Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » EMFStore Conflict Detection
EMFStore Conflict Detection [message #1400766] Mon, 14 July 2014 13:32 Go to next message
When updating and committing in EMFStore, I would like to ensure their
are no duplicates added to a containment list ---- that duplicates (as
defined by an application) are detected as conflicts. Today if two users
add elements to a containment reference with the same application "key",
EMFStore merges them both in to the same list.
Is there any way to customize the conflict detection behavior so that
EMFStore can detect user-defined duplicate model elements in a
containment list?
Scott
Re: EMFStore Conflict Detection [message #1401530 is a reply to message #1400766] Tue, 15 July 2014 15:23 Go to previous messageGo to next message
Hi Scott,
yes there is a way to customize conflict detection and handling.
What you will need to do is to register a custom ReservationSetModifier,
which allows you to make various kind of reservations on features during
an update to indicate which feature will be modified by an operation. If
two or more reservations happen to be on the same feature, a conflict
will be raised. Thus you should be able to encode your requirements to
raise a conflict in case your elements are not unique.
Your reservation set modifier will probably look something like this:
public class MyReservationSetModifier implements ReservationSetModifier {
public ReservationSet addCustomReservation(
AbstractOperation operation,
ReservationSet reservationSet,
ModelElementIdToEObjectMapping mapping) {
if (CompositeOperation.class.isInstance(operation)) {
for (AbstractOperation subOp :
CompositeOperation.class.cast(
operation).getSubOperations()) {
addCustomReservation(subOp, reservationSet, mapping);
return reservationSet;
} else if (CreateDeleteOperation.class.isInstance(operation)) {
CreateDeleteOperation.class.cast(
// TODO: check for desired operation and make custom reservations
Because conflict detection and handling is considered to be internal
API, we don't provide extension points for it, such that you will need
to register your custom reservation set modifier via the internal
ExtensionRegistry:
ExtensionRegistry.INSTANCE.set(
ReservationSetModifier.ID,
new MyReservationSetModifier());
Hope this helps!
Edgar
Am 14.07.2014 19:32, schrieb scott@xxxxxxxx:
> containment list?
> Scott
Edgar Mueller
Get Professional Eclipse Support: http://eclipsesource.com/munich
Re: EMFStore Conflict Detection [message #1401531 is a reply to message #1400766] Tue, 15 July 2014 15:23 Go to previous messageGo to next message
Hi Scott,
ExtensionRegistry:
Hope this helps!
Edgar
> containment list?
> Scott
Edgar Mueller
Re: EMFStore Conflict Detection [message #1401545 is a reply to message #1401530] Tue, 15 July 2014 15:59 Go to previous message
You guys are geniuses. I'll give it a try and let you know how it goes.
Thanks for the quick response.
Scott
On 7/15/2014 3:23 PM, Edgar Mueller wrote:
> Hi Scott,
> @Override
> ExtensionRegistry:
> Hope this helps!
> Cheers,
> Edgar
>> containment list?
>> Thanks,
>> Scott
Previous Topic:[EMFStore]How to create model element ID
Next Topic:[ECP] Multiple views for the same EObject
Current Time: Sun Aug 31 09:56:46 EDT 2025
Powered by FUDForum. Page generated in 0.03335 seconds
