAnU qYf7AP5c2P7c
BXe2O3rG/27psZ1wAxyMxDcEd1SzVrQ4jea3ahL0M2KfIl3BJeRefqwTUkbd g2rYp656Pijv
6erFGDzhQvndB466/Y+O4Z2qpZk46e2/8lzjHmSzNHH3T+I1qmgDtZ1IayXW 4XotTcepCFEw
piCO2uYj+tvAvEJuA2CuYqS5nNcxyasXZnINEa13O1eotSP6qS0L7NpRq8Zh F/Bk+FiQm/dL
tdjQkmZ1tqMjbnpOjsl2YDiWe9wWi/CKw8TTanF0R1l7OlBbWrHONoq1I2ar u4W/U0yNhMYu
y49k1aXpnbmm9eD7YJWyf9hA5XMwgKVOgtqWFhJRCUh1hb6psujY2/Rhw6/9 p2XQ0bQ6TryB
HqmVH78gbV3ipRzr3rrW97Slu8Kx3wdQWPqBkRKzI+V9/KBieSklt5I085KZ zLbmp4YaoVNb
UTC+9t1wFoVFBlquSrLXyoif3S37oNh1RNe+aA8YZsTeLvtRfWQkXd1sxoPc I/a0qyvmJz6w
9s1AULiK/9ofiiFilxCc6u/qCojaZOn3PJNsleSDAITD6zidB8RyKQhsdxd5 yKDikbSJXKtx
XoaZ3f4z3uCqzkW7YFRG7xA5KLvD+hfKLinRVo5w2assefZTV71KcOE0nM51 uM7dxsCpZgxy
kjPEOHLfCA8Nf13J9QjGri1vN/FGO7Lno04XHEeg9OCkG9u4fXfPC5inLvVQ 3SwQmOWTdQEK
gWhYLykYg5emyQDNjU/2iGr7Re4k9lGisjGJRGOgIC0yI1y2qx9Eib+xJ7jX B04dF+LSNDc7
fms7YdHVxj6ZvYNYReKxZiWaWxy/Nmv9Tv/ncjMD6Nyj4QjnA4apK9YjaO6c 8o4+QlY0JF24
LtnkwVKzCGGooMAa051+GiI+T5fWHWyQUe1e7/4FOfQ3pEerEIcQ1UOPB1ZA LxkMmdMH/jwu
G5GzxEJvk7Yr9EcCqlSiAiBST9ZBJwbUTMT/ui8/MWPU8TtqE8daQbCcVHYg 8fmahJP1WXd2
DaSE+2HZtlrfrBMaZTORxkRlXsS7xw069O5C6qZXJ7GVpD3AwFRguSrqo00o njN0vg/5EQsn
E+o6Ncgak9EKV6MX/LfPguRVdho2srsnySVbmXy+uE3SMXjx9TAmEIJtdY3W U5Tp2SIvgciz
j0uwVAe/dNTfiIJ/O4JlzA5VOjoCEmgVr5lBGEoD/Xj+Va3mwF4x/5ipYi+C 5qrG8g47qSt8
B3IDVewPFdh6fRz3a+BgJNT/NPTMqnFnS/t2ViU5nizy35UfCS3DNr645rEh VqfWMONByPHR
ugHEliXjuTi8ArHsFZHmtjCxeVFwwsWnx3KtOEuCaj3NhW6MDBFMhm3O5yI/ CotyEie129IU
9Ct6ubwA1AVqpcyi6VqhtMh5SXMdyzaUYUT1+t79lMNAk+CQrvJK1xW/XIpC X39G8uDz/nyu
+MAjU1iUqMY0NL8garfUtQh2Op0rvmzYtXEyVaybAha8aANfFIYURz9uG9EL mtcDR09k7r29
MUVYy37bwQm8mPsXFMA+0ctYwjRLoYyFOMxjAGSKz1NaKoUwirUbnBfMxPQk ZEV8RldJWhaj
qMu3nEHwVEOeKZaplLlj/w/fGJk522nN0pLrJepmqFrJaare+nAhtSr9EqGb /+f1nBkZMOIX
GGTH210VLbfWqC5UIo8tY3sAjVaz4oivMkAQ3xbTjtzvAf18L8xyFgnOo8hF y5OAsjGpj12o
S1Hal77wlLggdBbygdn2bZSzfqJ8PvQSwCSHcp6LhYAr8kvvyHwdW94bdL55 oeBu0FfAxYmF
XpRAfXCLvo4R582wJduGh6qYqQFzPN7ThfekhvUs46PqJjwYbKgYbYuxCFDw kAhLozAAX/gn
F6HRiVMKOg4/X1XuOmNBVesPpobxWtcjuquB1LLgtMKa0/LKdCd0L0ceM6Cn a2Gib/xl1Wn+
AyQLHAiX8PZSOL22jg5cq6qfEsk+uZjrFDzoOazrr4luvvXO2F5MuBcdEoCz TuEUu4GvUymT
ZVhxH87Bc19rb8smvVUExiGKrUBZon7R9MgqvlxbOfEuGKSSbsaxM4zsXU2I lobOThIfQHMj
nsPOXCIzxrFHmhW+fzWZgH4IVYqtu5NKxzQDQJK1IDwl2EJX6cGr9lxfIF4t FTN3T8yKLfwK
j5SILPUDlrGwZ40211XaG5cAJYl1XuJlZYmKyXu45Ru73modV83/3Ck/3WD5 NctXEV88jTra
JciiJ6dYIEI59+f3HMIS7mcgZuMMXh5z8XPx5yrNs1e/NVifFMm5FsD9mvg7 lxp0fZ91WRIy
PBF+l/Cvz4g8hkqXeSipi/aesltPpgSDnPIjoRwgJx2how/EWTOxE5Dn6J4p QR0UY7u9AjYV
Wd6JIogsGKHLwNDZEy69DY/s9+TJV/sLnvmBAEK64i6m4qVwR4UgnRIIngFo A2UW/98I0ZdC
vAUb3aO0+iCt3/Ld4DKPw6691AHMinWcSLQM3P5+aOklMKOCW/GS3kCUAaql awK7vfjRAzdi
Lga6cTm2Pk1So97lhF3vfCKhkJp6aPWHgvxhBUzzlNKls8MYcSEtjiJ9znH/ 8OBY5d15v9w3
gcXnnAqDUMTYCLbPsjvB8OF8L3RzOpr/Ny4SQfAl0OSODRCFtPFnMIwuKHRK lX4Aw8W7Y1pJ
Ql/GIPhylqFnsMaTlielfJqDo7CGZLE61sKKh83BREaO9MRNBFxlsuZ66pxT SoERN7Awi+su
PHucClgFuxPyYTTAkc2XwU32RKIJUiHS/Dq0BbT3/DFJOkk6RtQCzSP+r7la UyJDZhjPURcs
zRA1seDC+rlvysUcdpmuP1ydSaM7Jhp1xKPOTycwlFs58UG7B4h/lXFx9GRp RLb/MsFaaW4e
LvwAIpk0VWdkSG4hsBQK08bCuoD7ZxkV891M+fXOZopK+87ZwqfDNtEuikUr ggY1vUlTwk3s
Ar+xkmvSm59H0CA+hQf6LxGGp9G0QFcuBhXuSfjICFsGIT9LIqTOqYu3lnPq RDhcQnlFAoI5
zAOXYUVadAZ2/335WoA5YVYYylK49ztBMBES/tsQEBXyErEk+mBtexva4t6K OGUr2BbwqDBT
4uKuBKSXSicYhesMyzczAgqaP/YTnB53XWFCw43Ory08VChJj1uu8qTvowJJ 4dWjz6d4ZE9q
m3mEdWf46FmEzgLYM77+tEJYRX6xVGvOPXRDavJSTA4IjrdDzhGOLqbYrkvU 2fjessKQVSl+
3gR+vC26vqQm+np8SoBiRUhvV4tP42BmPR0HQkE2gNZL5M1iFNru93+hMkrx 7ZuX1JNExiLr
j3Zrl5CMKilVVhxwbLwCOI8yViwfX1GHOB+5srJ4uMeY4LVJ0Zxdsq6SkKAe vUPnLCC13Bnj
3xIg2LqdYfuoySfEQ+yp/jQkgIyMhC+kb6z6tEgP5bUXEiH+irvmkieCQl/V LPo+gdwhojNL
zvVZRXNTJYnmgqU1U3AsnCaLuBS1A6c5FsxKf2x8QISR7R78PqqlMURrN/LR 2PJ8Xt84HoR1
l8Y/CJ4cR4Uz7dQxnJh+wb5QpaI72eKJNhYez7Y5GGrGeSlyC3xjqb0pFImF E0pMKNRRU3z7
mofsbzttay+BTlpnX94VeN5XrYgsdJlKpG89z+LmQJ4EOuHc3i9a6kjw4jRN 1FOsCVYS0lTT
DMYKRwbnQdFjG2+f+d3MZ7X8ocPvJCTUHbDbU5DoJCeRO5jGmVEl9FGX/2ev f8olpOV2Z78A
wwJTyi5RFi9SxrKkR0Ykj+zO1hrKHnwkQBdM8vZyt4lKHi+ep4qLBE8zdGu/ odEqYxEc8qS+
EeG5OGMSr0OHPc4Y7hcgDDaHoQUJHuG138h3d1Mx4LerJBWVpFG3AOrRC6p+ hi0lyJHrVJSr
+js03rT5g5yYKzHR6xisPv9Iik+A/0/aNFnAZUbQnjFegQAmNzan8xlXPhq0 A51Vw5xb+frm
+SMTO4YzU/+Cv7YGYgF9m6DUC4qrx1uUD6hUYB1+mZk8jN0a8dtuUnw8Fo0+ x/X/pRkQN5e9
Gw/mxlTwjsQtv1s5kbNPDQA8+3eSi5qErIRLFJCemnWo0Z3YZexJ8GKNgRMP dj3M2aH9EniN
WoGDoYC3uo0diyCD5+f8eEQHonZ5+c6SCgKRDTlc9uhMeMBZvb8w0S1jrR1d dxetdHBfuPDT
1PMab6ljdieAiPnU2NW5CYVapBMIrzIUREv2+f/rVMyp32pMhrTNa8/2Au3q Rn6TE+B+Zt3R
