Home » Modeling » TMF (Xtext) » Using Existing Ecore in XText(Using Existing Ecore in XText)
Using Existing Ecore in XText [message #1396493] Tue, 08 July 2014 07:28 Go to next message
Hi All,
I am trying to create the DSL editor.
I have an ecore named coom. Also I have developed graphiti diagram for the same.
Also I have DSL named sysd.
Note : sysd and coom are completely different
Now I want to import coom in my sysd file. So in my sysd.xtext file I added the below line
import "platform:/resource/com.harman.sys.oscar.coom/model/generated/Coom.ecore" as coom
In the workflow i added
registerGenModelFile = "platform:/resource/com.harman.sys.oscar.coom/model/generated/Coom.genmodel"
registerGeneratedEPackage = "com.harman.sys.oscar.coom.CoomPackage"
Then i generated the artifacts with no erros.
When i try to import coom file in sysd. I get xtext validation popup telling
An internal error occurred during: "Xtext validation".
java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri compB.coom
Also i am able to see some errors in the sysd.ecore which is in src-gen sysd.impl folder. I dont understand why 2 sysd.ecore
org.eclipse.emf.common.util.WrappedException: java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri compB.coom
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:212)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.doResolveLazyCrossReference(LazyLinkingResource.java:172)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReference(LazyLinkingResource.java:131)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.resolveLazyCrossReferences(LazyLinkingResource.java:117)
at org.eclipse.xtext.EcoreUtil2.resolveLazyCrossReferences(EcoreUtil2.java:513)
at org.eclipse.xtext.validation.ResourceValidatorImpl.resolveProxies(ResourceValidatorImpl.java:155)
at org.eclipse.xtext.validation.ResourceValidatorImpl.validate(ResourceValidatorImpl.java:68)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:79)
at org.eclipse.xtext.ui.editor.validation.ValidationJob$1.exec(ValidationJob.java:1)
at org.eclipse.xtext.util.concurrent.AbstractReadWriteAcces.readOnly(AbstractReadWriteAcces.java:62)
at org.eclipse.xtext.ui.editor.model.XtextDocument$XtextDocumentLocker.readOnly(XtextDocument.java:246)
at org.eclipse.xtext.ui.editor.model.XtextDocument.readOnly(XtextDocument.java:84)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.createIssues(ValidationJob.java:75)
at org.eclipse.xtext.ui.editor.validation.ValidationJob.run(ValidationJob.java:64)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:53)
Caused by: java.lang.IllegalStateException: No IResourceServiceProvider found in registry for uri compB.coom
at org.eclipse.xtext.scoping.impl.LoadOnDemandResourceDescriptions.getResourceDescription(LoadOnDemandResourceDescriptions.java:70)
at org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.createLazyResourceScope(ImportUriGlobalScopeProvider.java:170)
at org.eclipse.xtext.scoping.impl.ImportUriGlobalScopeProvider.getScope(ImportUriGlobalScopeProvider.java:80)
at org.eclipse.xtext.scoping.impl.AbstractGlobalScopeProvider.getScope(AbstractGlobalScopeProvider.java:48)
at org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider.getGlobalScope(AbstractGlobalScopeDelegatingScopeProvider.java:46)
at org.eclipse.xtext.scoping.impl.AbstractGlobalScopeDelegatingScopeProvider.getGlobalScope(AbstractGlobalScopeDelegatingScopeProvider.java:42)
at org.eclipse.xtext.scoping.impl.SimpleLocalScopeProvider.getScope(SimpleLocalScopeProvider.java:60)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.delegateGetScope(AbstractDeclarativeScopeProvider.java:72)
at org.eclipse.xtext.scoping.impl.AbstractDeclarativeScopeProvider.getScope(AbstractDeclarativeScopeProvider.java:102)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getScope(DefaultLinkingService.java:59)
at org.eclipse.xtext.linking.impl.DefaultLinkingService.getLinkedObjects(DefaultLinkingService.java:118)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:228)
at org.eclipse.xtext.linking.lazy.LazyLinkingResource.getEObject(LazyLinkingResource.java:205)
... 14 more
  • Attachment: Error.bmp
    (Size: 5.93MB, Downloaded 199 times)
Re: Using Existing Ecore in XText [message #1396712 is a reply to message #1396493] Tue, 08 July 2014 13:18 Go to previous messageGo to next message
just to be clear: you want to reference stuff that is contained in a non xtext model from a xtextmodel?
