Cannot perform execution time analysis for profiling OC4J [message #140047] |
Mon, 09 February 2009 02:40  |
I've started Agent controller 4.5 (ACServer.exe) and try to start oc4j
10.1.3.3 with param
-agentlib:JPIBootLoader=JPIAgent:server=enabled;CGProf. It can start
successfully. But when I profile in eclipse, it will stop suddenly with
console message:
[Error: EC JPIAgent received message (FATAL ERROR): Internal error (see
log file
Where is the log file to trace? Thanks.
Re: Cannot perform execution time analysis for profiling OC4J [message #141265 is a reply to message #140814] |
Mon, 16 March 2009 10:55  |
Matthew,
Sorry for the late reply...
> So the filters.txt is as below?
> com.evermind.server.ejb.* * EXCLUDE
Yes. Should work.
> I found the page you sent me, the filters option only support in
> standalone mode. What about enabled and controlled?
In enabled and controlled modes, filters are set from the Eclipse GUI.
You need to define an "attach" profiling configuration, go to the
Monitor tab, double-click the Java 5+ collector and set the filter.
HTH,
Asaf
Asaf Yaffe
Eclipse TPTP Committer, JVMTI Profiler
FUDForum. Page generated in 0.33713 seconds