FxVG8rbJST0BaMzJrxovWVzNTvrHxgc5QI7LP/zsCnhjDiPCgEOr/+XIgIcO 4E0VsKASnQeQ
hciatmW1tUCrf9HaqPq6n+sjh/Z/6rwK3H6Vmzc7xqYNIltHT0uCvYDQ0tsf xR/C8t/D0K7p
v+SvUIBzwYBD6Zt8BSpTPLnAGYSxF0oLpsY4CdTsFeCW4dIQHjbsGNoK73Zv s0l3taobISzY
HCt1NBqw5S6r4wzV+4cJnR8/GYEM3hyMTLIieGSDKdC7u80TnviEeFXiz60y xbbNfq7/pwsT
oMWyJxcu+hVC0zcWMm24TQIYZGC83u2vd41wpgDYJmxGYQPGBFjsbYFrcf4G bnFPjFFLmDWM
xTB7blMbWe33A5t5XewFasZFCg5REN6MCnM7GYlDGaqQp7e4qNqcjx+v+Ls1 rqDXRbV7mHhe
25EvLnpslBZKWEq8qvs2bVcgRwIYW4ZF5NyIy8HWlcr/4IYfZn2si32MnrQI CFkM2/uSZnYz
TnvUdY2CtTYtEEGkVDLdakYsSyriXuceeT6Ha+J1f/+JuX27ymHmuuRRzQuo 2/5Th6YyC4pV
Kn061S7khi56jlbN9u2KCKSN4OU9wNPmI/+IXcOuSnKf1d0d5dPU9jzvKPap BrUHHRgoYQfR
uoeKaNGmMYy3UKvYs1MgrQBN6DSsWmNGotE38iopznWWTw3gMxTQSIuaVtvG fXz8lSwwdVPm
bUdA3DxVa4HExil1LM7EfG+6MUIpoRZwYgLDssAW9O4J6edpbPLb/0JvSZY9 g7PDZdUqZbgw
VN63qSYQ1UlrxLmNTi61BmnYzwXj1+EFAvUcJjiYKFL0sBJLUzMYjDzvPOJX wIyIesVAmo60
6PduamCy1F+b4eexZE42j0IsjWvX0Z2W/Lrsgp4NUEUyOoMb6KWEIWDGwt5Y 2g8jm3vX8CN+
k7PI3/6gRZsFurEusMjavdoQKP6bRXy27N4NaNNipf7mSo07IjDcY+RYwFTf cu5up8J4PW7c
z1zQp332dJG09dzZnY7WU6dU4MEYV6sPDxHfnImG4i51aKgfHDabHWvwsrl9 Mg1bwLjpgoMB
adOT63iaHM+ASCo+OOjd6uO8fHmxtR1zob32cX/zK14n91RbP3isfhxOhHaN vUj7Q1geF+dF
T991ZocCDKDOgOkIYDVcqlL8C7Cg2eXETsxsZHY3QBII+HyfB0MgP1P9j+4r WAX3e2VXH3ct
1q8skFgWVPTNvSEcpEVPgrlrTUt8cd/wqcqy3lTKRb1rLX2LJf6WW1hhLbx9 qFzkNF8MMXO5
x27ieCll58OnaeQR4shR9itkVXVr5ZxDrT+pesGQUd1OHQYCfbEcKbDqkjHO U9ODbh1up1CJ
QhVQpR2GNBPoG/RyUGOtF8B7FF8/uk5YsCiOsSsheIq5p6/kG+hQ85mcbrkZ U+S0u5JO9YKZ
6PB3z9hMFQHMPGBgWXDOnetJ+58M5LQ+l9TCOweSnNkS0yDCkLw7NHWHoeem BQelt8+jweUw
swRc8P9dduei4HdPZNuaIJiYLGrW8EjYAfxq6DdKEf8bjshEaauL+KuBQ5Zn YmSTyWj4yk4j
a99esDViWBx3nBTzYiaHC9jhnhWvYOV1whaMgjc1pLntlgmUwSgHru9XkeFN eak/mLtK/89Z
Qo+fA/86qi1cJNypLBcEEWRrpj54Ia87r0HtvOR157w3M/QpUI0NNIh3A7Q7 oy7MclPnUSXa
e68BclWJVioOaI72l2rlnKVlb67bwfpomTGwAlkfPbxQtq654zvrqjtCWPTH vFEaVCcJbzrw
q1thXTLZkzFa6xO668qBmBiRVs4n8FwP1EFGm3j2t2q25PfqOmBMn1D8Q6Lv za5RBQlU49NK
nMPMDUBL74q3s9QZAN+cq8foDm6Gwst71MTl/IAwt1SBF7JFiEU1tyIcN7Nw 2AWReCkaxZ66
RCPAaQ5fI5SlUtaIQqzSFMIajSI6G9CF7UwNdlxIcFxkEtQdFQii6aoiF2mK QeZmTPGdw04z
kAxovEj69HpWuzTbmrh90BH5b0t3eNXo1oG+pNWGqtjxl2Vx6KntSO0G+tRH qtfo1RDgfK7+
nfm/zJvAZTII46S/hgH6IxObX5AHAWrpTn6dJezbxpnnFDX+xg/Nhwt8gSps +Y5DTFV4Q7bM
njFnmP+VzD///7VQQjH8eKMVoejigp8nUN4MGjLZCabY+TMYWbLrzcv/4it8 RhIqJS/Q3Tej
IgTmP0Kt5v/vLWUP6mo2/mqhtDPOXPKsxedhzS6leUhuI4utvhvPGuxc4HOY uIlL1iNLg8pd
MerjTrL1Pgw+OzdA/CGygFouUALkn2q7aVhV4FkXhkrkqIHE6TxkEh9sXX4x +63D7HKGQKNy
w/9BbqNq2+KgogjxYCrE6CmalGZUjTSlUbN58Q1Q8v2wixSLyHiy0XUovIl8 djSKBgOFzIb9
98lqY3SQVgHeG78yXYFpTIY4iDK+Wj4fdrL1Fhz3A09uPcYybMEKni0FRIyI lFbLwCyVb1Zn
3pm5hrJI0DPJpiAS7U1wXV/2jCwoKeNjnC8wupzyftOYu/LNf/Ou0L1iZkvQ YJpodWSU5wUq
RmxVRN1OYo7h8oaJJ8Cvcm08uzWrqZY6mmlLc/U/NN7XHwx8I0fRRP/b/Ihn hZqw4TOd4KpB
6JAp/sBEUX71dW7KCDefGLfKFh2kyxR0AeT7U/+fbkkiawP/cAWmh/5RcBiU B0X8IssOq+Tq
38Ggmn0bZSzdaJtwBhrVhfv3wc5FMuVyivyWe6onFvPn1XfP6gQomG9chOsL jv6tKpbI7qjw
m/RidATICgJiB/w4nNZ0qFzVmvcDm/skXEYLKP0IZqO3vDulUKKnwVtOTSgO aa33/mazyYdJ
34PfCJrsu/lZFxdQOBl45tjP4wu+BA0q1vIVgj0KGEJGkhSm7n2tbUKxd96Y 3L9G7sNOYi7W
WfB3L3lk4wwdcwg/1MnpEN0ttjewuO2LL5F3+LdAagX6giiDB6loCj6LDqZU 25VMrDMetDlg
SBHvRdou9d2Fks4qaI1dYzS2wLzj427FS6+GZelLoOhqco6Quy3+7P9XDdv+ nx3uCc4ZHaOq
5uoIwqycw9s0s8wm9GT0nRZyCSmd0E7gHxy7GllGY7OinwsB2ESVjLIwScG+ pProjRP5qDfX
1mO/+qdsEU3PIz37DMuB1YTtru8shNkiiRb8+rL0YQzY0WsdkUtMkCq71gkE XcBCgVQ3ueMB
1mA3QngaZBXZycw3XkuyZBi2rAd6RYy9/0YAld/verfHRrcu87bdXw6e74IR INyQjC4XWKlk
IgFIkSa5HFPBU8JFhK6gPwe8lWvnuORMT+Nylm531R8k/1gIMUtrePF7+ver DL2KH6cIFmt6
bWTtd5m+9933icXVqVwe2G56oyjbX6jaM4NwHkELBXqOfl/2p5HfJ4jKypUC 44h41FKr8UAF
rlAv1obIwLkjT24uibF63VVh7Dz8nN8YfSHziPFNk6WLBbj+8YzDLUby2kmV KyRm/nPqD6ug
We+L9/6WdoMxZkBVSoDM0GJYu0Cp9gYsSTinFjzSYcvMIw4g51F5m5XmtSur P50q92J1WO1v
A2Ew+nPRbHPDQuI/LdUeFXnzZZdUKfOmHtmvIIiKTx5hlgfzjoRz/7qQ+LwU 6dcb/cLsxd1s
Eb9syEuBMgmRaurgtzAdX3JRAqFml4M7AcYMzQvkNIGo4U8ihZmVCUwOqBz5 QpccKStbJaLz
Kjq1oYLfFkPqRo+rrDT/4FMb2q+rCuqw/XEnGvt/TOIar7jxfMdCb0boNWfh TRWX4+3NL2/C
+i0rEsf0QYaAvvBa0bd5qNcMzRxx0fSrEhfhxtgQqWfxl3zrqBGc4ZF+DMuY acoyWgKqBJNh
yfHyTII3pW0d14xxfzxoFWpYNrxt5BsgfvN5RjWnlcFYjKMQG784Pgcn8xqg ceqZD3qIlvMb
Qs0ncgcst/7+2m9J7hUPHKDySnND39G1wz9rDNTuuTP4vKa6OpkGUNWFxtI8 QaPc404KXZ5E
ykOeDv9Hn7uzX8exYRx23SXbCZIQe+L6FnMLzgYLi+0T1uGrzrAdeRTsy0VI MTduDK73cKvE
9/VEyeSM3adyMdkNb7ktrc+coF1e6SUrWDDCNuWlSgHA3Yt6Gz17ebwi72cd 4wpk1gOGHc5L
DUUHhSsGBmks9c0Y5x5FWIhqvp8Y7Vk789/v/cWalkwv+iNYWXOTcJtrNKMg 1e0rfx6b20KY
0xHM2UAJ0VeG5K6zul/+SUCQO3Jrq0zfXTyxM9IZ387A11r1lbbDfRh9AS97 OuFlKrk8ugaV