Re: Using Existing Ecore in XText [message #1397057 is a reply to message #1396712] Wed, 09 July 2014 02:19 Go to previous messageGo to next message
It is non Xtext Model.
But i created a new Dsl for it, still having the same issue.
Steps to reproduce
1. Create a DSL1 of your choice
2. Create a DSL2
3. import DSL1 in DSl2.xtext
4. try to reference any class of DSl1 in DSl2
5. Generate the workflow DSL2
6. you can see DSL2.ecore in the src-gen/com...impl
I am using xtext 2.6 and eclipse Juno
let me know, this is the known issue.
What i mean is below tutorial does not work
http://christiandietrich.wordpress.com/2012/08/07/xtext-referencing-elements-of-one-dsl-from-another-dsl/
[Updated on: Wed, 09 July 2014 02:52] by Moderator
Re: Using Existing Ecore in XText [message #1397139 is a reply to message #1397057] Wed, 09 July 2014 04:56 Go to previous messageGo to next message
I Still cannot reproduce that
grammar org.xtext.example.mydsl.MyDslA with org.eclipse.xtext.common.Terminals
generate myDslA "http://www.xtext.org/example/mydsl/MyDslA"
Model:
	elements+=AElement*;
AElement:
	'aelement' name=ID;
grammar org.xtext.example.mydsl.MyDslB with org.eclipse.xtext.common.Terminals
import "http://www.xtext.org/example/mydsl/MyDslA" as a
generate myDslB "http://www.xtext.org/example/mydsl/MyDslB"
Model:
	elements+=BElement*;
BElement:
	'belement' name=ID 'to' a=[a::AElement];
module org.xtext.example.mydsl.GenerateMyDslB
import org.eclipse.emf.mwe.utils.*
import org.eclipse.xtext.generator.*
import org.eclipse.xtext.ui.generator.*
var grammarURI = "classpath:/org/xtext/example/mydsl/MyDslB.xtext"
var fileExtensions = "mydslb"
var projectName = "org.xtext.example.mydslb"
var runtimeProject = "../${projectName}"
var generateXtendStub = true
var encoding = "UTF-8"
Workflow {
    bean = StandaloneSetup {
    	scanClassPath = true
    	platformUri = "${runtimeProject}/.."
    	// The following two lines can be removed, if Xbase is not used.
    	registerGeneratedEPackage = "org.xtext.example.mydsl.myDslA.MyDslAPackage"
    	registerGenModelFile = "platform:/resource/org.xtext.example.mydsla/model/generated/MyDslA.genmodel"
Re: Using Existing Ecore in XText [message #1400577 is a reply to message #1397139] Mon, 14 July 2014 08:10 Go to previous messageGo to next message
Hi Christian,
The example which you have mentioned works fine. but the issue is if the Grammer in DSl2 increases, it simply complains. I guess the problem is with generator.
please refer the example which i have ....
https://www.dropbox.com/s/bb5s58t5cummu05/WS2.zip
sysd and coom are my dsl's
1. In Sysd file remove all the Grammer related to Component, State and System (Also remove coom import),Generate, it works perfect
2. Now Keep only Component, State and System and remove everything, generate it works
3. But the Grammer that i have shared does not have any error, no java compile errors but generated two sysd.ecore file . one in model/generated/sysd.ecore and src-gen/com....impl/sysd.ecore(This file is having some reference issues)
Can you please look in to it.. I guess this is xtext bug.
Girish
Re: Using Existing Ecore in XText [message #1400742 is a reply to message #1400577] Mon, 14 July 2014 12:54 Go to previous message
this is definitively a bug in xtext. please file a bugzilla
Previous Topic:Error after Xtext Utils add
Next Topic:Integer-based qualified IDs
Current Time: Fri Jul 18 11:05:31 EDT 2025
Powered by FUDForum. Page generated in 0.03338 seconds
