Home » Archived » Test and Performance Tools Platform (TPTP) » TPTP with Tomcat and server=controlled agent causes NoClassDefFoundError
TPTP with Tomcat and server=controlled agent causes NoClassDefFoundError [message #139938] Wed, 04 February 2009 13:11 Go to next message
I recently started using TPTP.
My configuration is as follows:
- Eclipse 3.4
- TPTP Agent Controller 4.5
- Java 1.6
- Windows Home edition
I configured Tomcat to pick up Agent DLLs straight from the Eclipse
integrated TPTP installation.
Not to mention having a bit of small nuisances like no Monitor tab is
present in Eclipse Profiling configuration, I was however able to run the
process with "server=enabled" agent and see some profiling information,
although this eventually killed the Tomcat process.
When I tried "server=controlled", my web application running on Tomcat
failed to start. The Tomcat log shows
org.apache.catalina.core.StandardContext listenerStart
SEVERE: Exception sending context initialized event to listener instance
of class org.springframework.web.context.ContextLoaderListener
java.lang.NoClassDefFoundError:
edu/emory/mathcs/backport/java/util/concurrent/ConcurrentHas hMap
My "just guess" is that because the "server=contolled" agent suspends the
Tomcat until I attach to the process from Eclipse, the normal application
initialization on Tomcat disrupts , so that it cannot find needed
libraries anymore.
Any ideas and help is highly appreciated.
Alex
Re: TPTP with Tomcat and server=controlled agent causes NoClassDefFoundError [message #140351 is a reply to message #139938] Thu, 12 February 2009 12:48 Go to previous message
Hi Alex,
With WTP-TPTP integration, you can start the Tomcat instance in workbench in
profiling mode. It will enabled Tomcat with the necessary profiling option
automatically. However, the Tomcat server is started in enabled mode.
Were you running the profiling session in memory analysis(HeapProf) or
execution analysis(CGProf), or thread analysis(ThreadProf)?
Eugene
"alexk " <akopylov@sympatico.ca> wrote in message
news:2a975ada81dd6f70acbebc4716c34e0a$1@www.eclipse.org...
> - Eclipse 3.4
> - Java 1.6
> libraries anymore.
> Alex
Previous Topic:agent controller
Next Topic:NullpointerException WorkbenchExecutionDeploymentAdapter.java:502
Current Time: Sun Jul 27 11:52:31 EDT 2025
Powered by FUDForum. Page generated in 0.03437 seconds