VLdP8MO8X3dvbP5UcexSjE1jaG47o7pdCDa9LyoPNNbNBMKdFzG0Tvtj8KJu ciOJ8cDlwUIc
0cDN1C1+8uEjCglzw2kRPhUo/r/ZxwLk5BQo9eefPsku7tVk4ct3PVD/4tE/ SNOd8s/FsgKZ
zFSinWHz1sDX1XTfMddEAnrX8RsheDCLM1wC3EY6VWzj6+bjDb5J5bbZhGqj JZQlwdHFonM7
hSJXeoIDATwUKg/uo4/qSOMURry7/RNUZS21u4lp/0QpSxJGp0uT1rTmmTE+ guIUe+P3AJg5
xZqZZgSvH0rZWl4BY5SGt//7R60e4DLFCzlg8YC2Qjd+uDqXoHWk07kOzUdK AloyrlMelzYV
tInnNLbkvPLHq6NQLWqafIx1yKfCuON0cd4m3//rTKt9qPsDeKxbuB/BaYpk c5beJ+CDWlXD
IJM7WxIe81aAaroIBpX2u9MgIISPlbr7hnUTj0Bgiu+VzN5edMPTEYVYsT9r soC7/xwqsLvt
g2qRFzSdzaG4RbofHrJpUIBK98mwctkLUofxnP//m7lFRHhZqOI4lsegyGZR 7p0c4XAqCPQf
2IY1mWGgIgSm4W2jYWe5M5XIhxsEMthf7YGGySfu1Tws2hDRnRtTyto7HCnh 5wmUa5Lr2cFy
0oUTT1IqT3OhS8EvRf7TJEyEqr83lI/Qs8ptoCELTTaJJwfVgS4wRQ5CjGem Xmh/+qy2Dqhx
PBQ7vr2Uh8nMe7T/SE7C1Jw3P6Yj+X0tV67BN9cFve10v9CkbJeYDs9OU/DL 16D93p/5sJsI
VbZFSbrKKECEOhdpMXr8LE5NOWnKtGnA5K1QF1T7wK/S/xbzjUBLwVOv61K4 JZ+Niky2CO47
aT9vY6AbpTtUqE9blIUMBiG+85Bw9XuFUQOic6xSU8ZbeMS43REuXa/VW29w fg6QfIh4Wb20
pxmgbcQ3yb4rgSTvpTUyDn9WdsnD6cfqBgWN+CIHtRTnRagp63pTa9iCIzk8 GaY7rAuWPNGv
XeeMQPHa+veet94e3704D+I8GAg5djPFqjBOxIb/95xCMwSUdJm9nH9Eq1p3 GJ5oaRwUzI5t
Jo34lSYE4v/B5Ye3Xm60bi2jHlvKvllXV43qzO3auNvxHN0+ZlvjdsmQOb2X g62qrjQV7X9P
mmWG1aCwMgHL3hrcKuUDzirT+AKpGbv7vJen2CBlb/ta4MH9/ZDyNJ0dYTPT 2OmGapiGnVfG
E+ZmNxg/Y6QvvEErYG8kQE50ENNdMRIzrHKwcsLsbAX3CwMAGE8Znzm7CnMu p0AY6w1z+TXA
ZjXavC/+nqootjijZuo6RID7k0b+keFHPF4GdcnIfSPD5EIWNZg3zwsBdlNE d50rNSUmS+cC
srN2uo5G+p6jsq6YfIeAwPkxRj7fHtRuBN8A04BoaBC8oGHiOm08l7zw0h6Q 44BWO9mumZnE
G98jKYkE3HF2P2Uvd2a+lOAaySRwfvw992v8rfA+NjMFTI7DRKg+znMbr+zS fQy7+oNARU1A
hjkLb+kbAK6vsum2eEgs3wyxCu8mSN3c8Y+h6u694bIZ78jJo70xIH5YkBtS u5IBqn+egopd
FRvAXEdM7+Pdneyqtsx57mionqI7CbgYtJYIDFjLSf0i4VKk3LMWoR+mAKcP oc8OH8L1AToG
nIUF58rHtNL5M8c85Sr6L++gxHQaxjpsKNf0YDXkmuPkpTuF1P8F9gLAm0uz kN3tc0tLi2O7
qmwGW/bZ30iG2fIyofwp+u1bt3t8K2c1DQV0k0/CH3MkKVvOTn+21fOL1fQl D74Vx12QUup+
Up+92M6VvSozX/oho08VmXYOAVn1pXC7fMJWOeEK4Jjo3eklrLtXA6VUghOs UkWedJyinIhM
75naePRpC/YggQCALFQVAeGFAGU/+65KtJYNo9DX4JGx0YZ0ty8kcxLhKZbf McfUX5hNIl8u
6sLMNeQ3KyXRt+z8/+GreWKChB9b5GINdcLRetHPW8ZLkycVl14KtrRXM/Gt al9n7c9+X1mF
Xqhqizfm0n7rdhSPO/3jxAbtAeD2xkDfT5b5SDgW7J0Zjdy8p4o7fpF5e4tU RmhFmmBRVlSW
GrBcueeiEFczE1OEbe/KsqqCWqYvpiwefF+z4BsLeimfvkNteBQ5It4t8BX1 GJ5xWqdbUHWw
HcsQm56zpbUdNfk6labQvnVFFuM7mJWTBUodi9ZejAV+BT82l2WtUChp5jqB rBlBw+Ch3bFz
JoJWYESoWlFQ5YwtB98UdKndcxK72Yuud1Cd6//mxv9wRYt9Nvf+u+rFekfS 8jqMSDMTbvd+
lw11FXZSl+7wdI8qopb8UY+0kehO5OqdUuaim642F5J02f+IoNDCJYUW7sz4 4bdqJcGTfKeL
VZVG5V/X6nnu0UHMTti2O53ca6aA6Ey9jZe8E3YEvei00WzCJ++4g2yz1TtT f3qVFYaOPpqj
v8DqGNAfi6AYKXYaMSitSXif65onL/K7eVMZYTejKBDcIuFTT1iRXMZ2+RJb YQVDboLBrcZI
T5lf6YAhWyBWhGKX7G35jHx+XcyTN7eGRzfauXJ8O8d+fvtf3tZKoGDvuyXh +icAGj6UdI1u
7Ny6EoIm3cdeKFTup2zNRwGbeywE0ODrT3uPZh2ChRVovlruTp7oRVx53NyL uK+zQN9XPCSM
zMFmqetwD7HUpSUH361Mx7rdVSs1B2XREae+8npqk5jkn2oRUcGolyZl3oyc sMSl03vKbNUZ
uK2/FnmzRZ3v3act7VHd+0OrntS1HyFBNlM1PhfoiTb/+o5vvtz8hPHDoIgA jEWkNcu7LIW5
4xfjtnFIlHhbRHjpYHSMf+VF6i9/yt1mj50nscuRJjO5MRI9P//7aUg6bcGd ISLCYNVg+108
ChBSNhztSEC4n3ZhN61hp01Tbn/4cL6eC1MCb5XKNv1IkeJl4l6Sdta/hFiV VwohREddF8O8
/bQq8cHFM278mpKXaet2Vnt5690tBmn/MQ0pF1LdUnoENQl4rLaiaSa1xapC iV9MfwxvntNh
rc5N8NywEOUo+IBMtKwH4dLZg/RTa8Y8bdxHouiqrTrhYPSp36z+8HQ7UYUd EvUzbM4suE3p
h9UQ0psEQU8r/OtuOhWtlBygtUVXOYb43bpgbGNYb4r6VzI5Yq2aw6nkz80M jVy06AJixpPM
kohjZ68QnQFaLC+TciVbfNm34xBee2fqqDkVVKM7tby0joJYQB8skOjN9NXe RDxt8z3L/IIa
a7vt69apI1+uyNBfgmSKzMdk7ZAmWG933hlqsJEX3zjSVtSASOt7nalW24hO g1KV97H8QOf3
4uZRRP+q92mtCsrbUGgjAZzEdc4vQZYe/hTpT1YGMJJFiiarZccGMD+S7pGA WcosAKNY0gCT
CwlhVdSXEbuEiwtZufgX2iEl+DJuh8IPF+SSpINHOYBeicBz1ZE8M6JMIDgM qohvXZSO60e1
wMWg0jgtTnw7HBzddsD7xHk5F8fPwIrreVuypMtwNE3FtnLxuaRkNrFB7Yzm bpkBGOIowDQi
ETZWNRoqb/GJHm4yrYLKcqwE6WtkR4SV+PSvduzio0iAWh7t0RjTsECPkmhz K5mTd4Vu/nnv
veZB0XPcRq4t4jXgbYi0F2OfvPy6MKcbkrCqfY1y70BhW9KAm3T7diaJRmRm CHsckt5n9lKz
TKzTo3FFtzJAa/qwwgI6e+r2reBH9hJTqsM18J8HUptM5hmn02Zw5F+mikxW MTh8YeUjR2qn
1yiEatP7kgo7rKB6BLefff84ImBLaUF2uuay/sBFFN+UWF9AARFceUe2wkvX WzA36HX9xn3R
sCovSXw5JMuL7qTuqQPvfh+ahczP2sBFBMd+ptsLIVJM0r0IdA37NA/ZHgLR WDsDptknvlBF
WK1stjL8iTTd/Mutyc260nVmdlkpPpho3p8/eAfecLzvk3ui0M2SSI2ATAvN LxGlz21hV9+P
GeYeOS5vvnQ4kJehCfXMWYYFMOvIZXWHMzdZopALYGd9VV+huO6/VGq+my9R xjk3W7w5hTvX
SMF2REpadwTU4mwinr/ygV8o9osRyMtH0iUUNiD62Z9X4f2Z96EC0rRnMREy jlfGU+qYvnp4
WWrDiMN99K82/ShUgJdovxiMpEM7E8IyTSgQjT1D+rwu4Q8Y2XXoslg9/RzW igD4TBKY6KiY
xdkVgd2reOOH39IbQwjDpVOFqVLzxD19TW0rXbfjtyLJbOW1GxgKjyS0OT5e VRfxUwAvjJEf
nbxG0Q4rsHG1+vYw9k48sW+K0yIDlTrxeQIhTPXVtP6ln29i5maEpAqIo/i2 ywpnEEQbV9zz
