Re: [NEWBEE/E4] Hello world - Switch from plugin to feature - No application id has been found. [message #1402098 is a reply to message #1401842] |
Wed, 16 July 2014 10:12  |
I'd suggest you create your own feature and add ALL plugins that are
mentionned in the .product-File into it and launch with that feature.
Tom
On 16.07.14 15:05, Andreas Riedel wrote:
> Hello Forum,
> after 17 years of being C++/Java-Programmer I find it very frustrated to
> start RCP programming.
> Currently it stucks by a very simple thing: I create a stupid simple
> Eclipse 4/Eclipse 4 Application Project with NO sample content. (The
> stupids of the stupids examples).
> After that I start the product and everything is fine.
> Then I tried a stupid thing: switch product from plugin based to feature
> base and nothing will works. java.lang.ClassNotFoundException:
> org.eclipse.core.runtime.adaptor.EclipseStarter
> No help in internet found for this topic, I tried to add
> org.eclipse.e4.rcp and add required (org.eclipse.emf.ecore and
> org.eclipse.emf.common) was added. Start the product again I get a new
> error message: java.lang.RuntimeException: No application id has been
> found.. Set the Product->Overview-General Information->ID='Test', ended
> up in the same error-message. Read a little bit about this, find that
> not adding all required plugins can ended up in this message. But what
> plugins this should be.
> I find it very frustated. I get error messages that didn't help me and
> can't find any base documention or tutorial (yes, if have read all this
> vogella tutorial, but they don't explain the basics). Eclipse itself
> discripts on tons of documention every aspect of SWT and RCP but I can't
> find any answer to my (I think very easy) questions. There are some
> other part:
> - Without the correct dependencies I get none Minimized/Maximizied
> buttons in my parts.
> - Why add the "Eclipse 4 Application Project" with option sample content
> create a project with 3 billion dependencies.
> and so on, and so on, ..........
> TIA
> Andreas
FUDForum. Page generated in 0.03363 seconds
