Home » Eclipse Projects » Eclipse Platform » Clearing the delta
Clearing the delta [message #138029] Tue, 30 September 2003 12:05 Go to next message
Originally posted by: sppatel.us.ibm.com
This is a multipart message in MIME format.
--=_alternative 0058979185256DB1_=
Content-Type: text/plain; charset="US-ASCII"
At any point in time, if a delta in the workspace existed, first how can I
access the current delta, and secondly is there a way to clear the delta?
Content-Type: text/html; charset="US-ASCII"
<br><font size=2 face="sans-serif">At any point in time, if a delta in
the workspace existed, first how can I access the current delta, and secondly
is there a way to clear the delta?</font>
--=_alternative 0058979185256DB1_=--
Re: Clearing the delta [message #139513 is a reply to message #138029] Fri, 03 October 2003 15:47 Go to previous messageGo to next message
Originally posted by: John_Arthorne.oti.com_
Can you expand on what you mean by "clearing the delta". A given delta
instance is only valid for the duration of the resource change
notification or build. After that, it is garbage collected and never
used again.
> I access the current delta, and secondly is there a way to clear the delta?
Re: Clearing the delta [message #140100 is a reply to message #139513] Mon, 06 October 2003 09:04 Go to previous messageGo to next message
--=_alternative 0047DF6F85256DB7_=
To be more clearer, if I have autobuild turned off, and I am working on a
project and hitting save, which builds up a delta. So on the next build,
that delta will be processed. However what if I do not what that delta
processed, I want those changes completley ignored, so I want to clear the
delta that has been built up before the build operation can operate on
them.
I hope thats a little clearer.
Thanks!
<br><font size=2 face="sans-serif">Hi,</font>
<br>
<br><font size=2 face="sans-serif">To be more clearer, if I have autobuild
turned off, and I am working on a project and hitting save, which builds
up a delta. &nbsp;So on the next build, that delta will be processed. &nbsp;However
what if I do not what that delta processed, I want those changes completley
ignored, so I want to clear the delta that has been built up before the
build operation can operate on them.</font>
<br>
<br><font size=2 face="sans-serif">I hope thats a little clearer.</font>
<br>
<br><font size=2 face="sans-serif">Thanks!</font>
--=_alternative 0047DF6F85256DB7_=--
Re: Clearing the delta [message #141474 is a reply to message #140100] Wed, 08 October 2003 15:08 Go to previous message
I understand now. No, there is no way to do this.
> a project and hitting save, which builds up a delta. So on the next
> build, that delta will be processed. However what if I do not what that
> delta processed, I want those changes completley ignored, so I want to
> clear the delta that has been built up before the build operation can
> operate on them.
> Thanks!
Previous Topic:Customizing the properties of generated build.xml files.
Next Topic:Load Properties sheet from Tree in MultiPageEditor
Current Time: Fri Sep 12 23:08:28 EDT 2025
Powered by FUDForum. Page generated in 0.04361 seconds