TfHbuhA51vLbK4P2iQ9QmUpWSfrcT8+f9uHewKfisC5zyurSYVjucgwgxBeF g4uKHWl1p98D
dLgqMxNvsFYv7PsnvQndPPHR/PSHYRul8P8KEXp2MNsoL/6CUFbphwrOeCGe omMaK1jHcu7X
wMhsR5PbA7Y46Lv/99u32AmN5mkcBoelZ2moz8pncVTVNiwNsjPKobVSGTBW dEbl6Qr+0cS2
zm84NzNnDOdQUvvBlvHlYsPHizuDlBdLlG60lKxycQOZv3UBtZ0ybanV8UnR kdZzdQDaUlez
JPVIna4KNcEJyoT3f5ynGRoF84kUPbOxxBB+N2CfiAldvtLCv9anthTog5sE 43Uu63QWY2m3
0Z+dBnrIy9Mea1LSKD4QgHe07ASwIhIaIXrh9Obb5QmMZv3J+9RyxMPStl5G FdQf6UpaZ6B6
HXcF88botTUu7zZLxeTOsPR+3WChwtckAeSQc8x8mUmSdyNuH9RPvQWYMHR0 kbYfZCYerorx
rN0Hzi1HbtwQSat80rya1dPIQSMYBwPp8XIBIDjkiPiPO2lGco90kgDFWRII sVNjSQqyGidg
H5twU62cPfyRo+nTidaLycL+p7QA86Tef6QP1Nql/Tv3yZw9qt1bYofK+UXp fMick1PXNK7/
cfEf6AjpVdfNtIh+FW2pNGdxLl6WDGGjWttMLZI4tidlle5qJqnQsoru2ZGA js8hFUaryfu2
LjcxijwcGKAKb9SrzGZh47g25ICqCm6v5XzDGXcakzsYLY8PRGaf/Abep6IU oCWmdIiBmrDN
u95bVReEwZtmRqfXZrOwsOaJ4QlYL3DZWoRM1PYHy4kOaSRPN07wjxCaDq9W FDvuAtKDoEIo
Rqfma2CS5C/6DWmPR+XGTTtWM46wu8H8dLh/3TG630KsGnWKB0D4Ps9U1Y/C E1f7eADVcMcT
HqhcBIqvWk23KDaHU/R/y13tiKm8KkFngKIYS2GGyGov8fyXAVB5WKpUCeYM 0jrOnCmEgY04
hNd3wanNF9m6+TC2x3louhWDRpuSYBZ/zOz30iOLgD82xgaA/JeQ5h/KDx5/ F1EHyK3kDDWT
sfEW0HbscX9OOKsV9fx0DPH+4F9iEc49osiVFCkctc5UAGclFqCxh6DGTMPk O6HbOGKytApU
Dlfs0Ne9DjYSthCYrqc+7Hls3MpLA+6K9OA3Cg2R4an+jDx3NbosZOpdBH4o ee2oxcgvTM9+
4/e60clwxZzVgPb6k4YMe2Qj5894948tXNr+xeW5fGdnKCDgSOa52Go9O5OU gtoNR/leP6kH
tpprzbRaAH7qntV0uq9EKHLKK9mMscoO5C7sE1y8XszzZhg/4x2cnEPBP7bV jnJLgR4hFuE9
lJbJo5U1q39iCkoZRtDPUdDconEYUt5HucuM/IaHsLbOwJm8aTWBC6Zqh+fE u9eLrakUCoN5
Xlgs/+L/1aMbuyTFKjzq69lgDazo2chZWPjxflxS0P5dxUAs4pB3IofoY/o1 V2VYntH6w0Mp
7UEuCNqQgvOMAjIZPEMKhhSBj1iFC5Zv2V7aC5XL/skLKJBeQVgomv6tis6I kX4BR6Pq60+U
r1b8vD1uyT1f0s0gwYPnYOxQmP0m27fjSutUO4yLTkxcm+u+bCMfelsUuiZV GdjJT7izzyqL
3tyf/Z2hGl4ZFVE7IaJPgCojIdZKvVjQsfc8alESs7FZ9j0Wsj3pDWFtq+qT x4sdYii0RTK6
piDrmzZAVvOh8C0W+V6TA+S4dgu2wq3BQ8sIPGC2f91xuOaMFFwcvXqHcT/t rVXVU18gg/H3
r4p8CM+kWuviKMURJ6DjFP8B4QGgiQLM7e9BYBq6T2Z+V09nOjQ/Owh0yNwD WX9b0bu3jFnr
7ApCLW6Ka+ldwrrkg++4jO/aBMm3jSYNxokgtQoxAkJ4ldCqVEX/O0AhWdc1 pxV2d1LXJg/i
utO6/wukgroAjU9GQQpsD6mWLKtF6vTSr8hOANBgA0LG+YuT+hncV7VTOC1G SuBhGEWyXUB/
/Sb0cXsshbgBgcWIbrH5lW6zjCyG88vG5QhXSV84vCAJEKD9JQG2Uk7BeVL/ PkG+00jcR25E
wQ3HKogDFNu11rZq/394a/cDiI3xT30tl2g6Sz54xRAaq6URrsgPFXBFyhif 7SQOqTcnwV1R
24x5UODX3+rHcK8Vx+XD6X0fgLpKIHcRlBG92d7QEhmabz61h5rjiFutdkNr Iqr4M7t2POlX
kd5gBK7YpAb52wOzl6HaMGaz/orMPYr/l/AgYaiX6H6th+nUYDLmXSDyeskE yLqf7q+BQ9cJ
u0BnJG4xCzmeM8G2tMr2otG/paYvgdMmZpee3nIoVWHvVt7rsUGAGzxzOasS 9v9VQ7on4ELF
VHfZMoJgVAd2lbHWsItZhJ4p/+P1Hy8d7PH5qwFcShnD/frtqV9h3LcyiCq8 DYWndbiGXIt8
bT6Qd39YjZthFDDiB1oXQS9X1qJ6MzYP9BNu3DjuFS6TeVxZaWaxkqAT0MHM 4JZXFwz46dw1
PhZWGSqbvqOW9WeBjIESdk1/EP6fVslgSMdJR1ifJ/LzYbx500uYi5FgEwJW z6g3VG58HlNs
Jx4THnwVpUizMI2K+OmRhAeE9c4AqRZOFcX2poDeEGeTJKD18tnHd+1tD6sM fXIT12/01L2l
x96e3mdh4AwFgNNIb1+EXmFsosVm+Ln8FnYA09WDcUGr2yAkxGCMyLs7eCwc cUMwLiW3Ds3N
zkLqxpnoisMsKBtewkXKy0vv4RFGXvMEtIf4qRInQMTmf/qtneOu9IR6hKul Q2mmxvj3wkjv
znzcxLRBf/v7I/5ruQL4qBOJ/ecfKl5pSsxbK7LDCyu10MvKeVCm4GbOJH7g 0cGp0dOJAI2R
tZPOMZxKJQdJW3iS9GpaX0+W8rDeS/5xUDPQ0RkwF4iAgZzPw/6TT2c9+NHg 6l93VlT2M83e
ziZwA0cpaINe5EGKHu66DsUvugV4j6Hd0zcvCVomag6gsTBKLOURNBcbsx26 1af4rqSyUOHr
sMFKa4gZ68S6wtVz2GuOsZa+FJba1htt0RyqBL+CUsjLx7ZCsFbC9S63/NL4 mKPC0Wo5zP+H
Qc7aFZqXRk5ByGZ5NAFyp+M0CiiZKGLshjz5kT4XOXaGxf3fzPi4XJCZrGZ+ e4R0SQ0zN8qT
IRrmAtvCRi/cQuB2YdIkVAD7Kq97FHhy5DPZu8IVMvbw85wQCFBnYUHHV/gv bPqf+h8WKiC/
A7/JiraaIKJ8ixsO6e2phwo4/1hGpaUQggIxychV/SobehzkvMbXPQK56fUo CKgvXemmOW9Z
gf6Pi7nVSSJM6resdJcUf4YWAr9TcIZTaZr4+KSeylMOs1yDG8SL//IyeUQB 3W+QZUWI3hm8
II1Jo29kRmynMU2WyQUTRUsXIXA5docZwim2XtAfI+z88dBBrMjpP6QpGPMu +C0ty02BabPH
rqik+dqvysCO7lRQjQujr9rl0KEiOT67v8Fk3lWME0KNVcEJiDh1Tydclu5e BJKshlWXT52F
K2VBBVky4/wzJE+m+993n4sy9aDAK7mKkdjf7vylIb2a/R6Qz+H/3PwLdJ08 4zuL/rxGnw8F
Jl7x6OxEFUbkBG4eN/2P/T61Yb5skgSOnOh5kwITluNFc2TX5GrzAubGCJVG A+szF/fF7eX3
Zk2feo3V4MQK01S/nODZmHK65J9Ambp3hWE2mhg21sTUC5Fmv5UrHVVjRW3h kIhekThfsdRa
DYKVsYQx3JppEV3/HyFC+Gpn2StbuTygWSP2JzvLrV4g8xZzbw5RAbuUn22H nlJZ09tSeylN
09QNQY9AydQ/FY5jT8vSDLbcETgaaLBi4J6GnO5gUhenz98BJGkNfFecw8/y qoHjo/aD81C5
F9OQKnWIVifwI4fDDyB5MSJjl+5NwVSTXrU09ao1r+9UjsEcF1F6/cm4DOym 30PbxEdy6AwP
5MUjNYl0xpPO4iTsXXE7dfXgfhh7fkhy0+03wbnwzR/3PlYeLsGqwT+UsnFH 6rToVr3inNDn
qyU0dUoOR/3iJBkAAtVGvLKWmBxjb5r8RuzznqdgVHHbnV3u8WxOBPurFLNN 1ztfTTYvQp0k
MbtJzVHr2HDxtLSaowfw1yFS+mp0hJRIF6AV9BKvIWauZjArlGGrVM0frt75 OWHpuaWlZxtM
TEXts5/6X78NAiX3Afd7QEtLhcXJfOCl0+8v8DOIU8moUHp1abWWtarQYToP mlOlPoXcxsOM
p3Zbg3CGN3zpAzn/9RGPhkYFYuR79QDDEHfDOumtChR669GYAz2jkDsotQMa tXTneque/Bng
JEcoQasiMpXHHt2eO6uR9FuRVIuFQXzK3LUJV6//36TqqK56gZTUlMog+4lE RJyBVL0Uu9AK
MtcO0mKIKTEvNFjVbsQ5IHfnp2HJxOKqaZPAKMXT0ZTNWOR8WGmggpjba4bi QND2yvYUP0w8
WmTcIq37s41i7J+Np9YvFBDLm+Rn8vuH2o9cxjljPQSp8E4/kbQjH+0eWzY8 RKnKfXLvPzDU
+guneYmnVocLgM7W/JO96gPiYb/qNZzcu8opjoZctsr2nD0VVr7rUm8rWOq1 Zmk72ZNuQwME
CuIYQSXVBSIu/BDK2tfL6r2YjTuwKa8dOjg8hIc5aFw1xNIInF9kK9hlMORf u/Yxyjs7vWjd
HizqwNqjoQcFwHKXeR4CwDt6QCmu073ZA7KAgdX9bBCW3Lq1nZH61PvD0QtZ ahla/6bgV2k2
VAYvurhAhQZW6wQqAAwdEMzM382BF8lRSRKJ6OAUUT/wogt528rLxsFYvC/7 eF97ouFkC8q0
4kam3GS2ATuLwTMD1ZhJ1qFfBvZHIo34Ju7m/E78DoDZTJKATDfA7+/ZoHoY dhI/PEbc29K7
yF0QczWUqq68SKsnS3QVpz46VrZh3TVvef1hoZXQVoldVYihYm1hvLT9i52o DqmCvQnN5kZK
3M4ZTXLN9JDyYTtyt+PD538Q7WvulBeMf3mdhMtYtbBNpV9nxXvGwktA9sko oVg9KFiuwchh
NsH2wu/uSDc1bTRxrVV9CYJtgb2bdsXGbgPd0ynQnF5AgrcVh6TpC++6H8Ib KRermGncrbBa
2CbYG8dPqLjF4HvklFCcfShYrcbhhNcd39sWVT5YYXjqq81y/nyHRe/iWIlY fGiD0VlLA650
t0Jak8O1bcVx0Sd/ejbvmHxi4Oaxppcb+qsMLgJvAN6EBxarYB2TpbfRzw6V 3IeHdK3Vi+g/
EQ3SjKqO0fI4XB6r+GLlJg9u2wA+E6W30c8Ol7PcNEK5N/OWDfLLD7A9nB5+ zQO2H/Po54df
IbtPgt+4ysYrf4B9oexg3FbTgO6ZLFCWvND4vWpDBEs/jVxfjFaTg82wP8IO 5rUtquvCLbJs
vqCtWdGzBa8OiFbONXcmYLYaoP2h7hByK11AdU0WaEtabGi9asOidaOFX7MY rauD6dLRtEIR
XHaB7epL1CXT1RDNV3Q+EK9/+5KwlQxX4sPp0te5kL0WBLgPd15moTBPYEgv YPw8S9hXwNGE
YB9OlyvLCmLCl4Hv64y0JhPryOesJQ9kLB3OrJX5iwhOl7Dv3z4WRYYWB19k aaEw32ZKL2Ho
fQyYgaXDdyg85OmEnOhXFiNgHZ2JooTEXZE9qBh4luInLWhCGLDlwfTpjLzI XosNYAfDrzNQ
mGewJBewvDxIWFcq11QxYKWH06Y6ZweiwE0DtnS3Ql7zw6XrshohXJnusBGK 4YB9OmIkYRRX
K4Duni5QlzT4/L1zw2IV0Zf4RXPkk2YLusD8YRbtVX3mOLrJ4ubqLqB++Q3b PgvOtwkL1zOs
UH06XvsoP4rgoDqnC1Qlxzo4XrehlNymM/H22/nUG0DfTme66y7U+QUzrKvt Dn6O5qnOm6r5
pQU/hVfblHa/hYG+RWzrErFPYtKRsyrQPbJKKFZglCxXZeQwm7JntvkSSlr4 cdku4WpRxk55
V+nut9HRhFoe4D3SSh9HKFk7K9Lu/l8vqYYoRVuql4Stvau+IIpWvA98kofR yhZ8Bv4yqNQY
gPiTi8Ws428cOUG8dH6LCawOuSUPo5Qs+A360uvuGAtbRNuDWjXrqq+56fXM klEKOULFcgCI
dee8tLgwwBttiL5Cx51qVjM8oKxV1gB8Jgr0JXsyMlawoZRc2WtHUzqJXPdZ xoZ7/h7fZ6zF
kuqfJBvR8oN579BDqUgtkwaiym0DtmCu+jmRl6m79V3hVr7tnu9TL+HktKDF X1TkU3jj6W19
sx37Qd+giLBfLwB2OqnEgnjoD8OwGdOqF+P/+fj8fl9P84NASv1TdnJPp/X7 gdoST+qHBB+k
0iueV+LEuR1Ly2/qZIk4LBfHGJQlkPzDSQ4C8vnGx6YEB8heN52YxD/uJAtz ddlbI6bRYcZJ
5EdD/BlbSnlcLmgjfixngeaCZTTQtdqcwIYp8UfzaJITYQytRuzSU3O6E+0a vgN6R5R0IN2q
vTZVptNG42BddjYUfgC27h7Jv74aGh1s4qbwPW/z4HUnXKytE5kep+SA3vYu V9rPSDWWlSKU
zaqkfP7oa4ens03ZZpcLm3Hqb8aTHLPkkNNiiQxTpDQFp+D4gYKKwQrSnOSm lIkaamh1ySwi
tRe3Mf6/t/AOQc60Ky6JBwYzljEJRZ8NqfuVDXrD+xIN7dEgzymM5XHxTAm6 7hxRApSxoshB
Fc03n5Roy4ud7mfI1Cv1nFlOJECw3/E7urQtAxjW0AJ2Az1f7qnxWaxVRkLM UwgGwgqkmVz5
efYIuSnNgA0AscaVfk2IBcCK3Cm9tZgOskzAgV2+jU+mIvPhr5gWnsj2dGHX LMepFKELFR+9
q6AZT/I+CJvVeOay6e/5luBdfG46xuHIj0y6vDMiJDTBdpbXp/ljAo7lKlJN vY1p19Fbz1Hg
DuVLZ2cYkezztJ9wP4+2ViKzagtelG6DRKFeePSv3Xczg2paQ6XYhOrArD1A wQRGq0yptcdH
Zol/cT9ZHOz0EXw6Q+hrAtqO0XW+VjvOJQV7TUSBtibk31gLni0nOOemYUsF TFN9j6h5k7qf
h5K0gTMv3Ti8O7W9TnNIZh+eJZ3m4N7djRdddiomMXOBDVyEykPM2JrIcaFz +33s4aFn+UMy
skEzLX+Iira10xDx3JAYKZDnQXKOMDaotgHWTXJ/DvEnjPq1puJKxxCzqDqe Epb0xQcWE19Y
yiqtUAXS7lbmBsg6AvfQ5YJ9kVkXUZ3irtDa2JdR7YHq9XDcRPzHzq9h8tnl VFngT6om+7u3
Zq2C0ybSDkiqSbWnLpfs3FLgC/aDjkUNOYiBEeZnDAS9D3VT6gmgwDiPojAK HhZk6KJ/XbZq
DThp2jOBDZbVp9/hqVt/Y/WKHAMaQIFEhCxntkqqBxSBnvC51XHCCCmxdDOq 9L5KLKEkyjfx
16p7XaCk4D4zJMhWOnUsxUCDQYFeMGchphZpXw4Xrnskr+TgYlUR5K9wenyB Codiu9rBuKaE
E/kTGpU9cwGyC3xSqb2QU/pQnKVoGSKHFUYMPxLb0NUru58SqrAKdHgGF/6n 5A87HPaFBHAy
S6jxrzaBnC6x12LEF5RR8Yp+SEv/5s8o+p239AbhDboQRla+JVRa6+hOhE2u /Pl4bDHs3O+N
x8rbYP3opc7oB6x2oRNvHRTvffnOoMUH14cqnSHfYsESOFHKQHH4YYyboocE fatoy0pQELWA
WEc5fwfuchnnpBY6zRRQ/l5W96nDWk932ZS/3W55VVI9C8TkOpwbyI6Kfo04 JUlMcu3uhEwF
KUTdNmU6dWTS/ho7BGaB8DMhdHoKdCcrVRrRjv9BtJlHIkF4QH/aqD6En59f uSW+7NM8n7+J
rHLU8eDD+esrckRb11u7Sy76JeQxV6aBEjlvGQ6fuPngv/lVUJ7jHdSTEy20 VpNMd804dN+s
ui2uT+0JyhzFjVgYfnkO2D+RmXJBGRZNh8B5gEDsARWEmUoI3san0y1OMeVJ yEk3EsYFeOyW
UrO5b/cN0CNKYAx2FNVRJlESzQPAPECwlX5LG/yr0nvibkpnx/F7AAsLMJwY Zfa96m3KIARp
D315UK0VHSPHiqo8gB9tf8EywKD0PaCiTD+DhtRy3zpRlPWHxB1XpQsSbVPK LwtChHii1J+d
z+xZxgZY2x8ldjinNMXoxVYW8y+4gCUzNP5QwMQ4V/Fz4lAP/oUvkcrLZymd uzCNqTDYJyid
fH83n76pgyAh240y5t1UrpwzMQen68F5CW/JB1Ir/SlJj2WHGnqfyQR2d7UN AzJIjlbM59W5
8Npx+SaKTlr+XxAXU6A12yInEh7Y7d6y+wqFdFaPaFHwXpuJiNtMuHK4wzxp I6XZYyoSbESC
TmkpyOh7Uk7wTDcoZRGJE2ZKIJvMW9xEXxojD2zJl/AVH/rjtGKIi13G8hZ3 QUtpzvf6LCWx
MlBbanPmTYBYrzr4Gqhw2Z66HYnF8CjE+7oYB0dGa403DgLLs7CdzuHWkCdK 5ZmexnwYGC9v
J9rZqRboCOBOKV4p94QCU/3EoR555rK0XF41hjxcxdLg2we0MfejY6Rhjz7W qc1XCoVk93Lh
JQt0fXyMfCcp6Xn/afzV8p34cyht2fakuA+LaWMvo1vdtugeGqTWuYN24fN/ geNILvIufOuD
/xSgBnRNZlWzs9P1zjk+HLvjBfv6ayfP8czIbx0F0tCN1RoD+vGteqOcvjgx kfJH19mxG1T6
SlG0LU9nZDnFwSnQdA/T0IMyxeBrqDCBix9pd0DXgdBbONMl8BpiF3jdbV3A WjNaO0lz8Hdm
vDM4w/jB9t4nHcX7MlfvM1ZdgR1j5X6r/ZYeEbpbg/x5zcCehaHYBaQOcsUI pDlrbU6Wtm3D
itVe7h4IqqQtB4P5zB4wzU9ZEwWbG+eFAphzLPQwO7cvO7zKaBc059YihFpc wpid7eZjzPkN
RsYObscfYvO0lxnDsQ3PwfHbjYl8KQefLVZ9rFDkAp++gUWEEyu3tqPPBa3Y s14NaciKPZm+
loBoungNeBhYw69byq9tbq1X9Ws7G5KXcqqvfU1NsS/iSoc8LfyPT6l3ie2s R0VufIBooDWN
MKMLO+QI3FkPraZAgy8Xu8bTz1FcQx+HmLYLfLjsz3+9szQmEo4bNHR0Uhcn bhufY86cc2V0
UT8kjIT3pD5YxBqWdvg9mqTwHNLAHrJ8dudct4tHuumxTuUOvtFBapbA/WE4 zUzr3tHYi2SO
Bc3w9zzU573TGOEmBvXaQ2D1GgvmDMRPC6J1XXNTKN738RsPdIEevZivfR9m ZOehaO3PIXUF
MmJLYdjCZjOSl+aKPB/9mMW4cWxDnBsc/gYaLwrYWod6X64AzChB1Hprc784 ga2XVBbjBtZ0
hIdOE8AyDYRcbLRbcEroyhgG8/PeELDcu/BHHPi4DCYXLwZOnP2TcHUuSfko bSOoEe/1wFEV
YrZf7HHrtYz6q00aP3k5U71bZpXiHf1qsa5kxkNm27+urGfAuyYmL3JnJWDq sNez3Pzf3mzk
BWVoh1YNgVNOaSfVMT5oYVWKjoZRZkWoFVW8tnRppn3PWLseVwDJjZuNGnn9 r+voTJAkcLZN
Esxw9x2a15i8cIAIO66BvzBZzO7DWpDnzSvCdRyeFs+EJAD4BBvCSj94YBzH 3HyRVoXQH1js
h8VxTjZYXEvzc2/IzzdPmpUMGj5BvjiSqNeZWPca4C89Vq38sD9kNu6IO3/Q LcTG8VnNDOun
5M1Rf6d8ZqNHP2qUs2rSQqS1pvQ1+CylbBC1nyIYbzVskBJT0B+rLsHPjOvo DM6S7ScmmdE0
eQh2LiAtF5g1Q/2Q5BfpesiJEkr2dpFzMVxFw1HeDwR2moGxsB//716IdFK8 yppnVvP8kdEZ
/CRb3mma0BJdVdLoSCWYHOvxE+diA8rDIxNTB59TfCinsodfjPCjbfT1w4Yx g301dUAEuzfU
q2HfvgsiOFTXHtSsla0/uJYRUGCIiq3FntArONt/YD5/veQyqq9UPAvjBKIq kezoqz3zuRX6
0+0dsHNsIIROJHYtcBBYyPmN5BsBNU/w6j/47ECGwJ2gpePsqkoiJZXI3snK YKjy2nSDCzwF
Nd7TXaBE8joU6Nv9QwtIHRK9DHAvYn0iy9k9HDw/duJWpBKhBLuSt5XcEDjh UG2krKp8tq1J
zkXHBsxUXBBu584PmYJw4j5Wrhr3m3c8hLPkmPF5ojMUeuwR0f5mkSZJMTkL mRybnSGwvBZ2
1FmNVGqBgUVqPf3IB9MY3AW3+ngJ0yi2IQPLEouzUHqT6ZzLtryCAP/r2Xgv DY1xUZf3mCzA
mNwjRijD3uCY/xuOzXBG+W1Z89cfs4Ezw9Z/+2OU9LMBWirC+P/o3yAMAHLF eyrdF4pbbaOT
ZaXho2yhqPVLPZbPjJFLyMtyrZAzhQnRg/avMqpCiiWeW5qeFA79GvgtBsri m/EwvJ56B9Zh
z5RJOn5vby0mSOthsA9qU0+lEcckTW45ri8hnIIpHzW+VQhkRktsMiWqn9+Y n9jovmBsLPCO
IfobtZTgrSo6+n0QuYSYZPb3PBAPSmz8NMqiPK+jyb4QzMbrAWFucCeJmnwX MIf1GI3nOQvQ
G7QDCrOWkfN9Tv4KrvBWru2ZVBWcWRmqcslN7qksoo/ot7Zhl2ONKkhNKJH4 sdUwYOfv/tJf
APYJtMnvG/wnFbeKhV5joRPfN/KuQ7f9UiGXuJbxHVEkfxyvwd0INNYqxqt+ Fpkr6tapKu/A
7XEPrZ7+TXg0RNOBQ1fOGZzTEhMl5kGDiC8MQ6Rdyxy5Q6Y0DckrOlYqCCYc WTn5KTySPh2S
BtIV2r7N4PqrGAwGxE9qKQDXKaacKaf2/epy8HAHkb+z+v+hgqfYYwxAEHPa jbI0Ksz7Pd1t
GlYXtwDs+vaKZTi/r2C89C+kmwL993++5OiUTWeU/1m0G9qyc7I0ESBLgLWn 8UsV2v8ZOsCN
8lxeC0yl6SzQ+r34/m6GPrAlbWPwDBAutcNVqKDdWkvmhJAsAxQvQ1lg/Pu1 JfslUYoYoc8a
CUJvbWbWXdeLMyX44aoNVgWbMaeIZxiKUyCmBR6mEEJidAFCbhKHxhSPyuTV ZYPWFr15iled
q9GHeayvIyZGLL3Q5Gkj/OCFGQ/gLF5LulYbmbItVkx9sl6qZyiQjQHC/Er5 Ip92z7llsxXN
40orKpvKZmpqmdpD6OgcSg4VRPsDb5QTfzFlaWzD5D66ECyLknVyl7SpIUOK ljhBVfjk/Lu2
ChR/qYHdqIl/J5qz+N4+LYN0DbTFDk359szsfTubp+Cb3B6cuLHc1UiF4Qbq cWcph27FZtSu
79QM1GcBPcTIKk2Y7NLIpyZa+BNO5+tG/W6ardG61CXmD5uQ70+PMe7dMB85 MqVBfAqPNoxn
VuzgyaP8KyTx0mVc3c2rdjUE3leM2aK2wAz7kqKFk9YGa+mJaTkDhFT0uGZ4 ptIBKd9PoWSY
3ltDhH/lY/xfjp0P82bSEpYl2oaRFoWwpvIrpt1fjaBgPXqAkBgJ1lwQu4NV SG0fFfVSlY1H
H5e/kLH4zRqGwsa1UVLUi4zEXUcq4F0hoVEnBgiFRtKY8ejPiiXuWi8pNvRz DQoRpXR6iEfL
4OxGjsvjPWupC7VPwzJHr3EEjRn/5YnbOWmeRA4wI6N/8TCpf8/18jF/5rqV uNpKfoU3Q21s
wR8zNC6amgmbsVXkWOH6UbjfR2pkHkx2+DfeQJP2c/L0Pub1Ntbt0cVUAcYQ ytKPPMXmZ7kf
olzZis12Mwu3p2fwLKM+g2yidStTMXS9Y16kNk01YaThq3nuBQYaXJVaw71R oCCtnk2WKjZQ
mzeIUB49fdjhSGEQ6Z5fKUbeP1f9MdHEdk7Uo4wwHWwJ1w//cgKQIINO0WhC Dn8KexuXiq7Q
XkoyWhilvFZp6AIkhVHc0iUZsp/V6QfPQ3OBlj2sXBqnfhxEgzFFJRFf9YLP bf0OlVyY/PQZ
+i8DTu6Gt8oe3UEVbicw0qoM8lHRcfQ8CmS9Bps42yFNdxuyo387TnphkA53 hdQI33fpODaG
F6GqbtLQ+ZSrMUh/xr5amW9iXVnK3+9hcpAw6SXZlRRTYLeexAaz/K6385Yn JlOcB3JtGNkG
hUWMkSLAOs8OQ1TR4bw+k4V1cnKGlaSLfNhHD1VaJdheLK2dS6qJ+4Fmmale xAKp5gvi+cC5
31xXdGkysN94oXqBb8QjbiboAEh8l+J5ERoMeURSRUf5p1dHxoRDEor0H+yf Tx0Jjcf6wqa7
/jbcZ7pOnDIKY8QSCqS3PVZOR4agFRfErbtcKgo/5PpmSoVRJyEc0trYG+5u 18pGD2xt+7Q0
hCgD97MeLL9ZFAJbZ4EHhzoK4SnMhRrWESvKRqaWUTAAarGpcLEbjiafN0+p YgxfZhA3OwjV
I0N2ws3z/LOUG6MTTrYyKj5/2nnsLOW9EqJm/wqQ2eKsNk+l6f/PzTsWDNb4 alDPXctSARP+
WXAPjd/+TZG468GXhTNB+vUN3ENPlZbEeqOnjhY4LRaBHYiDDerZkSGQwHjV N1CxeAnAvPVX
pzz8+A7vCHXFI9KCp5KXgb5fCM/M9Lpo0snbiAgYPi2Kf9F4FnwYMfQ3iNst z9/O141TP5sR
P4lkBQStSkfl+sdXGggZRL8cWnE8d4EuG55acGuanrLeluAVS3KW7/f4YKIi TdPpyTsxjSYk
i5mAxul7H1wdNY0XWjN/ZeIA5QN92GkgwSc1lhswPD0qZCN0V1qPvs8R0fcb sBd/c7JYPREw
+a0s2i7O3sFN3zC25xF1tKk4A/NTyxMbU4a1d+RBquVFmKQqXMDRW7bcaI1h PW6XZWJczz5t
IU8Qi/Es5BBt7w2chATJds0NKSxx5anCRVmYHuLxw5k1nDEcnUN/7kx/0k2B PSuRhyh7Jslg
h98DIXrIOkeQXDpxxdYI1AvxWEQ5ftT7sRyDEQZIUZrUFxnJcEwkufUUXrjt o9XV7n1hiERY
qmjc+k0CGAXBW0RM2GaK8/ZscYPixQ46dTZe9jWmhai/sR1qwJokTGNMscWy HM5znjKv1GiK
OyEDxpn8YMM2VDEyID3XKYuWnAArg5aYGWoilIX/JOPpyUkmTEqpTha0SCPN pB/BuTlvSMd0
CHzW5uUlOge3rqJev5QbPxOVBvVzbVASDjCUEWgYkHQsemgdi1X0StsWETBy m4F0QGdSlmOn
JAQrqksiv5zhTw8Ux7oeD8aMFZbCqYEMiubdrc0G9A1xElzFKL8d4MZQWp0j A/kcINC/bdJ/
rR34zqLz897ksNOprU7QwrXuJ25Kyx2Ec0I3U870x7mG84Xj3smcBjH3KxuU MrRlb/eFA975
w0CCq9DU9QdueWOBpfOAx5Io7nHGC5Q0HupsqfS5i2Whjpb/ovcc4GdfOxL6 xFDfLDk6tnUR
e3gmaIAqWp9o7v8mHzJs5EzWLemI+C8KPMs8oo20jnLHx5kdGGu7Uu6MmE07 31qnVsnKP+hZ
mZjALrTcB0YV40Kz4zvqxtP0fNV7VmrGR2MD9tZZ8gSDU1nR8yhjy6aRtM52 w0s/8VTRWEUG
05HU4C5ErPUmWepzL63N6VfzfoC3k/UqNumtePvMtxo7MEQtaAzZLbP/bGag lCVHGILIb+yC
TLWBUdCefvlE2RToJyxrGtwGa+O0XaWPsfrMh7FHL87RLR7IFs7Z1PhD2+Fr TyYXEM9Lckyx
Ozn5XjAjvWiSGVAglCRlB6zmPzPxL1qunj4ICA6J8C8MwVuDg8iHWYmJaWDa cm4CnHNXuHkd
yV7oGrO6jW514/f17h+B+G3ZiHd22xlpC3RNfLhj9tEyT9Tt2ahcZsOUK4iU mHcbsOt2nP1e
sSqygPNiNtkZ4IEvuvFlKGujlIiwl68IhvWdipAPDZWnF9NKfjSGBbEb9Db0 AH1wRWjcUhkL
2Z5lFyRrIJEdlCl0AVOuieOjz3xybFTO5aEEscNrTBkO8PpdmqtoDNq/g3Bc g5sNTOyN8zI+
aOZ5lULxjbx9pB+3NCw6kY7fD3N/KPzRi2Qh1VeMwUTTMjdfGx+gcslAnsnU pmUVfxm0WB2a
DbkBzPi+fIdrbcqweexMAiUR4W9wgNLnf0TxoU1h60PJaij2Rauz1mSX4g6g kRWZxXaoqDUO
JR78U97Ul/DA71dJLhPt/d89+xRkK3aRA1bhPh/rEPH1awwIalZSwVBvkUIr datl8bAU/+a0
RoiV2VZJzkOQW3gSfQjL0RvCNivseujNcIsvJ+KEhTF9oYY7dYY5jhEL7qrb g43UWSlyPp1S
tSl1C4I2oayfWNYQo5YC6e7cOr1BAsIT9cFm5OvMWRR7HJVjx3OGtH2nBO8k dHb+Ejl/jDUz
55YFwBVXJ59iaY0MbDFT2SSotIyUhmSL8jbc2LjAtucTSVM56Pp3QIykGAYg IGeyy6dABVV2
9eKTACW3nG7FQST8yjIIrNamoydD0pkxHjcgS2FZueJT/c9QkQQzovFcS4GV pEHAUdGfHvz2
Ag6o5EY93kTiGWWchgygKo7QpqNWMSSwLZvE6/K0Tjbdfdlq8g/+iV93FRtE DWSg+eICfTyy
tWne4u90eJFg/1lAq2S5tY9lh+qt4stqh2cRUuntSEfQdagjkf/6z64Rby9c Y2WjwdRPkt4f
JOHAM6UFcv02tWx5izvjS3+tBummfH7cqIqbopKVBWuZx1dOy/ln92OtqMlA yxcbelv5216N
eteckmeG7iGaWc3RPmuuBjEEcdgWwRyWpONRgUM5QmnxPd0w0aDwcf0K4Yro HLOevfTZKlQZ
9Sx2UFzvzf+y0p9jUPqx+jX3wR7gTj14REkLe8ZIrK6wfiaB6Jo3cn4716Xe zU2mqlO78yvx
jRyU+eOv0hJVaK0vaMNxqFrMYYOGq2vdqNkmHzzcRZZlZHXukunMfhPlBsMg 3a0aj6RhZdlV
yM2MTv3xDfQA/d3qAxGyuhj5a922oUCqKSl7C2h1h4rlbrFjwh736AsadFRy PsymPkih3OOP
4dcDeTJOEtsXjBJas6B5TmATNOT2SzXzhnbV8QLrHbhpY/C8Qbe7/y0zkKfP pyIS/1W0YdlP
M/0s3a6078kKFW08ISBSwzyN4a4P4H0hOtBQAMGkwsAoIMjCjj9htT+e+sN0 x32Eykd14+4b
9Q6HooBDrycq+YV+eOceN2LdLMXsXUO8/9+yW8589hY3162NHKUDPGy9tIrr kIMwpWJLFWk1
pC5v1y6tWasshSt6EewkTa8nTRa4lp063kyIztVuUFHWLyzBAM7xxW8pVV3U yxCXPovyG9Dv
GfPxtsHlMsEjjTnfsyl4Hl6t12XpR3A952TIyhGhc3ED3k0E0Agftp1/NVsT mr7tdX0OMTxx
FoCJrWk8hq0rKqYcTjXzPWsq7TmSWDUkLDy6LX82csIDY0QWTcCZTDnMO93Z fSwrbSevGp8u
PZH9BBp3zghrulSmylcsNwq9CYKZXEyAdFx+j69EF8uVnv9eDSMETDiNQ7fP 2upQO9axrHYt
6T1eiX53l7vAQ/y5+PWpqlWP3tsaorFLjrvF+NL5NToLUoxyVaXuoqsN5eOX 5CrvyQ9XpJdm
kxSYuk6/LxFrbnxkzz+lQNXgNwZvR7vtxklzKaWEtWgD7Q5Gq8prCesTEXlE tdnP2Qf5jBQl
xGeJo36w9PkURC+5MNXn+sjAxfgmTRk8t4xAju6kKaMPqPySDtNnhEuV8DZ7 bFJ0r9MUOm0d
mtiG6V0jyVQj43entV9iRRzTE2SYnNFbKU3I+HT9aQ0QUsesFdhyu9HrRTiO lOauA7WUD/CQ
VRfJk1TifEBRsCDoM8smeqOebZ90vaEqggHxqkje6YdyfnVO9kOHLuvXLI92 qYt1jX2mBvDH
ME0xNhoN1V6FQxtTteS5p7MKeNEbRQQfsOpgXVYlL89h5GC/YWzy8+gtPuTg 2i+D4tr6lrZe
5L1DfC9FRMqLfOV1b47/Xp5/WwLTz2yfgPen9B3hI//qfPOADTI+wHQkfte+ aNIif+2Bn3Aq
8OfwPBwFAFbEs/ttGS2ktLhexMx1UsG61Rl2R7E4Jyyg+zkhEKfIPdQHlUU6 icM+0g6Wizbi
Dx9948UrC1UCf+5JpTdIXlPrQl8m+yeALxmyQwCdKohJFfNJI6EWsGbrw/s2 7YXklKu5MwzK
x3cEUZJ57y7U4/N8SEcj8h2w5vAY6GDZq+A91iU/f7eD41ZQElNnRYycY/cH uF24rILEiqZg
roG5mhPRLM+N8rNMKykg1ppTh26BTh8UrxrRfrkjlOHfcPAnEqWhtF6VomYK mHMvGy9wXlC9
2Brk9jOw1yyvguVTGBC56dXcowLPbYMp7tsvEyTSIvWG2yxmm+rQDQp4yl0j uQbmDSXNwETN
HfokRAmqhcf8IJTFryY7X05R3Phq7q3CPW0a2XNYNhMVUUZn9bz/LMnUjhr2 R/0tZatUa4wL
Rcyftj4nYL7+LaqrmlHiRNj8VI/RLUE+kihQp7J+jLkRly3b/8vGgdP6gh9n Eb3fouCVbCTj
0vFjhFzwDZgNcZ+AyZvpWlOxDsfrocf562RFQ1ASADKegFTRt/bFubpG1ai7 CQtCfLUZVcTK
koTfRxvrKF4MNFL9wl+bZFGgdnk4Jj009fe/VWuKH21PzvG5w1Dof6XNEdVg 52xUQ6iWaPf8
LYllet69nZQpavTx0KSyIRBS6uLyiM0Py/5oHUXLc8G6IUVub7x5FnjJ9Ido 3rcGmnS2Al7+
VahvtzZUnSZAC8G94feiNvQK3YHBKbLMI9B+ofhVw2fZf2j+aHAOTr4nrZnW wROfxOJbYlKr
B/KDoIn3YIg6Xz/lXUFdnDokTlfRUJnfvFrzZBQIwj+mPv4gS6cTxzemFG+Q uNZI9dToGlsB
OdZnf59o2Hs1wJCoFikcyTXxEvXTzQspwdAIRKK1QC9qkpACRyv4eHVQUNAl A5vU0YFZVn5V
ouP1rwL0H1TUnWgNedqJ+59hluvS0NHbO0Zy7ZtyEl+2ybzsCeZuuu4UO63F GDGpOozjO1nL
ZDBA16aNgkdI+odIYq1v/l2G233nic5Cg+Vn6Gg2r3kG6t/Oo7T/P6+KzrH/ JJ9B4qN7L5Jz
xHzrqeGjU1i/5LosLmZ25f3iL+igZFTiJJgjd+T+rRm16i9Mx9BK6958yTog Q7upBs6fhrGs
9d1jTaPIsJEi5CwKAkJQhLS7u1Q6ppOUgyGInzLKSXDKfd1A7UPsrfw7IT8S 9g/tV93zesue
9W5en9b5D3INV0pXIp1DeH+hmaZy2Nqls9lBWl0tkMnZdiHbIvtyLPDzFRID axV5b3m1JULH
HY02Rp1KE9AgC0rbsS2X/E8M/pHXNh3bQYIL1oGboJ5oj1vm7gM7WrlkiajF +2hchR7/LuOL
PSJESHIqrhzyfsgPjoQVt/NstOilicPF4OpdZYxotfFZprJumUlXzVDV/uWe UfMtjC4Gl3A5
av56CmJQG49HiIBJPjwfgG7o3ybN0ApnCS/J0kTJdFb8zZtjVER7MjhFCQUW /HiCN+rriFhr
OzIKl4w9DL4dweMlZZrLepO0yyNfOEfqfNOy7EntUqBcU4D9YZ6o51cujdPv RfUYZY79adf9
syeWS16gKdC/3R7XtqA0wGgdY/7jVPQf57/skOEQ9df8oeG8bHBpkAnPWLt9 a7PjM8fDruRp
d3Rm3QdA2S03OcdAKrVCQ3gh3UCKECQPQuUMCWvh4NOQGz6KPdoDd+Q5xeUT Ml9JAdxH/+Wj
sUS/0l6WCrY7n41Y/qb/qyBmknW6+7iV7CwVDStygsLX7+T+OoPUZyL8W+VS sMBMJg5gEDr+
FL5IbBF0wnnbMEZA4Z+nqWFKHxs6lGhAFIUWDGz8da6L1+LWm3RDLR/popAu 4CaGgXmEfA54
CQ/Z2U9LarnB5E/E5M508v/z9h6XktGAl9sc2jVPmkO4j4b96Sjij3rkstnD 8RpuICRMbqtO
dqoI8oBGd1WkeL2TUMlg4Sj54s3nYru16wRlPYwBWBHP8fE5TWbwMU2PUR4J mHKyzm+lwHhJ
4wrTtzMNFq3uTMB7ZJ8J+k8yEpznITtgnPQXsl+/AJtAivbA9wjfYIioFDFl ipb5zs22udqH
6McAzoF+YDenZ6W7eBP0UqSa6oTv/TCIpwYcqgNCd80iumfY3oO+ZhJqRYbo bIroinku+wvx
464vt1CRC3BIiDC8Kb76obk03GwdrpkyaZArg9k/nDOnFYWJuw0km1lTrXCc Nx9MD2bTZtlh
HAp365bwsNNeLnKjVSp9RewziFC/+cAG/37wdU31UyjCPj09mf8mQjUjV1C0 5VxsFLL5KW5g
i1QpnG9UqJJZcuFlgSwFEudeKmPO8++LflLMAHqmxwsHFeQcLxba0h41Uaem B8xkSRrG8SFg
NQyAXxAk4rZwXKv/Q5lyyBJUY2z5VEje3SbQiAdpgCqSt/ZH8GLZtxTaSU3r hZyd/aHqeUcU
UhIjHMTfq7XUBaKcnmlYJOs4zLECkVoWCu3KKFxVP4oBRR7wkWW8/IMY+vYN BrbmtenJ32Ej
eryTLZebuoz6D7m9PS1L08IMCMnGKFoAuOBJNIZVNbKUe7UKtH+zZnP2QjV1 Qah1PSLa0EeE
sjwf3r0OamOZtqYuTEenwqeSLwWvsfJdGMedRz25gv//v0PV5WQ3rAI1+Sn9 MqLm96nFdFdA
UpnQN/E9i+A4TIAZf5lXOqY8cuDpwL3D8vPWy28lnf0ASlbSpCJJRtR0SXac 4lsUPz6TdJbE
k0ibKK4iF8pRpG4PJvr+LSrpGbp45voiQYqvFepZNobgVUp2FQcsszTz06Mk c+9PrSfOJco+
vkPSuhpVKA8hFUmfbJsNLb3wVMU2W8JNd8qIxXApswEJ+gvjcyMb2OmHY1Em WYFKP6xB0Ovq
cgadHeipPAH5F3tqbd3xgqsamsxQZBg9a/m6Ysl3vZsOqd6wgwNAlbjtoqOS slusaFMRkat+
uPZhjNGzSHxI0BP0eBV0MncRXHu6U/GsgX/xuGsaEmtn+eWYm87FAZj4lUJ6 wI6/FhV41IWX
QwHW2XwNhWHL/9Ak2jscLb6pggT/5hzaji31iq6xbYvf5pFyFfl+rOC34Xkk JtAEdJJsS72t
dPMF8gC0uv+DXpS00XIcBqxNtd1nhQktZ1G3GIVu+VAuYevZxdDSXWeIZEeD 1rRwsZhLynkd
0Y7wWExkDM6o0mhorBMIWFspxkILL41PQRWzAPmLCaAbIxfWya1DYQ5ixNlI JGrVy8octc2u
57kbErFXAggDqH5REHqusqJGmUyp2BK7w7qTgTXYsrNgTT6lOA6n/v6/3EBP W9aUC9si3LAV
z+FIc/jKeWF0+5QNif0bYHNqbDyoivACaNQ3Ljs/iXSyPnGnLSsz+NYrZp0p yKJxQGFKzmId
QzBa1Xiy6xPOxudnVauPy23Q1MhXbnA+1v4mJborrwZlJtyWOasbiJ6Jv56H yA/ZLsgWWfoq
qi1W1/D
Re: Cannot perform execution time analysis for profiling OC4J [message #140689 is a reply to message #140597] Mon, 23 February 2009 20:16 Go to previous messageGo to next message
Any update? Thanks!
Re: Cannot perform execution time analysis for profiling OC4J [message #140720 is a reply to message #140689] Tue, 24 February 2009 02:19 Go to previous messageGo to next message
Matthew wrote:
> Any update? Thanks!
Can you try to exclude all classes from the com.evermind.server.ejb
package and try again?
To exclude classes from profiling, you need to define a filter file and
specify this file in the Java launcher command line. See
http://help.eclipse.org/help33/topic/org.eclipse.tptp.platfo rm.doc.user/tasks/teprofsa.htm
for more information.
If this does not work, try this:
1. Launch OC4J in "controlled" mode
(-agentlib:JPIBootLoader=JPIAgent:server=controlled;CGProf.. .)
2. Attach from the workbench. Before you attach, define a filter that
INCLUDEs all your application classes and EXCLUDEs everything else.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
Re: Cannot perform execution time analysis for profiling OC4J [message #140814 is a reply to message #140720] Thu, 26 February 2009 22:17 Go to previous messageGo to next message
Hi Asaf,
So the filters.txt is as below?
com.evermind.server.ejb.* * EXCLUDE
I found the page you sent me, the filters option only support in
standalone mode. What about enabled and controlled?
Re: Cannot perform execution time analysis for profiling OC4J [message #141265 is a reply to message #140814] Mon, 16 March 2009 10:55 Go to previous message
Matthew,
Sorry for the late reply...
Yes. Should work.
In enabled and controlled modes, filters are set from the Eclipse GUI.
You need to define an "attach" profiling configuration, go to the
Monitor tab, double-click the Java 5+ collector and set the filter.
HTH,
Asaf
Asaf Yaffe
Previous Topic:AGR: Shortcut-Usage leading to "InvocationTargetException"
Next Topic:Custom Profiler Data Provider
Current Time: Wed Jul 23 15:35:28 EDT 2025
Powered by FUDForum. Page generated in 0.51014 seconds
